Question about KitchenAid Dryers
Kitchen-Aid Dryer has power to dryer , door switch is working ,and inside light is working but dryer will not start.
    President:
  • 1,776 Answers
Check for a blown thermal fuse. It's about an inch long and is inside the rear of the dryer, usually attached to or near the exhaust duct. It can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a blown thermal fuse. Hope this helped and best wishes.
Posted on Sep 11, 2009
My dryer light comes on when I open the door, but the display panel will not come on when I push the power button
try the dryer aid draw switch and check you have some in systems or it will not turn on. just flash at you on some models. also check the bottom has enough salt inside as this as well as dryer aid needs to be topped up every now and then.
May 19, 2015 | Dryers
Kitchen aid gas dryer lights up but won't start
What is the model number? Look inside the door jamb.
Oct 19, 2012 | Whirlpool GEX9868J Electric Dryer
Kitchenaid prestige dryer will not tumble
I fixed one that would not run last Halloween. A Kenmore very similar to a kitchen-aid dryer:
4 Wheel dryer DE-mystatified
Jul 08, 2012 | Dryers
Kitchen Aid Electric Dryer Model # KEYE678BALO, won't start.
This is most often caused by a bad thermal fuse or thermostat high limit cutout. Check them for continuity (with the machine unplugged, of course) They should have continuity -- replace them if open. They should be available at www.appliancepartspros.com Also, if one or both are bad, check the dryer vent as they often are damaged by high heat due to a restricted vent pipe. The website above also has diagrams to help find the parts on the machine.
Dec 30, 2009 | Washing Machines
Maytag mde5500ayw,,,, have interior light and display will light up, but unit will not start???
hello. begin by looking closely at the latch on the door. if it has lint in it clean it thoroughly, vacuum the area and see it it will start up.
if not read on:
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Aug 17, 2009 | Maytag Dryers
Dryer won't start
Door switch
Thermal fuse
Wiring
Jul 22, 2009 | Kenmore Elite HE4 Electric Dryer
Checked the fuse it's ok but the dryer still won't start
Hi, What kind of problem are you having? Heating or running?
I can help.
Vic
May 25, 2009 | KitchenAid KEYS700LQ Electric Dryer
Kitchen aid clothes dryer
The door switch is likely stuck or jammed by some piece of material or lint build-up. you need to locate the switch, clear the debris away and make sure that the door pin is the only thing that pushes it in.
Sep 01, 2008 | Dryers
Dryer wont start
I would check the door swith first.
Jul 15, 2008 | Estate TEDX640JQ Electric Dryer
Open Questions:
Dryers Logo
52 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
