Question about Amana ASD2622HR Side by Side Refrigerator
Amana model # ASD2622HRW will not defrost , pulled the sheild off the coils and the whole thing is a block of ics , defrosted it myself , can I fix this myself ?
    President:
  • 1,653 Answers
If this keeps happening then it is most likely that the controller board is faulty and needs replacing.
Posted on Sep 11, 2009
I had just submitted a question in regards to my Amana Freezer not keeping the food frozen and the coils freezing up to the point that we have had to defrost the freezer twice in the past 3 months.
Non defrosting units are a thing of the past, almost all fridges made in the last 20 years are self-defrosting. If the coils are freezing up, what kind of ice is it? Clear ice near the bottom indicates your defrost drain is clogged. Snowy, fluffy ice indicates the defrost system is the problem. Make sure the fan in the freezer is blowing freely. Then check the continuity of the defrost heating element. If its OK, the limit switch is bad. If its not replace the defrost heater. Also don't overlook the possibility the door gasket is leaking, allowing warm moist air in that condenses on the coils! To check a gasket, insert a dollar bill between the door and the gasket, close door on bill, pull bill out, if good resistance gasket is good, if little or no resistance gasket is bad or needs adjusting.Do this teas all the way around each door.
Aug 10, 2014 | Amana Refrigerators
RE: ASD2622HRW (7yo) The freezer and fridge sides of the unit keeping coming up in temp. Has happened 4-5 times in the last couple of weeks (that we know of). Ice starts to melt and fridge gets up to high...
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
Jul 29, 2011 | Amana ASD2622HR Side by Side Refrigerator
I have an amana br22 the botom freezer gets an ice block on the radiator coils then air flow slows down to top section i have to hot air gun the freezer to get the air to start moving
The ice block is due to a defrost circuit failure. Typical problems are due to the defrost heater, defrost timer if used on this model and defrost thermostat. Since you are using a heat gun to melt the ice, check the the defrost heater with a meter to determine whether it needs to be replaced.
Aug 23, 2010 | Amana Easy Reach AFD2535DE Bottom Freezer...
ASD2622HRW Freezer side cold, refrig side not cooling.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 31, 2010 | Amana ASD2622HR Side by Side Refrigerator
Jenn Air freezer does not 'automatically defrost-side by side
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem
Nov 29, 2009 | Jenn-Air JCD2295HES Side by Side...
Warm
If you need freon you can't do it yourself
Could be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 23, 2009 | GE Refrigerators
Refrigerator won't defrost.
Replace the defrost thermostat and defrost heater in the freezer.
Aug 19, 2009 | Kenmore 71279 Bottom Freezer Refrigerator
Amana bottom freezer problem
It sounds like the condenser coil might be freezing up. This happened to me on my bottom freezer. The cooling part of your fridge is only in the back of the freezer compartment. The cold air from the freezer blows up through a vent in the back to the fridge and comes out at the top. If the coils do not defrost (which is what happened with mine) the air flow is blocked by the ice and can't get to the fridge compartment. Your freezer will still be cold but your fridge won't. If you pull the plug on it and time things right you can defrost the coils but this will only postpone the problem. Both will work for awhile again until the coils ice up again. You can also pull out the freezer drawere and try to defrost the coil with a blow dryer. You have to disconnect the icemaker and pull out the back panel behind the freezer to get to it though.
May 25, 2009 | Amana ABB1927DE Bottom Freezer...
Fridg not cold
Ahhhh, the classic symptom of a frozen coil/air return duct. You'll have to pull the back panel off the freezer wall to view the coils. The are likely a block of ice causing the air channels on the sides to be frozen, thus blocking air flow. You may need a defrost t-stat or a defrost timer. If the defrost cycle isn't working then you will get a freeze up eventually. The only other reason is if the freezer door was left open slightly overnight letting in moist air. Let us know what you find.
Dec 27, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana ASD2622HR Side by Side Refrigerator Logo
126 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
