Question about Vivitar 283 Flash
Vivitar 283 flash
Dear Sir
Are these flashguns compatible for use on a Fujifilm FinePix S9600 digital Camera?
Regards Rob Hayes.
    Champion:
    Scholar:
  • 216 Answers
Please check the trigger voltage.
What, how do I do that, you said!!!!!!!!!?
Here they are:
1. Four fully charged or new batteries into 283.
2. You needs a DVM (Digital Volt Multimeter).
3. Set DVM: DC scale, higher than 10 scale.
4. Black Lead to black DVM and Red Lead to red DVM.
5. Turn ON the Vivitar 283 and wait until light turns Green.
6. Place Black Lead to Outside Silver Contact of the flash.
7. Place Red Lead to Center Silver Contact of the flash.
8. What is the voltage reading? Read the max. V.
9. Anything under 8VDC will be fine.
10. Some versions will be high.
Hope they are helpful to all photographers.
Truly,
Alexander
atdlee@netzero.com
Posted on Dec 13, 2007
How do i turn on the internal memeory on the S9600
the camera should automatically store onto the internal memory if there is no card inserted. if there is a memory card insterted it will automatically store onto that
Jul 01, 2013 | Olympus Fujifilm Finepix S9600 Digital...
Dear Sir, I own a FujiFilm S9600, I was using it perfectly fine with near to full charge of batteries. I clicked a few photographs in Afternoon and turned off the camera after that. When I tried to Turn...
Hello Nikhil!
It is clear your batteries are low. Recharge the batteries and try again.
If you find the batteries run out fast, that means you have used the batteries for a longer period and they cannot hold the charge much longer. Then it is time to replace the batteries.
In hot climates like in your country the batteries may run out slowly even when not in use.
Sep 05, 2011 | Fuji Finepix S9600 Digital Camera
I have fujifilm finepix s9600 and need the software to download photos. Can i download this from the net
when you connect your camera with the pc the camera will probably appear as a seperate drive on your computer. for example if you have a hard disk C: and a dvd driver named D: check to see if a new external disk appears as E: which will contain the folder of your pictures on your camera.
you can also check here
http://www.fujifilm.com/products/digital_cameras/s/finepix_s9600/index.html
Jan 23, 2010 | Fuji Finepix S9600 Digital Camera
Can the Vivitar 283 be used safely on Nikon Digital SLR Cameras?
I assume you're asking about the 283, not the DF-283 which is compatible with digital cameras.
As for the 283, yes, if you put an adapter such as the Wein Safe-Sync between the camera and the flash. Under no circumstances should the flash be mounted directly on the camera.
Nov 29, 2009 | Vivitar 283 Flash
Hi my name is Curtis can you tell me IF my Vivitar 283 flash will work on my c-750 Olympus, TTL camera it have an hot shoe,but flash don,t fire. I have talked to Olympus about it(on answer). I took it to a...
No the 283 is not compatible with your camera. The 283 is manual only and not TTl. The canon flash is also not compatible with your Olympus. You need an olympus compatible flash.
Nov 16, 2009 | Vivitar 283 Flash
Fujifilm s9600 cf memory card is not initialized wot can i do
If possible you can copy the directory with you pictures and clear it out the format the card and copy back the empty directory. I hope this works I need the directory for my card if it works post it..........
Jan 13, 2009 | Fuji Finepix S9600 Digital Camera
Vivitar 283 with new Nikon Digital camera
the nikon D80 has a 250 volts safe range and i have the same issue but readin on the internet i learned that yo can now the voltage of your flash with a voltage metter ond the hot soe.
Vivitar 283 has diferent ranges of voltages depending on the year of fabrication so older ones can achieve 300 volts and earlier have 230 volts so the best is to get a vivitar 285hv for about 75dollars or a safe sync for about 55dollars, you can find all on ebay or other brouser the safe sync converts up to 400 volts to a safe 6 volts that are yust the normal voltage for digital flashes.
Jan 06, 2009 | Vivitar 283 Flash
Flash Gun Broken can it be fixed
Buy distilled water.
Try to open the flash apart.
Pour distilled water to unit and blow dry or just set it near sunlight until dry.
atdlee@netzero.com
Jul 30, 2008 | Vivitar 283 Flash
Vivitar 283 Flash Logo
210 people viewed this question
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
