A/c fan starts and stops
A/c fan starts and stops on my Dodge Ram 1500 sport pick up.
Only runs on high speed when working.
  • Dennis Boxerman May 11, 2010
    In most every case, it's the fan switch. I'd do that before I'd do anything else.
  • 534 Answers
Speed control switch has gone out on all but the high speed.
Posted on Sep 16, 2009
2001 dodge ram 1500 4x4 sport ac and heater fan runs only on high what the fix
Replace the relay under the hood .There is a black box that wii say relays check your relals ther sould b 2 also check fuses Good Luck
Oct 15, 2011 | 2000 Dodge Ram 1500 Truck
2001 dodge ram 1500 4x4 sport 5.9 l heater and ac fan works on high only whats the fix
Very common. The blower motor resistor is burned out. The part is about $25 and you can replace it yourself 3 zone will cost 75 bucks and is behind the glove compartment..2 screws and 2 wire disconnects and your done.
Oct 15, 2011 | 2001 Dodge Ram 1500 Truck 2WD
Low and medium speed fan for ac does not come on, while high speed fan works. 2000 1500 dodge van, had new condensor unit under dash replaced recently.
Blower motor resistor needs replacing. Follow wires from blower motor to connector, which should be the resistor. Usually in duct work, held in by 2 small screws.
Jul 25, 2011 | 2000 Dodge Ram 1500 Truck
I have a 2002 Dodge Ram Quad Cab 4x4. The a/c runs great as long as the truck is moving, but as soon as you come to a stop it starts blowing warm air. Please help.
Generally if the a/c works fine at highway speeds but kicks out or slowly begins to blow warmer and warmer air as the vehicle is driven at slow speeds or is stopped the a/c condensor cooling fan is usually at fault. At highway speeds there is enough air being forced through the radiator, condenser, and oil coolers to keep everything working and cool but when the vehicle is moving slowly or is parked the electric and mechanical cooling fans have to be working to pull enough air through to keep things working. If the cooling fan isn't working or can't pull enough air through the a/c condensor the system will kick out once the internal pressure reaches a certain point. Once the vehicle is moving again the system can get rid of the heat that it has gathered from the passenger cabin, the pressure drops back to normal and the system cools again. I would start by looking for a blown cooling fan fuse in the fuse panel under the hood. Usually they are 25 amps or larger and run only the cooling fan.
Jun 14, 2010 | 2004 Dodge Ram 1500
1997 dodge ram idling problems
check the iac (idle/air valve) it controls the idle speed during the time the engine is started or coming to a stop. iac valve is located behind the throttle body . hope this will help you with your problem!!!!
Apr 16, 2010 | 1997 Dodge Ram 1500 Club Cab
2004 Dodge Ram 1500. Radiator fan is very loud at
you could change the fan to an electric one and take off the old fan off why bother.....alternatively try soundproofing the bonnet/hood works for me(cheaper)
Feb 23, 2010 | 2007 Dodge Ram 1500 Quad Cab Sport
Po 108
if there is not a vacuum leak it seems that the signal wire to the MAP is either open or shorted to 5 volt reference wire. if not either of those may be the PCM
Jan 09, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Heat blower only works on high speed
replace fan speed reostat,generally high spd. does not go thru the reostat-full 12v service..kev-mn.
Dec 10, 2008 | 1998 Dodge Ram 1500 4WD
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
