Question about Garden
Stihl trimer won't spool up. Aks like fuel problem, but line are good. Also has pre-ignitionwhen RPM's drop. Almost like it's out of time. How can you check the timing on these little gas engines?
  • 389 Answers
There is no way to set the timing. You can only check to see if the key is sheared under the flywheel but I do not think this is your problem.
Look at your muffler or more specifically the tube where the exhaust comes out. There will be one or two small screws holding it in place on the muffler. Remove the screws and pull off the spark arrestor screen under it. You will most likely find that it is blocked with carbon. Take a wire brush or flat screw driver or any other flat tool and scrape off all the carbon deposits until you can see clearly through the screen. Put it back together and your trimmer should be good as new
Posted on Sep 16, 2009
My 051 stihl has vaiable rpm at full throatle under a load...why?
possible water or dirt in the carby and main jet
could be a leak in the fuel pick up ;line from the tank or blocking of the fuel filter at the line end in the tank
go google and type in ---workshop manual for stihl 051 chainsaw and they have a good pdf version to down load
Mar 19, 2016 | Stihl Chain Saw 051 075 088 090 +
How do I get the old line trimmer spool off of my Ryobi 18 volt cordless trimer
When looking at the head, you will see to two gray rectangle pieces. Press them both at the same time between your thumb and forefinger and then pull. It should come unlatched and reveal the line spool on the inside
Jul 25, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
How do you know if knock sensor is bad
  • Knock sensors measure engine vibration caused by pre-ignition
  • When not replaced, vehicle may experience engine ping or knock, high emissions, poor fuel economy, internal engine damage and/or CEL/MIL illumination
Mar 25, 2013 | 1998 Nissan Sentra
Hey guys I have a stihl fs 85 r and I can't get
Hi Esh Weizman
Sounds like you have the fuel lines reversed going to and from the primer bulb.
I will put a picture up for you to see the routing of the fuel lines
Please take time to rate me
Bud
Oct 29, 2012 | Garden
I have a 026stihl that won't start
It would be a good idea to check the compression first to make sure there is enough to make the saw run. A person can run in circles trying to figure out an issue if the compression is below 100 psi, there should be about 150 psi. Older Stihl saws are also notorious for cracked fuel lines. Check the fuel line to be sure it is ok, also check the spark.
Aug 04, 2011 | Stihl Garden
Have a Stihl chainsaw (011). It dies out at a high rpm. I think I am sucking air from tank area because carb. is good, fuel is good, fuel lines are good at carb. I am looking for something to print out...
Replace the fuel cap. Check the fuel filter (inside the tank hanging on a length of fuel line) for plugging. Also check that length of fuel line for decay or other damage. Hope this helps!
Dec 03, 2010 | Garden
How to replace trimer line
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Oct 17, 2009 | Ryobi Garden
Stihl FS40 Runs for 60 secs at low RPM with the trigger fully depressed - then quits
had the same problem.
in the fuel tank is a gas filter and a fuel line. replace both.
the line gets soft with age and collapse and restricts fuel flow.
while u are at it replace the other two fuel lines as well. easy to get to when u have the cover off.
Aug 10, 2009 | Oregon Scientific Complete Carburetor for...
Describe string replacement on ryobi trimer
Wind the string on in a clockwise direction.
If it is a duel line then: Cut two separate pieces of string, about 7 ft. each.
Jim
Jun 24, 2009 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
