Question about Toshiba 32AF43 32" TV
On/off switch Toshiba model CX32D60
1994 model works great except the on/off switch doesn't work. I used to be able to fool the switch by plugging and un-plugging the electrical connection, but no more. The set works great (as I remember), but I just can't get it to turn on anymore!
  • 1 more comment
  • littlesister Dec 10, 2007
    that may be beyond my abilities, but we'll see.
  • littlesister Dec 17, 2007
    I don't have acess to a skilled technitian, just some guy who charged me $75 and did nothing - not even turn it on!
    Is there any other way to by-pass the on-off switch. Once I get it on, I can leave it on and just use the cable switch to turn it off at night - like I used to.
  • Anonymous Dec 24, 2007
    power turns off after 2 or 3 seconds when i turn on toshiba cx32d80
    Genius:
  • 1,694 Answers
More likely, the switch itself is ok...I don't recommend
hardwiring...we used to do that sort of thing on much older sets..
Your set positively has bad solder connections in the regulated
power supply circuits...will need careful hand-soldering by a
skilled technician...................................T.
Posted on Dec 17, 2007
  • Vista Electronics Dec 17, 2007
    The on / off switch is not faulty....it is power circuitry that needs
    attention.................T.
    President:
  • 4,402 Answers
What i have done in the past is use one of the other buttons, if it's a push switch what ive done is hard soldered and then use a wall switch to turn it off.
Posted on Dec 10, 2007
  • Cary Farah
    Cary Farah Dec 17, 2007
    there is a company called PTSCORP.com
    if you take the board out you send it in and they can fix it.
    becarefull taking it out there is high voltage in that set!
1996 Grand Caravan Backfiring through intake
sounds like you didn't get the wires on the correct plugs .
Mar 03, 2014 | Cars & Trucks
Toshiba DVD SD73000KU will not recognize ANY disk
hi
have you been tried to clean the lazer lens with a cd lens cleaner. if doesn't work you can do with manual cleaning using a fiber cloth moist with alcohol damped gently the laser lens which may be dirty causing not to detect a disc. now if those tries still doesn't work your last option to make an adjustment on the speed settings of the drive motor. at the lower portion of the lens their is a trimmer adjustment, you can used a small flat head screw driver then try to adjust the trimmer just a little bit counter clock wise, make sure the player is unplugged for safety. then try to plugged it and turn on the player, insert now a cd and observed. if the motor doesn't rotating, removed then check if worn out, replaced a new one if needed.this will worked now.
hope this will helped thanks for consulting the fixya.
Dec 25, 2011 | Toshiba Televison & Video
My labtob is toshiba a665-s6089 the problem that the eco utility button doesn't work also i can switch on th eco utility mode manually but i can't do it using the eco button beside power button...
go to toshiba website, enter your laptop model and search for drivers. make sure to download all the drivers compatible to your operating system version.
Jan 03, 2018 | Toshiba Computers & Internet
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
I have a Toshiba model 32WLT68,which will not switch on
Have the main power supply module checked out first.
Oct 29, 2009 | Televison & Video
Toshiba 43AX60: sound but no picture
try switching to a different video source and play a DVD or a game system. If the issue is still there try unplugging the TV for 5 min. and then plug it back in.If the problem works fine on all other devices except the video source that has the issue try hooking up the same device your having the issue with to a video source you know works if that works then you have a bad video source on the back of the TV, if it does not work it's either the cable going to the TV or the device itself.
Jul 08, 2009 | Toshiba 43H70 43" Rear Projection...
Every thing works except the sound
press mute on the remote control
Jan 25, 2009 | Toshiba 32A33 32" TV
Toshiba e-studio 35 Copier Problem
there is one more swith to off the machine.the switch which you are using is only for make the machine into energy saver mode.in that mode machine will be warmed up to take the printouts from computer.
Aug 23, 2007 | Toshiba e-Studio 350 Copier
Toshiba 32AF43 32" TV Logo
78 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
