I have the new Printmaster 18 and it will not work with my printer. I tryed to print a simple document and it took 3 minutes to accomplish the printing. I also have Printmaster 15 still in the computer and it will send a message directly to the printer and print instantly. Printmaster 18 doesn't seem to be compatable with my HP Photomart C6380, but Printmaster 15 works just fine with the printer what can I do to make 18 work right.
    Guru:
  • 389 Answers
How do you do. For decision of your problem advise you to change adjusting the printer. There is adjusting the seal In characteristic of the printer. You it is necessary to install seal the text.Thank you for question.
Posted on Sep 20, 2009
Can I add a watermark to a flyer using Printmaster Gold 18?
I am trying to install a watermark to a document with print master gold 18. I'm having absolutely no success whatsoever. Anyone withany suggestions
May 20, 2010 | Broderbund PrintMaster Gold Version 18
I am trying to print a greeting card!
ITS ALL DOWN TO YOUR PRINT PREFERENCES.
NOT SURE YOU PROG, SOME ARE EASY TO SETUP/OTHERS A RIGHT PAIN.
TAKE TIME CLICKING TEMPLATES AND SIZES?
Nov 15, 2009 | Broderbund PrintMaster Platinum 16
Cant save to pdf in printmaster gold 17
found the fix for printmaster 18 broderbund pdf saving problems...
1-close all open programs and return to desktop.
2-click START and choose CONTROL PANEL
3-click PRINTER
4-right click on BRODERBUND PDF CREATER, then select PROPERTIES (the broderbund PDF creater properties window will open)
5-click the PORTS tab, then select ADD PORT button. (the printer ports window will open)
6-click NEW PORT, then enter PMPDF in the ENTER A PORT NAME window, then click OK
7-click CLOSE at the PRINTER PORTS window. you will now be looking at the broderbund PDF creater properties window
8-a check mark will be located next to the new PMPDF printer port. click APPLY. the broderbund pdf creator will now be located next to the new port. click OK.
9-exit all windows and restart the computer. once the computer restarts, you can save your project as a pdf file.
Jan 28, 2009 | Broderbund PrintMaster Platinum 16
Printing Envelopes
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Jan 10, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Printmaster 18 will not print on HP ColorLaserJet 5M.
Following the description of your problem, I noticed that you are mentionong both sides of the paper, so I am assuming that you are trying to use the 'Double-Sided Printing "
This can be the reason of the problem--> you can solve this issue by setting the program using the "Double-Sided Printing Wizard" in the File Menu
Nov 02, 2008 | Broderbund PrintMaster Platinum Version 18
Can't print any projects from Broderbound Printmaster Gold Version 18
Nobody uses that stuff anymore. Get LibreOffice, learn how to use it.
Apr 06, 2017 | Broderbund PrintMaster Gold Version 18
Printing from Printmaster 18
Try updating your drivers.
Aug 18, 2008 | Computers & Internet
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
