Question about Sunbeam Classic 3957 Iron
I dont get any steam. it heats up.
How do i take the iron apart?
  • 1070 Answers
SOURCE: My Tefal Steam Generater Iron will not steam
check the little tube that regulates the water to the holes it needs to be changed.good luck.
Posted on Apr 18, 2007
SOURCE: No steam
It appears that your rocker switch is broken, I am attempting to find a source for the switch and the screw driver that removes the screws holding the unit together
Posted on Feb 25, 2008
SOURCE: Tefal Pro Express Steam Generator Iron
My Tefal is the same, steams for a while then nothing. I have tried to descale with no joy. I think it may be a problem with an internal thermostat that cuts out stopping the steam.
Any ideas????
Posted on Aug 29, 2008
  • 62 Answers
SOURCE: Iron not heating up...
Unless you have a 5 or 6 hundred dollar iron, or unless it is brand new, and still under warranty, there is an excellent rule of thumb when an iron quits working: Buy a new one! These days, irons can be purchased cheaply enough that it is WELL worth the money. Not just for the convenience, but for the safety issues. This is an appliance that could burn your house down even if it's in PROPER working order. Hope this helps!!
Posted on Oct 08, 2008
  • 1714 Answers
SOURCE: brown dirt coming out of steam iron
You're seeing hard water deposits and maybe a little rust. Use some CLR and pour in the iron and let it sit with it off. Shake it a bit and let it clean it all out, then rinse with clean water. (Vinegar will work too)
Posted on Jul 02, 2009
SOURCE: euro-pro EP1005 iron--iron heats -blower works-but no steam
You may not need a new iron, my wife's iron is doing the same thing. take the top of the ironing board off (you will need a torx t-20 security bit driver), under the tank is a connection that may have rusted out re-connet it and turn the iron on. Once it heats up, check the tank for leaks. The tank may need to be replace as well or try a 5-minute epoxy type glue on the leaks once it has cooled. If the tank leaks you will get not get enlugh pressure building up to get the steam.
Posted on Jan 05, 2010
0 characters
1 Points
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
Feb 29, 2012 | Irons
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
May 22, 2010 | Rowenta Commercial Garment Steamer - White
Steam iron is not heating.
Yes you most likely can, they are very simply consisting basically of, a switch, a thermal fuse, a thermostat, and an element.. all wired into the Phase wire, the neutral, is simply the return. Take it apart and draw a diagram of how it all goes together and reverse the procedure.
May 09, 2010 | Irons
What happens if I use CLR in my steam iron? I have an expensive European style iron which is no longer producing steam. I have bought an iron descaler/cleaner and have repeated its use. I tried the...
The steam tank may not be heating because of mineral deposits in the tank. But also do this check first. Open up the tank reservoir cold, and drain all water out, (is it clean inside there when you shine flashlight in there? Rinse with clear filtered water only (low minerals).
Do not use CLR or anything agressive in there. You should have the main unit in full steam mode and the iron control also in full steam mode. Leave one tablespoon of water in the tank, put back together and let the pressure build. Put a clean towel on your ironing board and when iron is at full pressure and heat, hit the burst of steam and look at what comes out of the sole plate. If you see lots of white deposits look at the sole plate and see if the white chunks are coming out steam holes.
When using iron, run it till steam/water tanks are dry, the burst of steam is used in this case to clean the iron of all standing water. Pull the reservoir and allow to cool...once tank is cool drain it as well. Doing this several times should help purge unit of the heavy mineral deposits.
If you need parts, here is the Rowenta repair facility....
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is:
or tech service:
Mar 12, 2010 | Rowenta DG-980 Iron
My iron will not consistently get HOT.
The clicking sound is given by the solenoid that turns on and off the iron element. Heating cannot be turned on, and the iron keeps clicking without making any heat.
The cause of the problem can be a defective solenoid, a broken contact, or an open thermistor (it will turn the solenoid back on). The oven must be taken apart and tested to find the fault.
Mar 02, 2010 | Rowenta Irons
The iron does not heat up
Either wiring is broken or the heating element is broken.
The heating element is tested taking apart the iron, disconnecting element contact, and reading impedance on element contact with a multimeter set at Rx1. If the element has no continuity (circuit open), then the element must be replaced.
Jan 15, 2010 | Steam Fast Irons
Wont heat as much and on steam setting it leaks
make sure you dont have the steam dial on self clean if it if is iron wont act right
Aug 13, 2009 | Euro-Pro Shark GI490 Iron
MY rowenta Iron wont produce steam. IT heats up
Sounds like the Steam control valve is blocked or not opening. try cleaning the iron with a kit from wallmart or similar store. Failing that :It may be cheaper to buy a new one from wallmart or similar store.
Jul 25, 2009 | Rowenta DX6700 Iron
Steam button on iron has stopped working yet iron still heats up and light on boiler still goes on.
this just happened to us & the electronics man at my husband's plant took it apart & said the thermostat needs replaced. the wires were all eaten up so to speak
Jun 10, 2009 | Rowenta Steam Generator DG050 Iron
Dec 11, 2008 | Oreck Cordless Speed JP8100CA Iron
Open Questions:
Sunbeam Classic 3957 Iron Logo
32 people viewed this question
Top Sunbeam Irons Experts
D. E. Hev
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
