Question about Acer Aspire 4720 Notebook
Acer Aspire 4720Z Battery works till about 32% and then it gives a low battery warning of 5% before shutting down. It wont restart unless its plugged in. The battery shows 5% charge remaining. Where has the last 30% charge gone?
  • 590 Answers
Laptop battery notification is not accurate but approximate. The remaining battery usage is calculated approximately and then notified to the user. If your battery's life is more than a year, then the calculation goes on decreasing. It cannot be rectified unless you go for a new battery. But still you can tweak the battery life by,
1. Switch of the wireless adaptor when not in use.
2. Decrease the screen brightness.
3. Configure your power plan in control panel to minimal power usage mode while on battery.
4. The notification limit for battery low can be custom configured in the control panel. set it to 30 % and this will prevent your laptop to dye without power as your battery power drains faster below 31%
I hope this is helpful to understand the logic behind this.
Posted on Sep 11, 2009
Testimonial: "thanx. does putting it in a freezer for some time help in any way?"
  • 32 Answers
Usually this means the battery is starting to fail. The battery is giving the computer incorrect information which is what you are seeing. Usually this will get progressivly worse until it wont work at all. I see many batteries get to the point where they will go from 0% charged to 100% in a few minutes, but they dont hold more than a minute charge. Batteries fail often unfortunately.
Posted on Sep 12, 2009
Acer Aspire 4830T laptop battery behaving vaguely
Do you still have the old battery. If so charge it, and see if it charges properly. If so then you have a bad battery.
Mar 18, 2017 | Acer Aspire Timeline X 4830T 14 Inch...
Acer Aspire 4720Z will not power on
check all power leads
or if its trying to start or starts then shuts down check for over heating, check battery,check fuse in plug.
check fan to make sure its running.if not clean it.
Jul 02, 2014 | Acer Aspire 3690-2196 Notebook
ACER ASPIRE ONE
Unplug the computer, hold the power button down until the laptop shuts down, then remove the battery. Plug in the charger, and try powering up. If all is okay, shut it back down, unplug it, and reinstall the battery. Then, plug it in and let it fully charge. Restart it, plugged in and with the battery installed. Good luck.
Apr 06, 2014 | Acer Aspire One PC Notebook
My Acer Laptop battery shuts down completely at 40 - 30
Go to Power Options --> On the plan you are using select change plan settings --> Change advanced power settings --> Scroll down till you reach battery and click the + next to it to expand the settings --> Where it says Critical battery level and Critical battery action (on battery) make sure that the level is at 5% and the action is to hibernate. If it's set to do nothing, it will keep running until it's out of battery and completely shut off. Plugging the AC adapter would give it more power. If that isn't the problem, check your battery's connection and consider replacing the battery.
Nov 03, 2012 | Acer Aspire 5742G
Hi, My Acer aspire 5332 keeps shutting down with no warning, I have rebooted approx 7 times each time it will shut itself down.
Have you checked the battery condition indicatot on the lower right hand side of the screen? It may be low and telling the laptop to shut dow.
Hope this helps.
Oct 31, 2010 | Acer Aspire 1202XC (LX.A0105.085) PC...
I have an Aspire 7736Z-4809 and it seems that the battery isn't working. If I unplug the power strip the computer shuts off. Is this the battery or the settings or the plug? Any thoughts?
Unplug the laptop then remove the battery. Reseat the battery, plug the laptop back in. Then restart your laptop. Give it 5-10min to allow for a small charge and then remove your charger again. If the laptop shuts off immediately it is quite likely that your battery has failed. This is quite common for batteries. If you're under warranty please contact the manufacturer. Else you will likely find a cheaper battery solution on ebay. -Ravi Shanghavi
Aug 19, 2010 | Acer Aspire 5335-2257 Notebook
Acer aspire 2920z is automatically shutdown only message appear warning critical battery low and then shutdown
Sounds like your battery is faulty and not charging. Try replacing the battery or just use the mains lead with the battery removed. If this keeps happening replace the system board
Feb 23, 2010 | Acer Aspire 5610-4648 Notebook
Acer Aspire battery shutting off with no warning.
Karen,
I am not familiar with this particular model but deal daily with this same issue on the Lenovo Thinkpads...it is the battery. They can just go bad. Had one yesterday that was fine the day before, now won't hold a charge. It was also less than two years old. They seem to have a shelf life. I would check with ACER to make sure they agree, then order a new battery.
To extend battery life, you need to use the battery up on a regular basis, then recharge all the way. Leaving it plugged in all the time with the battery in shortens battery life.
Jul 31, 2009 | Acer Aspire 5920 AS5920 Notebook
Computer shuts off
Maybe it's your power supply, I suggest you get a voltmeter and check the voltage on the power supply.
Good luck
Nov 07, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 4720 Notebook Logo
197 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
