Flash error how do i fix it - Audio Players & Recorders
  • 51 Answers
Send it to the consumer's service.
Posted on Sep 11, 2009
Has error message
go to the following websites and post the error message
www.ask.com error message flashes deno than on
www.wiki.org error message flashes deno than on
than go to www.youtube.com/
to see if any one else has every seen this problem and have a fix on video to show you how to fix it
Mar 26, 2015 | Ovens
HOW DO I FIX KYOCERA SUM ERROR CODE F010?
That service code refers to the flash dimm, which is on the main pwb assy (controller). You have to try upgrading the system firmware. If the upgrade procedure fails, then you have to replace the flash dimm.
Jul 25, 2014 | Kyocera Mita Office Equipment & Supplies
Why do i keep getting shockwave flash error
Hi Mary,
I have this link for you on how to resolve shockwave flash error. Hope it helps.
How to Fix Shockwave Flash Crash Error in Google Chrome
Sep 23, 2013 | Google Chrome
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
The game will freeze up, the whole screen turning green
Hi,of the multiple errors that can strike the PlayStation 3, you may one day have to fix the PS3 green light flashing problem. This issue is perhaps one of the most antagonizing for the average user. The unit appears to power up for about 3 seconds and then shuts down before the system has a chance to boot. When this happens you need to fix PS3 green light flashing problem in order to get your console working again.
Simple Ways To Repair PS3 Green Light Flashing At Home:
In order to fix PS3 green light flashing problem you're going to have to do some troubleshooting on your machine. The usual steps of unplugging everything and doing a hard reset apply. These are universal and advisable for any error on any console. If this doesn't work then you're going to have to go a bit deeper into your PlayStation.
Typically you get this error when something is not operating correctly inside the unit. This is different from a display or hardware errors, these still allow the console to be turned on. In the event you need to fix PS3 green light flashing problem chances are something is not working with your power supply.
If the PlayStation 3 detects a problem in the power supply or any other components that might cause severe damage it will not boot. If you want to fix PS3 green flashing light error you need to track down the faulty component and replace it. Do note that this is a safety feature designed to keep the console from overloading and requires some dis-assembly to fix. If you are uncomfortable disassembling your unit to fix PS3 green light flashing problem then you should send it in to get it fixed.
Learn how to fix green light error of PS3 with step by step instructions. We have actually prepared pictures and video guidance to fix all the ps3 problems in the best Ylod fix site.
Take care.
Oct 11, 2010 | Sony Playstation 3 (PS3) Console
Controller 4 blinking lights continously
Hi, of the multiple errors that can strike the PlayStation 3, you may one day have to fix the PS3 green light flashing problem. This issue is perhaps one of the most antagonizing for the average user. The unit appears to power up for about 3 seconds and then shuts down before the system has a chance to boot. When this happens you need to fix PS3 green light flashing problem in order to get your console working again.
Have a nice day.
Sep 15, 2010 | Sony Playstation 3 (PS3) Console
At start up the green light turns yellow red light flashes and system powers down. What should I do?
Hi,In order to fix PS3 green light flashing problem you're going to have to do some troubleshooting on your machine. The usual steps of unplugging everything and doing a hard reset apply. These are universal and advisable for any error on any console. If this doesn't work then you're going to have to go a bit deeper into your PlayStation.
Have a nice day.
I try to play you tube video's and get a flashing green screen to a solid green screen
To fix a Youtube video error start from repairing your Windows registry which contains all the keys/codes for all the programs and applications such as flash, browsers and other softwares. You should choose a best tool which is able to fix the active-x and file association errors to solve your problem. A recommended software to fix such PC errors is listed at the end which you should try after following all the guidelines given here.
After repairing your registry and cleaning your Windows make it sure that your Flash version is up to date. To install the most recent version first uninstall the previous flash player through the Adobe uninstaller here: (http://kb2.adobe.com/cps/141/tn_14157.html). This utility will also uninstall the active-x component as well. After doing this install the latest flash player available at their web site.
IMPORTANT NOTE: When you are about to uninstall the older version of the flash make it sure that you have removed the registry keys of the old program from the Windows registry database. A registry cleaning software will help you to remove the unwanted and corrupt registry keys which is very helpful to make PCs clean from registry errors.
Also clear your internet history and cache before installing the newer version of Adobe Flash Player.
Have you tried playing the videos on other browsers? If the you get the Youtube videos error on other browsers as well then most probably it is the problem related to the flash. However, if only one of your browser is making trouble then also try to fix your browser. For fixing browser especially for the file association errors which prevent programs from opening properly repair the registry in your Windows.
Also do these steps to smoothly play the videos without any kind of Youtube video error:
* Disable firewall
* Disable pop up blocker
* Clear cookies, browsing data and history
* Restart your computer
The above guidelines allow you to fix your Youtube Videos error. If you are looking for a quick fix and want to try a solution that can do it almost itself then use a high performance registry cleaner and PC optimizer software.
RegInOut has been found the best software to fix the file association errors and other active-x issues in the computer. It not only repairs Windows registry ansd allows programs to run normally but it also boosts up PC speed. By using RegInOut you will be able to really stabilize your computer.
Aug 19, 2010 | Alienware PC Systems Alienware M17...
Cannot watch videos on you tube
Download and Install the latest version of flash player.
Download this file ...Adobe Flash Player
Please rate. thanks.
Aug 14, 2010 | YouTube Videos
 Grubhead
Grubhead
