Question about Kenwood Audio Players & Recorders
Higher speed on 33 rpm - Kenwood Audio Players & Recorders
  • 69 Answers
Maybe your turntable belt has stretched causing it to slip and speed up? go to http://www.needledoctor.com/Online-Store/Turntables and order a replacement belt. good luck
Posted on Sep 15, 2009
Record player turntable runs too slow. How to troubleshoot?
If this is a belt drive turntable the belt might be in the wrong position or is slack due to wear.
Jun 12, 2017 | Audio Players & Recorders
The speed switch results in same slower speed than 33 rpm when set to 33 or 45, and 78 is slower than 78 rpm, but faster than 45 rpm
Assuming it is a belt driven turntable I suspect the belt has slipped out of position. It might need adjusting or replacing. If you do need to replace it make a note of how it fits, even though it could be in the wrong position. It's a starting point for putting the new one in the right position.
Dec 28, 2015 | Audio Players & Recorders
On my 02 eldorado running tall tires at 65mph rpm is 1750. what mpg can i expect
you might get there but I doubt it as the digger diameter wheels takes more power to turn so the throttle will be opened wider even though the rpm's are lower.
Aug 21, 2014 | 2002 Cadillac Eldorado
Grundig 4400 / Audio Techinca T4P Turntable spins at 35 RPM instead of 33 RPM
I think you mean 45 rpm?
It sounds like you have got the belt in the wrong position. Try adjusting the position of the belt by experiment. Or you could look up the correct way to set up the belt.
Jul 28, 2013 | Audio Players & Recorders
Pioneer plz81
if the ampere was high it is not problem if it low it make ur motor very week so higher the ampere
May 14, 2013 | Computers & Internet
What's the correct way to use the strobe light to set turntable speed?
The turntable may have a pattern on the edge of the turntable. If not you need a turntable strobe disk that you place on the turntable like a record. The pattern on the disk or on the edge of the turntable will be marked for 50 Hz or 60 Hz frequency.
The strobe marks on the disk or on the turntable are for 33 RPM and 45 RPM and for both 50 & 60 Hz mains frequency.
To adjust the turntable for the correct RPM, turn on the strobe light and the turntable set it to 33 RPM and shine the strobe light on these marks and adjust the speed setting until the 33 RPM marks appear steady and not moving. You may want to check it for 45 RPM as well.
Make sure you use the correct mains frequency marks ie. the 50 or 60 Hz that your electricity system uses.
Feb 25, 2011 | Audio Players & Recorders
Playback on the turntable is sped up
The first step to resolving this issue is to select the appropriate RPM speed for the record that you have in hand. If it is not a simple 33 1/3 RPM record set on 45 RPM, then it would seem that the phono motor speed could require adjustment. Your phonograph is a belt-driven PX-E860 K with a DC servo motor.
Some people mistake the the 7"/LP record size LEVER for the rotational speed BUTTON (33 RPM when raised; 45 RPM when down).
In the case of needing to actually callibrate the rotational speed, underneath the unit there is a hole labeled "33" & a hole labeled "45." Using a very fine precision screwdriver, you can callibrate the speed of each. Insert the screwdriver into the repsective hole past the rubber & slightly turn the screw (rotational speed increases as you turn the screw clockwise).
Jan 07, 2011 | Aiwa Z-L500 Shelf System
Akai Ap-003 belt drive turntable pitch problem
Hi!
Make shure that is a 50Hz turntable. If you connect a 60 Hz turntable in a 50 Hz system, the result is aprox 28 RPM in the 33 RPM position/
Dec 31, 2009 | Audio Players & Recorders
Sony PS-LX250H speed problem
I have a different Sony model (PS-LX-150H) that had a similar problem. I hadn't used it in awhile, and then when I did, I noticed the speed problem.
IF your PS-LX250 is like my PS-LX150, there are small speed adjustment screws accessible from the bottom of the unit. On mine, the two adjustment screws were labeled - one for 33rpm, the other for 45 rpm. Basically I just fiddled a bit with them using a very small precision screw driver until I could verify that I had reached 33 rpm (I used a stopwatch and literally counted the number of rotations/minute after making adjustments.)
Now it sounds right!
Mar 09, 2008 | Sony PS-LX250 Turntable
62 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
