Question about IBM ThinkPad T23 Notebook
Laptop problem A friend removed stuff from my laptop and the speed is much better though now the visual display has changed cannot read words clearly and the pics are highly pixellated and almost invisible can you help me reset back to how it was before?? many thanks
  • daffydil Dec 10, 2007
    i think i need to reset to factory settings on my T23 IBM laptop as i have lost clarity format and colours and words are not easily read
    Can you please advise me how to restore it to how it was before?
    Many thanks
Try re-installing the video driver
Posted on Apr 16, 2008
    President:
  • 4,402 Answers
Right click on the desktop > choose properties > click on the tab button that say's settings and adjust the Screen resolution and color quailty till it how you like it.
Posted on Dec 10, 2007
How do i make words and pic. normal size if everything shrinks on widows 8 hp
To change the windows display, Text, Icons etc.:
Changing the Visual Appearance of Windows 8
Just click the different sub categories for what you need.
Jul 06, 2014 | Dell Computers & Internet
Words with friends
This has nothing to do with the computer you are using, but with the program running on the webserver Words With Friends you connect to and how it uses your web browser. Please clear your cache and cookies in the web browser you use . http://www.wikihow.com/Clear-Your-Browser's-Cache
Jun 22, 2014 | Dell Latitude D820 Notebook
I have a 1994 bmw 325is automatic transmission and reverse wont work at all and drive is starting to slip ive never changed transmission oil. IF i change transmission oil and filter will it fix this p
hi friend,,,,,,,,,,if your transmission is ZF 5 HP 18 or 19 or 24 or any other type of ZF 5 or even 4 ,,,,means with 5 or 4 speed ,,,you have to remove the pan oil and check the DG clutch ... most probably the side of revers is broken ,,,,,in other word ,,,changing oil of your transmission is not helping you at all ,,,,,,,,if you give me further information so I can help you more and to tell you what is your exact problem..........just tell me the type of your transmission,,,,I can check it on my list but better is you say and not to make a mistake for better diagnosis,,,,,,,,,,thanks
Nov 29, 2013 | 1994 BMW 3 Series
Why won't my vision fitness simple T9500 run? I tried holding down the stop button for 3 seconds. It did clear the screen. Then when I hit start it puts 6000 in the screen and will not run. It beeps as if...
With the safety key in place, press and hold “ELEVATION UP” and “SPEED DOWN” for 5 seconds. The software version will appear in display window shortly before model number appears. Press “ENTER” to accept correct model number IF YOU CANNOT GET INTO CALIBRATION EITHER UPPER CONSOLE ELECTRONICS OR OVERLAY CONSOLE ASSEMBLY HAS FAILED.
• Press “STOP” to enter “ENG1”. Press “ENTER”. PLEASE NOTE: HR Window = “0” for miles, “1” for kilometers, treadmill will calibrate in kilometers if set for kilometers. STEP 2 MINIMUM SPEED • Press “ELEVATION DOWN” button, “P0” will appear in display. • Press “START” button, the running belt will begin to move at minimum speed. • The display window should read approximately “.49 - .51”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “.49 - .51”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P0”. STEP 3 1/4 SPEED • Press “ELEVATION UP” button, “SP1” will appear in display. • Press “START” button, the belt will move 1/4 speed. • The display should read approximately “2.71 - 2.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “2.71 - 2.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP1”. STEP 4 1/2 SPEED • Press “ELEVATION UP” button, “P1” will appear in display. • Press “START” button, the belt will move at 1/2 speed. • The display should read approximately “6.72 - 6.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “6.72 - 6.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P1”. STEP 5 3/4 SPEED • Press “ELEVATION UP” button, “SP2” will appear in display. • Press “START” button, the belt will move at 3/4 speed. • The display should read approximately “9.41 - 9.43”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “9.41 - 9.43”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP2”.
STEP 6 MAXIMUM SPEED • Press “ELEVATION UP” button, “P2” will appear in display. • Press “START” button, the belt will move at maximum speed. • The display should read approximately “12.10 - 12.12”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “12.10 - 12.12”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P2”. STEP 7 MINIMUM ELEVATION • Press “ELEVATION UP” button twice, “P4” will appear in display. • The display should ready approximately “190 - 205”. • To adjust, press “ENTER” for value which should read “190 - 205”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P4”. STEP 8 MAXIMUM ELEVATION • Press “ELEVATION UP” button, “P5” will appear in display. • The display should read approximately “750 - 765”. • To adjust, press “ENTER” for value which should read “750 - 765”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P5”. REMOVE SAFETY KEY TO EXIT ENGINEERING MODE REPLACE SAFETY KEY AND PRESS START TO TEST TREADMILL
Jun 14, 2010 | Dmm Vision Fitness T9500 Treadmill
I open a link with word document and I get code execution has been interrupted, and it asks me if I want to debug, stop, clear, and click next on the pop up display.
If this occurs in specific link, the problem must be parametric. Or if it appears in all the link, you should reinstall the word document again and if the problem does not resolve, remove Microsoft Visual Basic Enterprise completely and then check. If it is opening correctly, then reinstall Microsoft Visual Basic Enterprise. If problem appreas again, there must be something fishy in your Visual Basic disk.
Nov 18, 2009 | Microsoft Visual Basic Enterprise Edition...
Laptop stuck at 800x600
Odd problem. To solve, best bet is too reboot computer, press F2 to enter system settings. Go to visual performance and set a terminal networked computer default. May reset all other setting as well though.
Jul 06, 2009 | Dell LATITUDE XFR D630 Intel Core 2 Duo...
Scan a document to my desktop
Choose OCR (Optical Character Recognition) if you mean to edit what you are copying, otherwise it would be like a photograph of what you are scanning and you will not be able to modify it as text. The original document should be very clear and the text dark, if not, then OCR will 'guess' what it thinks it saw and you had better be careful to review the entire document for errors. A good way to proofread a document for spelling is to look at it word by word from its ending toward its beginning. If you don't do it this way, then we tend to read it in context and read it so it makes sense even though there are misspellings. It wouldn't hurt to read it then from the top to the bottom to be sure it makes sense.
Sep 29, 2008 | Brother MFC 210C All-In-One InkJet Printer
Text problems with my Compaq laptop
perhaps you don't have the correct VGA drivers loaded or the screen resolution is not set to the best for your display!
The first two passwords are more than likely imputed before the system VGA drivers have been loaded!
You shouldn't really use it on your "Lap" hence most manufacturers have changed to the word "Notebook". Your clothes can block the cooling ports (causing over heating) and believe it or not there is a theory that they can give off a type of radiation which would be better off not being in your "Lap"
Aug 31, 2008 | Compaq Presario 700 470024-192 Notebook
IBM ThinkPad T23 Notebook Logo
148 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
