Question about Hussmann Freezers
I have a hussmann g6f-8u and can't stop the ice from forming. what should the defrost be set on?
  • Hussmann Master
  • 1,218 Answers
Most all freezers are set at a defrost of every 6 hours (4 times a day) and for about 25 to 30 minutes. This is a good starting point.
Be sure that the system is working right. If you are icing up, you may have other issues.
Hope this helps.
Posted on Sep 12, 2009
What the best way in defrosting evaporator when full of ice
http://www.hussmann.com/Installation%20Manuals/DCCG_DCSG_06_im.pdf See page # 6
Oct 20, 2010 | Hussmann Commercial Freezer DCCG-12
What the fastest way in defrosting dairy cooler
Fridge freezer side by side running constantly but not cooling.
Make it a habit to defrost it every week. You see, when ice forms around the evaporator tubes (which runs around the walls of fridge and freezer), heat exchange reduces (that means heat is no longer absorbed from the things inside the refrigerator) and cooling stops. See whether freezer walls or fridge walls are damaged. Do not use knives or any other sharp tools to remove ice. Do not forcefully remove items that are difficult to take out from the freezer. Defrost and remove them.
Aug 12, 2009 | Freezers
Won't freeze after door was left open
Having the door open has introduced an excess of humidity and therefore condensate/ice into the freezer coils. The coils are therefore iced over. You have choices depending upon your skill level. You might: allow the unit to sit unplugged with the door open until the excess ice thaws out and wets the floor underneath, which may take from 6 to 24 hours. You might: do this, adding some heat source in the freezer to accelerate the process. You might: locate the defrot timer, advancing the timer until a click is heard indicating the unit is in defrost, and repeat after about 15 minutes to defrost the unit with it's own heater. You might: let it recover just as it is but it will take a couple of days to clear itself.
May 19, 2009 | Hussmann Freezer 12 Facing Straight Glass...
Top of freezer is warm and bottom is forming ice. What do I replace?
The cause if no defrost cycle , remove the panel where the ice is and derost with unit unplugged , use a hairdryer or similar to defrost ice , make sure its all defrosted , check the heater under that coil to make sure its still intact.
Also check the defrost timer , there may be a wiring diagram on the back showing where this is located.
Phil
Apr 15, 2009 | Freezers
Defrost tube needs replacing
12999 St. Charles Rock Road
Bridgeton, MO,
63044-2483
USA
Phone: 314.291.2000
FAX: 314.298.4756
Jun 08, 2008 | Hussmann Freezers
Freezers Logo
136 people viewed this question
Top Hussmann Freezers Experts
Dennis Boxerman
jasbo
jasbo
John Tripp
John Tripp
Are you a Hussmann Freezer Expert? Answer questions, earn points and help others
