Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
Making a loud noise when on the spin cycle and not balanced
Washer needs new barrings? Makes a loud noise when on spin cycle and is not balanced.
    President:
  • 1,653 Answers
It could be a drum spring has broken or stretched too far, there is too much of a heavy load in the drum, or the bearing needs replacing.
Posted on Sep 11, 2009
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Noisy when in spin cycle
This could be the drum baring and probably will need professional engineer to do it.
Jun 01, 2017 | Kenmore 24032\24036 Top Load Washer
My washer makes alound grindin noise wen trying to empty
1) most Noises coming from washing machines coming during the cycles of SPIN .Clothes load can be un-balance. Stop the machine and balance the clothes.Start again, and repeat the step if necessary.
God bless you
Jun 28, 2012 | Washing Machines
Wash machine won't spin all the time and makes a loud banging noise.
Check to make sure that your clothes are not piled to one side causing the load to be off-balance. If that does'nt fix it then, It may be that your machine has a balance stabilizer on it that has worked its way loose or even off.
Jun 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
GE WSXH208A makes a lound noise during the spin
check to see if the washer is balanced (cloths are evenly placed in drum) if it sounds like banging noise
Jan 20, 2010 | Washing Machines
Washer agitates off balance and makes a loud banging sound until movement stops at the beginning of rinse cycle, advice?
If it makes this noise in the agitate mode and not during the spin cycle, I would suspect that the transmission is going.
Jan 03, 2010 | Whirlpool Ultimate Care II GSW9650LW Top...
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
GE washer (wjsr4160gww) makes loud noise during spin cycle
Remove the front panel and you will see two metal guides attached to the front of the frame. One of them will probably be bent and the transmission assembly will have jumped over one or the other of the guides. You need to manually pull it back to center then straighten the bent guide. May have been caused by load being out of balance or machine not properly leveled. Good luck.
Feb 18, 2009 | Washing Machines
Washer makes loud thumping after finished spin cycle
I replaced the drive block and it solved my problem. (thumping noise at the end of spin cycle) Easy repair. Videos on utube show all the steps.
Jun 07, 2006 | Whirlpool LSR7333 Top Load Washer
Washing Machines Logo
429 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
