Question about Hummer REMOTE CONTROL HUMMER H2 RC CAR HIGH PROFILE TRUCK 1:16
Maisto Hummer RC Concept 1:14. This has a wire running down from under chassis to the top and its pretty long? does it do anything (antenna) or is it just a packing thing
3 Suggested Answers
swampthang90
  • 18 Answers
SOURCE: 2006 Hummer H3 a/c & heater fan/blower failed
Probably too late now, I am sure you have already fixed it, but mine did this and it was an electrical part that is mounted right beside the blower fan. The part was OK, but the plug into the part was arcing and burned out the connection. A Chevy mechanic told me this has been happening to MANY Chevy products. I had to buy a new part and plug assembly with new wires, about 100 dollars, and I spliced them together. It was an Easy fix, but I shouldn't have had to do it :(
Posted on Mar 07, 2010
  • 20 Answers
SOURCE: Need replacement mote for maisto rc junior train.
Maistro should have a website, look on the toy it self and it should have a number/website, and they will ask you for the model numbers..etc..hope it helps!
Posted on Jun 05, 2011
Hi, I've a maisto 458italia rc toy ,which was working perfectly for 2 months .all of a sudden it wouldn't.work,I replaced a set of 4 batteries and tried several times,but I stil.wouldn't.work.pls hlp
There could be many different problems here:
  • Your transmitter may have disconnected wires or a blown circuit board
  • The car itself may have disconnected/loose wires or a blown circuit
  • The electric engine may be blown
If you have good soldering skills you may be able to reconnect wires, or install a new circuit or engine for cheap. Otherwise you can take it to a shop to get it fixed up, although it may be cheaper just to buy a new one. I hope this helps
Apr 11, 2015 | RC Toys
Where does the antenna wires attach on the fujitsu n3010 I know one end of the wires go to the wlan card. someone removed the antenna wires why I dont know. most of them connect behind the screen but the...
Look for the service manual for your laptop. It should show the routing of the cables. The antenna wires may have been disconnected for a screen replacement. Typ ant wires are black and white and should go back to the WLAN board in the correct location. If they don'r reach it may be incorrect routing or just the wrong cables. Try switching the main and secondary antenna cables if not sure which is which....... should not hurt anything if backwards, just poor range.
Apr 08, 2011 | Computers & Internet
My so31 ligths up but does not respond to remote
Check that the antenna isn't rubbing against the chassis as mine got rubbed thru and I think shorted the sensor. After trying playing with the left switch on the remote about 20-30 times it synced again with my chopper and I touched the open antenna wire purposely against the chasis and it would lose signal, then I removed it and it worked again. Tried that a few times so I think it's rubbing against something causing it to short out.
Jan 03, 2011 | xheli Syma S031 Outdoor RC Helicopter
I removed the top cover and there were 2 wires attached. While sliding the cover off i broke both wires. What is the function of these wires and do i need to have them repaired
Its a chassis intrusion switch incase the wrong person decides to get inside the PC. It must be disabled in the BIOS otherwise you would hear it beeping away. Unless you think you need an alarm for that dont bother with it........cheers from Scott
Feb 24, 2010 | HP Pavilion Elite M9000z PC Desktop
My t maxx 2.5 is driving and steering by itself. when the engine isnt running everything works fine, but as soon as i start it it drives and steers and i have no control. ive taken it to many places...
Sounds like an antenna problem. Make sure the antenna is isolated from any metal of the chassis or engine. Also make sure the antenna is not damaged anywhere. You could try purchasing crystals on a different frequency, but I think that it is more likely a mechanical issue.
Nov 01, 2009 | Traxxas 4910 T-Maxx RC Monster Truck
How to replace thunderbird antenna
please rate service.
Automatic Electric Antenna
Removal
  1. Lower electric antenna (18850) .
  1. Remove rear retaining screws of RH front wheel splash shield for access to antenna lower retaining bolt.
  1. Remove lower retaining bolt.
  1. Remove radio antenna nut (18865) from top of motor tube and remove electric antenna through fender/splash shield access.
  1. Disconnect signal cable and motor wire connector(s).
Installation
  1. To install, reverse Removal procedure.
  1. Tighten top radio antenna nut to 6-8 Nm (54-70 lb-in).
  1. Tighten lower electric antenna retaining bolt to 5.8-7.8 Nm (51-69 lb-in).
  1. Check operation of electric antenna and radio chassis .
mast
Mast, Power NOTE: A power antenna mast which is bent or broken can be replaced without replacing the motor and tube assembly.
Removal
  1. Remove radio antenna nut (18865) and radio antenna stanchion (18919) .
  1. Loosen retaining nut inside tube using 14 mm (9/16 inch) socket, and slide nut part-way up mast.
  1. Raise antenna to run plastic drive wire at bottom of mast out of motor. Note direction of teeth on plastic drive wire.
  1. Saw off damaged portion of antenna mast. Remove burrs from mast and slide nut and contact tube off stationary tube.
Installation
  1. With the teeth on the plastic drive wire facing toward motor on antenna, push end of plastic drive wire of replacement mast assembly down into tube. Push it around curve at bottom of tube until end enters drive mechanism.
  1. Run motor down while pushing on plastic drive wire until about 305 mm (12 inch) of wire has been drawn into the tube. Stop motor and insert bottom of antenna mast into tube. Lower mast.
  1. Slide contact tube and radio antenna nut down antenna mast. Tighten nut to 0.45 Nm (4 lb-in).
  2. Raise and lower antenna several times to ensure proper operation.
Jul 09, 2009 | 1995 Ford Thunderbird
Cant get SWR below 3.5
A ground wire will not replace the lack of ground plane. Try a different antenna altogether (possibly one with a magnet mount) and mount it on some metal surface like even the front hood and retest.
I am sure the problem you will find is with the lack of a proper ground plane.
May 31, 2009 | Cobra 29 LTD CB Radio
Hummer REMOTE CONTROL HUMMER H2 RC CAR HIGH PROFILE TRUCK 1:16 Logo
214 people viewed this question
Top Hummer Toys Experts
ray gallant
Are you a Hummer Toy Expert? Answer questions, earn points and help others
