New pcb for zanussi fjs 1025w appears faulty after installation. Is it possible to test the PCB independently from the machine
    President:
  • 1,653 Answers
Not unless you have a test rig to do so. Best thing to do is get it swapped out.
Posted on Sep 11, 2009
Zanussi washing machine ZWF1431S wont empty or spin.it appears E50
From my experience I advise you to check the brush of washing motor in the opposite could be:
E51 - Motor power supply triac short-circuited
PCB faulty; current leakage from motor or from wiring.
E52 - No signal from motor tachometric generator
Motor faulty; wiring faulty; PCB faulty
E53 - Motor triac sensing circuit faulty.
PCB faulty.
E54 - Motor relay contacts sticking
Dado
Dec 11, 2016 | Zanussi Washing Machines
Why is my zanussi machine 6k9 1200apm error code e60
Family error code E60 is visible to customers and (could be E61,E62,E66,E68 and E69 only visible in service mode) means problem with heating phase.
Possible failures : heating element faulty, NTC sensor faulty,
PCB faulty, wiring.
Dado
Feb 29, 2016 | Zanussi Washing Machines
I have a zanussi 6hg 1200 rpm it's flashing error code E 60 what does it mean
Possible failures : heating element faulty, NTC sensor faulty, PCB faulty, wiring.
Dado
Mar 24, 2015 | Zanussi Washing Machines
E90 fault
Blue wiring loom that goes to the front control board from the maim control PCB has bad connection on the user interface.Clean PCB terminals and crimp connector to make connections tighter.if this doesn't work could be user interface fault or main PCB fault.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 02, 2009 | Washing Machines
Door not closing Zanussi FX1265W 1200 Auacycle
Further to my previous posting, I have now got a new Bosch but I have removed the PCB from the FX1265W. I found that the printed circuit track between the edge connector and the triac has blown. The triac (BTB16) was tested and faulty. New triac is on order (£1.03). I will post again when it has been fitted and the track is repaired and if the machine works.
Mark Allinson
Feb 15, 2008 | Washing Machines
Zanussi dishwasher
hi there sounds like a possible dry joint on the pcb repair and try first
Nov 26, 2007 | Zanussi ZT485 Built-in Dishwasher
Fills and then empties and error 1
sounds like the new PCB is not connected to all of the sensors (the water fill sensor especially) either that or you have got a faulty PCB.
Oct 01, 2007 | Zanussi 24 in. ZSF6120 Free-standing...
My zanussi's door wont lock, it normally clicks once to lock but now it clicks three times and does not lock or start washing. I have replaced the locking mechanism but still have the same problem.
Front PCB faulty, if you remove pcb you may be able to resolder blown track on pcb totherwise it will require replacement.common problem with this model. Regards Advisor
Nov 09, 2006 | Zanussi FJS1225W Front Load Washer
Zanussi jetsystem Turbodry 1200
It appears that you may have a faulty door interlock or a faulty PCB. pcb is not really a DIY job as some boards require proramming on certain versions. Regards Advisor
Oct 30, 2006 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
98 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
