Question about Logitech Squeezebox Remote Controller
I've moved to a new house and wireless system. How do I find the PIN in order to set it up in the new place?
    Novelist:
    Champion:
  • 250 Answers
Hi, Please download the latest squeezeserver 7.5.0 and install it, The PIN code feature has been removed since version 7.4.1 Thanks and have a nice day ! J -
Posted on Jun 08, 2010
Ican't get wirless anywhere in side house except the room router is in. Are there longer extensions so i can move router to another room? Or what is your suggestion?
I've never seen cinder block affect wireless signal before. Metal pipes and ducts can interfere as can electromagnetic interference from appliances and ungrounded wires.
If possible, moving it to a location higher up, like a second floor of the home, could help broaden the range. Also, check to make sure that that there aren't any wires grounding out on places they shouldn't be (pipes and ducts).
Aside from purchasing expensive external antennae, moving the router through trial and error is probably your best bet.
Oct 23, 2012 | Computers & Internet
I've just set up my Technics SL D212 turntable after moving house. It keeps skidding across records. I've tried the usual adjustments and leveled the turntable. Any clues?
Please make 100% certain the needle is still in place... To test this *GENTLY* rub your fingertip over it and you should hear noise from the speakers when you do. If there is NO noise then there is likely no needle.
Did you put the protective device on the needle/arm for the move? Is it still on there?
Sorry Mate, that the only thing I've got to help....
Feb 20, 2012 | Technics Audio Players & Recorders
I own a regular MacBook and it's about a year and a half old. I recently moved into a new apartment and established a new wireless network through Comcast. They gave us a modem/router combo for our...
Hello Jodu,
Please check the internet settings of the Lan connection in the Mac Book. May be there is IP Address or DNS settings is installed in your Mac Book which are stopping the wireless network services. Please check the IPV4 settings in the Lan or wireless connection properties.
Jun 03, 2011 | Apple MacBook Mac Notebook
I want to find the pin for linksys router to give to house guest. can't find it on router
when you say pin do you mean the encryption key? and if so what operating system is on the computers in which are currently connected to wirelessly ? and did you try going to 192.168.1.1 and typing in your admin info? (default is usually admin for name and no password or password as password) and going to wireless then security and you should see something written next to the generate option and hit generate and that shall be hte key
Jun 02, 2011 | Linksys Wireless-G WRT54G Router
How do you connect the internet to the wii i have wireless in the house and it still wont connect
First, you have to go through the Internet connection setup process through the console and you've made no mention that you've attempted that so I wanted to make you aware of that. On the main menu, go to the lower left corner and click on the round Wii button. A new menu will appear with two options: Data Management and Wii Settings. Select Wii Settings. Go to the second page and choose Internet. Select Connection 1: None. Select Wireless Connection. Select Search For An Access Point. A network list will appear, select yours. You will then be prompted to enter the password/network key that you established when you set up your wireless router. The Wii will attempt to test the connection. If successful save your settings.
Second, simply because you have Wireless in the house it doesn't mean that it your wireless router has signal strength to reach the WIi. Various factors affect this including signal strength, distance from the wireless router to the console and obstacles such as walls and ceilings that interfere with the signal. If you're using a G router and you have your Wii is too far away or, has obstacles in the way, it will not connect. You should use an N-Router if there is a significant distance between the console and the router or if there are obstacles. Here is everything you need to know about connecting your Wii to the Internet.
http://www.nintendo.com/consumer/systems/wii/en_na/online.jsp
May 08, 2011 | Nintendo Wii Console
MY NEW LAPTOP WON'T CONNECT TO THE ROUTER WHEN I PUT THE PIN NUMBER IN....WHY?
1-In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
2-There is a great article at Working with Windows Wireless Networks
3-There a great article at General Router Setup.
follow the order~
If you need more help post back! Thumbs and testimonial are welcome!
Apr 22, 2011 | Belkin F5D7234-4 Router
Hello we forgot our password for our wireless router how can we reset it and make a new one?
Apr 19, 2011 | Belkin N150 Enhanced Wireless Router...
2 routers. Can i have two routers within the same workgroup. My wireless router will not work from one end of the house to the other. I need to have more than one wireless transmitter so my laptop will...
Yes you can have the setup in your workgroup in multiple ways.
Solution1:-
The logic will be making your new wireless router to act as a wireless booster which will receive the signal from your old wireless Router and then retransmits the signal.But this needs some extra configuration on your new wireless router
1. You have to select the WDS ( wireless Distribution System) mode in the new wireless router.
2. Set the same SSID on the new wireless router.
3. In the new wireless router config page , search for the wireless signals and select your old router from that list.
The WDS mode tells the new wireless router to send/receive the wireless signal to the old wireless router.
Solution 2:-
Connect your old wireless router LAN interface to a network switch through a CAT5e UTP cable and the new wireless router to another port of the switch (use a cable which can be extended to the other room where you want the new wireless router to be placed).
Configure the same SSID you have set in the old wireless router.
Best Regards
Nov 15, 2010 | Computers & Internet
How do laptops connect to my wireless router?
Wireless routers were configured with some security PIN in order to avoid unauthorized connections to your router. To connect to your router, just providing the PIN will do and no need of complex settings. Contact the service engineer who configured your router last time and tell him to configure your router with whatever preference you need. you can also set it in public mode so it wont ask anything and so anyone can connect into your router but this is not secure at all.
I hope this is helpful to you.
Thanks
Feb 07, 2010 | Arris SURFboard SBG900 Wireless Router...
Cant get good connection range .
Try placing the router higher up, for example on top of a bookshelf. You may need to move the router closer to the center of your house.
Aug 26, 2008 | NetGear RangeMax WPN824 Wireless Router...
Logitech Squeezebox Remote Controller  Logo
48 people viewed this question
Top Logitech Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
JP Services
JP Services
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
