Question about Sharp AR-156 Copier
How do I reset the maint lites on a Sharp AR-156? Replaced developer bvut still have maint lites.
    Guru:
  • 389 Answers
Http://free-manuals.ru/download/53f901ad306715dee588d2c0e77ea8cd
please, take the manual data/ Yous descriptions is too aa litle? i do not undestend, what the lite is on? goodgold@inbox.ru i am Sergey, write me
Posted on Sep 12, 2009
We no longer have our manual. The Little man is lit up and also the dotted circles to the right of the triangle. What does it mean?
the little man means time for service, that is replace the drum and toner developer units,
the maint. man has to be reset by aservice tech, you might try the sharp support site for the reset instructions .
good luck ,tinyman
Jul 19, 2011 | Sharp AR-153E Copier
The copier is saying"maint. req".Also
You need a new drum and developer changed i would nearly guarantee
Do you do work on the copier yourself?
Jul 07, 2011 | Sharp AR-M257 Black and White Copier
Code CH s.v.p.
i really need a code to reset AR-sharp 5320E which display developer light with toner light together at the same time
Jan 30, 2011 | Sharp AR-156 Copier
Sharp AR-156, with code H-4
H4: Heat roller abnormally low
temperature.
cause:-
Thermistor failure
Heater lamp failure
MCU PWB failure
Thermostat failure
Power supply failure
Execute Simulation 14 to reset
Dec 21, 2010 | Sharp AR-156 Copier
I have a sharp ar-m257 copier. my copies were
There are a few thing's > have you cleaned the optic's > clean the primary charge unit in the drum unit > how old is the drum & developer? Also, is the copier calling for for "Maint's Req"
Apr 05, 2010 | Sharp AR-M257 Black and White Copier
How do I change the developer on a Sharp AR-156?
The developer sits in a small, black casing that houses the toner bottle. When you pull out the toner, look for a small, blue or green screw that holds the developer box in.
Once you pull the developer out, you'll notice three screws on the outer casing (two on top as you look down on the unit, plus one looking down into the opening where the toner bottle sits). Removed these screws and set them aside. You should now be able to pull the cover off the unit and expose the developer assembly.
Dump out the old toner in a plastic bag. Be careful, as it can spill out quite easily and it's a pain to clean up out of carpets. You'll want to invert the developer unit and use the plastic gear on the backside of the unit to spin the magnetic rod until all of the developer has been removed (be careful not to scratch the surface of this rod, as it's what holds the developer in place during copy processes).
Place the new developer into the open auger area of the unit. Put the cover back on and install the three screws you removed earlier. Place the developer assembly back into the body of the copier and screw the blue or green retaining screw back into place. Now you can re-install the toner bottle and start the copier back up.
Sep 10, 2009 | Sharp AR-156 Copier
How do I change the developer for a Sharp AR-156?
It's part of a kit. You'll need to consult their support site or a tech to get the part number and pricing. It's all disposable these days...
Sharp AR-M165, maintenance led and developer replacement leds on
It's the drum thats causing the lines to happen. Youre going to have to get that replaced before you can reset the counters.
If you get light copies, then the developer should be replaced.
Sep 01, 2008 | Sharp AR-5316 Advanced Digital Imager...
Developer sign
The developer doesn't need to be reset on AR series machines. Toner and developer are in one cartridge. There is a drum reset. That is service code 24-07.
Did you replace the drum as well?
Aug 11, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-156 Copier Logo
98 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
