Question about Garden
Tecumseh 00h60 smokes has 90# compression - Garden
    President:
  • 1,129 Answers
Valve stem seals may be worn out allowing oil to pass into the combustion chamber.
Posted on Sep 11, 2009
What should the PSI read on a compression test for a 5 HP Tecumseh engine?
This check is difficult because of the internal compression release that most small engines are equipped with.
This link helps to better understand what to expect.
COMPRESSION TEST on 4 Cycle Engine with Automatic Decompressor
Hope this helps?
Jan 17, 2016 | Tecumseh 5hp Engine Snow King Mtd Blowers...
What should the psi be on a compression test for a 5 HP Tecumseh engine??
Anything lower than 90 psi should be a concern. 110 or so should be good
When I start my ride able Ranch King Mower I get white smoke. I just had the oil changed & they did a Compression test - 100 psi and it is good. They did a leak down test 100 in -90 hold and it is
I only use 10w30 in my shop, and also have you checked to see if they over filled the crankcase with oil. The dipstick must pe pushed or screwed all the way in to check the oil..
Nov 24, 2014 | Garden
Tecumseh will not start after replacing flywheel key. engine has good spark and is getting fuel
check compression. You have two parts of the engines operation triangle! The only thing left if timing is correct is compression.
Are you sure you got the right flywheel key? Some engines have stepped keys. Althought you would probably have backfire issues if the timing was off that much.
Get compression numbers! Good luck and be careful!
Sep 30, 2013 | Tecumseh 5hp Engine Snow King Mtd Blowers...
If I tilt engine side to side or front to back it smokes excessivly. Otherwise runs good no smoke
is the oil level overfull ?blueish smoke or the float level off and it's flooding black smoke blackish smoke
Apr 28, 2012 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Tecumseh ohh55 smoking/burning oil
http://www.repairclinic.com/Tecumseh-Small-Engine-Model-OHH5569024F-ID-806444-Parts
one of many suppliers on the web- lol
Jan 07, 2012 | Tecumseh Garden
Using ariens snowblower today, model# 924026 and heard a ping and everything stopped. Tecumseh engine model3 H80 155006. Some white smoke came out and some oil leaked down side of metal part that oil is...
Check your compression tecumseh's are known for the exhaust valve seat poping out of the head. If you have compression check the governor shaft it should only turn about a 1/4 turn.
Dec 18, 2010 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
I discovered I ran out of coolant after I saw my engine smoking... I put more in and still my engine is still smoking. White smoke. I am wondering why. It does smell like something is burning. Help!!! Is...
sounds like a Head Gasket or Cracked block or Head allowing coolant into the Engine Cylinder. Do a compression check. If you have Compression on 1, 2 or 3 cylinders that is higher than the rest, 20 to 30 lbs higher, it is most likely the head gasket. If you have high compression on 1 cylinder only then you need to look at the motor or head being cracked. If you purchased the vehicle from a dealer in the last 30 to 90 days, take it back to them and make them fix it.
Oct 14, 2010 | Audi A8 Cars & Trucks
Ford Thunderbird 96 V6 3.8 Idle rough, smokes like big Diesel motor
CHECK ENGINE COMPRESSION.SOUND LIKE YOU HAVE WORN ENGINE VALVES AND PISTON RINGS AND VALVE SEALS IF ENGINE SMOKING BLUE.IF YOU ARE GETTING HEAVY WHITE SMOKE.YOU HAVE A BLOWN HEAD GASKET.WHEN DOING COMPRESSION TEST IF COMPRESSION READINGS 90 - 80 WORN RINGS 60 - 40 BLOWED HEAD GASKET.
Aug 29, 2009 | 1996 Ford Thunderbird LX
Free advice on mechanic
on the cylinder head ,u must check for the oil seals on for the valve if one of the oil seal leaks engine oil will come to the compression chamber,this oil burn and make that white smoke
Aug 14, 2009 | 1990 Toyota 4Runner
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
