Question about Poulan Pro " Pro" Self Propelled Mower
Can't push my self propelled lawn mower!
I have a Craftman rotary lawn mower 675 series ,which is very hard to push .Changed the belt and that didn't fix the problem. Someone said I needed a new transmission
  • Wayne McNeil May 11, 2010
    Once you fire it up, will it move when the drive is engaged? If it does then it's not the transmission. However, when it comes to pushing it, does it have freewheel capability, because some doesn't. It needs to be running before it'll transport.
    Problem Solver:
  • 6 Answers
Remove the drive wheels and have a look at the gear teeth in them. If even slightly worn, they need replacing. If you run the mower with the wheels off, that end elevated with a block, see if the axle turns when you engage the drive. If it does, your transmission is fine. Wheels are a lot easier to change than a tranny.
Posted on Oct 01, 2009
My yard king performance 675 series has problem with self propelled unit.
your drive belt that turns the self propelled unit is worn or stretched and not turning the gears. or the gears themselves are worn down causing them not to engage. check your belt first that is most likely your problem. hope this helps
Sep 11, 2015 | Kelty Yard King 21" Push Lawn Mower w/...
I have a craftman rotary lawn mower
Check the drive belt as it may be broken or most often they get out of adjustment, too loose and fall off of the drive pulley.
Sep 19, 2014 | Garden
How to tighten belt
I'm going out on a limb with out doing a little research first, but look on the backside where the self propel lever is and see if there is an adjustment nut there. Just a shot in the dark. George
Oct 26, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
Craftsman 675 21" rear self-propelled not pulling
Remove blade and loosen tension system slide belt over transmission and off of the engine
Apr 17, 2013 | Craftsman 675 Torque 190cc 21" RearBag...
Repairs on craftman lawnmower 917-377-550
Sounds like someone cuts the grass when it's to wet for that much to build up
Mar 23, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
What kind of battery does it take
Mowers don't typically take batteries. Possibly riding mowers might, but not push/self propelled mowers. They run off a spark plug and gas and that's it.
Jun 13, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
I HAVE A CRAFTMAN LAWN MOWER 6 HP SELF PROP RUN FOR 2 OR 3 MINUTES ONLY I CHANGE THE OIL GASOLINE AND S/PLUG CAN YOU HELP ME TO FIX IT?
It sounds like you have a bad Ignition Coil (Module). This is how they act when they start going bad. When they get warm, they quit. Some will last up to 20 minutes before they shut down. You can sometimes find a used one pretty cheap at a small engine shop.
Jim
Aug 07, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Where is the carburetor on the Craftsman 675 Series 190cc 22" cut self-propelled lawn mower?
The carburetor would be located BEHIND the air filter housing and air inlet tube. The air filter housing should have a removable (by screw or clip) cover.
Apr 13, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Self propell wont work when wheels are in put in grass. I have changes cable and drive belt. what could be problem?
If you take off the wheels, you'll see gears inside the wheels, check for wear and tear. If their Ok, check the cogs and pins inside the cogs on the base (or chassis) for wear and tear
Jun 22, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
Troybuilt 675 hp lawn mower doesnt start
self propelled not working on troy built 675 series bought 5/08. The belt is still on.
Jun 17, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Poulan Pro " Pro" Self Propelled Mower Logo
426 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
