Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
"LF" Long Fill Fault Code on Whirlpool Cabiro HE Washer
About a month ago, I purchased a Whripool Cabiro HE Washer. I recently tried to run the "Clean with Affresh" Cycle and received the "LF" fault code about 5 minutes after the cycle started. Tried to clear it and restart, but no success. The "LF" code also came in when running the "Whitest Whites" cycle. All other cylces work fine. I contacted whrilpool and described my problem, explaining to them that water supply lines and discharge hose were fine. I checked these after reading about this fault code in the owners manual. Whirlpool's response was to check the water supply and drain line. There is nothing wrong with the water supply or drainline. Not sure if there is anything else I can do other than call a service repair person. Any ideas?
  • 318 Answers
The LF code is for long fill. it will happen if the washer fills for longer then 8 minutes and has not satisfied the pressure switch that the unit is full enough with water.
you might get this code from the unit not having enough water or if the drain hose is too far into the stand pipe or runs down hill into a floor drain.
check the drain hose and correct it if either of these are happening.
other wise check to see if you really do get enough water on the cold and the hot sides of your water supply.
Posted on Sep 15, 2009
    Top Expert:
  • Whirlpool Master
  • 75,814 Answers
There is an electronic timer, did they mention how long the fill should take on average and when the timer signals fill time exceeded?
Posted on Sep 11, 2009
  • jeannie canak
    jeannie canak May 16, 2014
    I've got a Whirlpool Cabrio, from day one I could never get enough water out of the machine, no matter the size load, to wash and rinse my clothes decently . I had a warranty so i called and made a complaint, the repair people put in a new mother board, that did not help one bit. the water level in my machine is much too little each and everytime and many people complain about this same issue, not just me. What a horrid product I purchased, not like I can drag it back to the store
  • yadayada
    yadayada May 16, 2014
    Make them fix it? Have a cheap Sears top loader that is 10 years old, never an issue of any kind, My advise these so called High efficiency washers are a scam to get your money.
Whirlpool LF code reset
The Long Fill code occurs when the washer takes more than ten minutes to fill. Although the replacement level sensor could be defective, it is more likely a control board defect because of the timed fill.
Feb 03, 2017 | Whirlpool Washing Machines
What is the LF Code my washer puts out
Hi Sherry,
The code definition for LF is a LONG Fill (F30). What does that mean is the next question? Here goes.
a. The fill hose may have a pinch or fold between the connections on the pressure in .
b. Are the hose screens plugged at the connections.
c. Is the water siphoning out of the drain hose ?
d. Is the water pressure at peak, check valve, filters before washer.
Now if your savvy hungry. Here is a learning curve link
Washing Machine Diagnostic Test Error Codes Cabrio Bravo Kenmore Oasis .
Okay. The next link is for the manual for your favorite machine. Manuals and Troubleshooting Whirlpool Whirlpool Cabrio Washer Fault Codes . I tried this and you need registration.
I decided to go one step further and track down a printable and savable resource for you. Yes, all, the fault codes and what they mean.
I did pretty good from memory but that link leads you to a printout you can keep right by your washer. Most of the occurrences are easy to fix without a technician. Hope this makes your day. Better. Fare. Well.
Jun 20, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio washer starts to fill and then quits almost immediately and then the LF code comes on. I have run the automatic diagnostic test and the water inlet valve seems to work fine. During test...
Try cleaning your inlet valve filters. Turn off your water supply and remove the hoses from the washer. The filter screens are located just inside of the valves. Just twist them out, clean, and reinstall.
Good luck.
May 06, 2011 | Whirlpool Washing Machines
Whirlpool Duet was purchased December 2009 and lately has a strong odor. Does this front loader have a filter we can clean? Please advise how to get rid of this ongoing odor.
There is no filter but you might want to remove the bottom front cover and clean out the sump filter(a large white thumb screw attached to pump) turn to the left. After cleaning this out get a product called Affresh available at grocery and other stores. Put your unit on a clean cycle. If you can't find affresh try a cup of bleach and run that through a clean cycle. Another tip leave your door open when not in use
Feb 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
About one minute after starting machine (Whirlpool Duet WFW9600T01) the machine flashes "SUDS" for a couple minute or so, then the machine locks up with the F35 code. The only way to open the...
this is a suds lock and a very nightmare of a call....... are you using high effeciency soap and do you ever run a clean cycle ....... i prefer an affresh cleaning tablet once a month...... first things first need to drain all water out of washer threw drain hose connected to drain pump .... then check for any float obstructions at bottom of outer tub to drain pump large 4 inch ruber hose at bottom of tub with a plastic ball in it make sure there isnt any lint causing float ball not to seal in pump vacum... then reinstall and reconnect hoses then check pump filter sump trap for debris and reinstalll next open washer and install an affresh cleaning tablet and select hotest water cycle or clean cycle if washer is equipped with this feature and close door and let washer run ...m if code comes back you make have to repeat draining and pump steps a COUPLE OF TIMES TO REMOVE EXCESS SOAP BUILDUP..,. CAUSIN SUDS ERROR LOCK CODE.....
Jan 24, 2011 | Washing Machines
How to get rid of the stale smell from the atf8000 front loader washing machine
first things first we need to purchase a cleaning tablet from local grocery store called affresh tablets in your laundry detergent aisle ,
then clean out filter sump assymbly in bottom corner of washer som washers have an axcess panel in the bottom righ or left hand corber uncrew filter cap and drain in to bucket or a shop vac .
clean debris out of filter and reinstall the filter screw cap in tightly ..
check your console for a clean cycle option in your wash cycles an select put one affresh tablet inside of washer drum and run cycle..
if you dont have a clean cycle thats ok select your hotest water wash cycle or sanitary cycle put one affresh tablet inside washer drum and run cycle ...
after cycle completes always leave waher door cracked open when washer is not in use ,,, reccomend running an affresh cycle once every month or if u notice stagnant water smell the more often you wash with hot water the less chances of smell
My clothes smell as if the washer uses recycled water.
Purchase Affresh, Place 2 Tabs into your washer and run through a cycle. This will keep your washer smelling fresh. Do this every 2 or 3 months, or you can have the boot replaced.
Sep 19, 2010 | GE WBVH6240F Front Load Washer
Clothes stink
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
May 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool cabrio washer that displays LF when I try to start a wash load. The water comes into the tub but it doesn't fill. After some time, maybe 10 minutes, the washer stops and displays LF....
Aha the old LF : Captain we have a problem. What is it Spock? Computers cannot confirm water is filling, water level does not change. Spock you did pay the water bill this month? What could it be Spock? Captain the inlet screens appear to have contaminants. Suggest you jettison them. If that does not solve it see test #2b7fe528.jpg
May 15, 2010 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
Code lf keeps popping up
lf code means long fill. If the water fill time exceeds 10 minutes, the water valves are turned off and lf is flashed. Press STOP/CANCEL to clear the display.
Mar 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
1,027 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
