Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
No reponse when using the remote, the wall control works fine.
The wall control switch to close the garage works fine, but when i try to use the remote there is no response. Both my remotes went out at the same time. The light on the back of the motor just blinks. Tried changing batteries and everything on the remotes. Nothing helped. Any help would be appreciated.
    Scholar:
  • 150 Answers
One thing you might check is the electronic door stops. If they are not aligned or something is blocking the beam it will not let it travel at all. You might get flashing lights on the door opener or it might start for a second and stop.
With the wall switch if you hold the button in it should make the door move.
Hope it helps
Check them and make sure they are aligned. Then go from there for a fix.
Posted on Sep 15, 2009
I just programmed my remote and the remote opens the door but won't close it. It clicks but wont close.
Posted on Sep 14, 2009
    President:
  • 3,197 Answers
The remotes use a receiver to actuate the door and the wall control does not. It sounds like your logic board is bad. Maybe a lightning storm recently? Try removing the board and look for burnt or missing traces on the printed circuit.
Posted on Sep 11, 2009
Why wont my 3 remotes (hand held factory in remote)only work to open the door ? They no longer work to open the door.I did replaced the batteries and reprogramed, craftsman 3/4hp chain driven garage d
SOUNDS LIKE SOMEONE MAY HAVE PRESSED THE LOCK / VACATIONS SWITCH ON YOUR WALL CONTROL. IF STILL NOT WORKING AND THE LED IN THE WALL SWITCH IS NOT FLASHING TRY AGAIN TO PROGRAM YOUR REMOTES.
GOOD LUCK
STEVE
Dec 15, 2014 | Craftsman 3/4 Hp Garage Door Opener System...
Lift master formula I will not close, only goes half way down, but fully opens. Worked fine until my wife closed the door on the car, after that it would fully close
I had this problem as well with the door opening just fine but was not closing when using the remotes or when breifly pressing the wall mounted control. The door would close only when using the wired wall mount control. I have experienced this problem with other garage door openers I've had in my previous homes and it was always caused by sensors at the bottom of the door tracks being either misaligned or the lenses were dirty. In this case, and it was just a moment ago today, I simply cleaned the sensor lenses and then the door began to function properly. Give it a try.
Jan 28, 2013 | liftmaster Chamberlain Garage Door Opener...
The garage Remote control was working normally at first then for now reason now it just opens the garage door but doesn't close it. I checked the side sensors they look OK & clear, and I...
It could be the garage door motor that is acting up. Try closing it with the button in the garage. If that's not the case, you may need a different garage door opener.
Jun 06, 2011 | liftmaster Garage Door 1/2 Hp
I have a Sears Model 139.53879 (3-Function Remote Control) garage door opener. It's about 12 years old. The remote controls open the door fine but the remotes do not close the door; it has to be closed...
Sounds like a problem with the safety photocells, to confirm locate the where the safety input is on the opener and bridge out the terminals ( not the supply voltage terminals) if the door then closes the photocells are the problem.
Mar 31, 2011 | Sears Genie Garage Door Gpwk12 Wireless...
I have a 3/4 hp model 139.53990D from sears. My reomtes have quit opening the door. they will close it. The light on the control console blinks very lightly, not like when the lock is set. Door works...
The symptoms you give are exactly the way it is when the lock function is used. The wall control and the keypad will work but not the hand remotes. If holding the lock button for 3 seconds doesn't change it you should hold in the smart/learn button for 6 seconds. This will erase all remotes from memory and only the wall control will work. Now program it for the remotes and the keypad.
Jan 21, 2011 | Sears Craftsman LiftMaster Chamberlain...
My lift-master garage opener works just fine from wall button, but will only open but not close from any remotes (from car or original remotes) If I open it with remote and immediately close with wall...
We have the same model and similar difficulties. We were told it's a bad antena. Not sure if there is anything we can do about this. Sometimes it works with the remotes, sometimes not. Always works with the wall switch, because that's wired.
Nov 12, 2010 | liftmaster Chamberlain Garage Door Opener...
Okay, I'm having an issue with my Sears Craftsman garage door opener. Not exactly sure of the model number, but can dig it up if that's necessary. Symptoms: 1) Door opens fine from either wall button or...
It sounds like you have a problem with your wall button. I would remove the button from the wall and then disconnect the 2 wires on the back. Remember where they go as they are color coded. You can then momentarily touch the two wires together to check the operation. There isn't enough voltage there to bother you.
One thing to remember. If when the door reverses the main light flashes 10 times it is a door sensor problem and nothing else.
Sep 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1/3 HP. Remote and wireless keypad stopped working.
Sounds like the reciever for you wireless devices is not working?
Aug 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will open with remotes, but not with the wall switch
Sure sounds like the wall control is bad. Very common problem.
Jun 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door remote
It sounds like the lock function has been toggled on. Press and hold the button on the wall control with the lock icon for 3 seconds. This will toggle that function off.
Jun 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
326 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
