Question about The Singing Machine DVD/CDG Karaoke System with Single Cassette Deck Shelf System
Loads then, no disc
I have the STVD-919, the disc spins and it says loading, then it reads no disc.
I've tried to clean with a dvd/cd player cleaning disc, no luck.
Please help. My son really wants a karoke birthday (10/24)
Thank you so much
It is your cd player problem
Posted on Sep 11, 2009
Sony bluray player flashes wait
see this causes and fix it. God bless you
If your mini DVD player reads "No Disc" after you've loaded the disc, it means the machine isn't reading the DVD. Take the DVD out again and clean it. It's quite possible that the disc is simply dirty and cleaning it will solve the problem immediately.
If you try several different discs and clean them and you still receive a reading saying "No Disc," then the problem is in the laser and this will need to be fixed by a professional.
Clean a DVD disc:
  1. Hold the disc by its central hub and outside edge.
  2. Blow dust from the bottom surface with a can of compressed air.
  3. Clean dirt and fingerprints from the bottom surface with a lint-free cloth dampened with CD/DVD-cleaning fluid or denatured alcohol, wiping from the center outward.
  4. Clean the objective lens:
  5. Remove the housing and lift the hold-down clamp to expose the lens.
  6. Remove dust with canned air or soft brush. If needed, use a foam swab or a camera-lens tissue dampened with lens fluid
Sep 30, 2012 | Sony BDP-S300 Blu-Ray Disc Player
5 disc cd changer CC4000 will not read
All players need cleaned from time totime. Do NOT try to clean it with anything other than a CD / DVD lens cleaner. They are available almost everywhere that sellsBlank media. It will clean the lens without scratching or smearing it.
Dec 06, 2009 | Marantz CC-4000 5-Disc CD Changer
My player when loading dvd loads for couple of secs and cuts off
Does the disc spin?
If not you have my problem spindle motor suspected faulty if the disc spins then its not being read, faulty lazer assy Try cleaning the lazer using dry brush disc philips do a good one and also clean the disc you are trying to play if it still doesnt work its a fault
Sep 02, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
Dvd player wont load disc
try cleaning the lens first.then load a disk.try a different disc like VCD, CD etc.if only the DVD's are not read, the lens and the mainboard itself is faulty.but, if after cleaning it, it goes ok ,then its just dirty.
May 28, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Prism DVD-352P not loading any disks
What you are hearing is the attempt to read the disk. The unti detects that a disc is present and attempts to read it by spinning it first at CD speeds then at DVD speeds. It will attempt this a number of times before giving up and reporting "no disc". If you can get at the optics, try cleaning the lens using a cotton swab and alcohol. Next try to read a CD. If you can read a music CD and not a DVD, it indicates that the optics are starting to fail and need to be replaced.
Dan
Dec 18, 2008 | Televison & Video
No Disc Error
there is no fix you bought someone else's junk
May 08, 2017 | The Singing Machine DVD/CDG Karaoke System...
Plays CD but not DVD, says no disc
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
Nov 29, 2008 | Insignia PD10135 Portable DVD Player
Won't read/initialize CD's or DVD's.
Check for a dry capacitor on the power suply is about 16v 470mf you can identified him because the top are inflate.
Jul 01, 2008 | Cyberhome CH-DVD 300 DVD Player
Won't load disc
Not sure exactly what happened, but the unit works beautifully now. Perhaps cleaning did the trick? spinning definitely got it to work manually. After sitting an hour or 2, I tried it and all worked fine, CD's and DVD's too.
Jun 12, 2008 | Coby TF-DVD7005 Portable DVD Player
Stopped playing...all DVD/CD
TRY CLEANING THE LENS WITH A SPECIAL CD LENS CLEANER.. YOU CAN BUY IT WALGREENS OR WALMART
Mar 07, 2008 | Mintek MDP-1020 Portable DVD Player
The Singing Machine DVD/CDG Karaoke System with Single Cassette Deck Shelf System Logo
495 people viewed this question
Top The Singing Machine Audio Players & Recorders Experts
 Grubhead
Grubhead
paul
Are you a The Singing Machine Audio Player and Recorder Expert? Answer questions, earn points and help others
