Question about Karcher 2500 PSI Pressure Washer
I temporarily misplaced (not lost for good) the owners manual for my honda pressure washer : engine and pump. I do not want to run my machine again until I verify the pump oil content/level. On the pump itself, at the top, there is a black, unscrewable oil cap, with blue-ish oil in it, BUT NO DIP STICK! How do I check the level? What kind of oil, specs etc? Thanks!
Calve gap on a Honda GX390 engine? Hi, I have a gas power washer with a Honda GX390 engine in it. I need to adjust the valves. Any idea what the gaps are supposed to be? Also do I adjust on a cold engine...
Hi intake is 0.15+ or - 0.02mm and exhaust is 0.20 + or- 0.02mm cold engine..I always double check after running the engine again...you can check out the owners and service manual and all specs here http://cdn.powerequipment.honda.com/engines/pdf/manuals/37Z5F602.pdf
Feb 23, 2015 | Honda Garden
Husky 2600 pressure washer with honda gcv160 engine. engine won't run with choke off.
I bought mine at Home Depot, the pump failed after about 8 hours of use then Home Depot agreed to replace it now it failed again after aabout 10 hours of use. This is a piece of crap and Home Depot should be ashamed for selling this junk. I am sure they are in with Husky and making big dollars on a crappy product. My machine is like brand new just will not work. Now the carb has to be replaced only after less than 20 hours.
JUNK Home Depot
Nov 23, 2011 | Garden
The pressure washer will run for a few seconds with good water pressure,then something in the pump causes the engine to shut off and all pressure is lost. Trying to restart the engine is almost...
Most likely you are haveing a problem with the water valves inside of the pump. Honda does not make pumps they make the engines and if you have a honda engine its the best engine for powerwashers . S o what you need to do is look at the pump and see who made the thing . If its a simpsion or a cat pump these bolth are vary good pumps . It could be a miti m pump there ok but tend to have problems with the valveing . The kits are cheap enough for all of them about 60 or 70 dollars . So let me know how many horse power the engine is and what kind of pump you have and the gal pr munite aswell as the max pressure out put of the mechine how old is it and ware did you buy it Most of this information will be on a metal tag on the water pump or the frame of the mechine. A nd i'll tell you if its worth saveing Pier_j
Mar 07, 2011 | Honda Garden
Pressure stops and starts intermittently
<span class="Apple-style-span" style="font-family: Arial, Helvetica, sans-serif; font-size: 14px; line-height: 18px; ">With the engine turned off, pour liquid TSP into the fresh water inlet until it comes out the other end at first just water that is already within the pump will come out but make sure you put enough TSP that it starts to come out the wand outlet. Then, let it sit for 48 hours and don't run it at all. This is how I fixed my no pressure problem tomsimmonds@yahoo.ca owner of Honda 5.5 with Comet pressure washer pump</span>
Aug 16, 2010 | Honda Pressure Washer PSI 3000
What type of oil is needed for a Honda GC160 Power Washer? Honda 2500 PSI x 2.3 GPM.
The type of oil recommended for that engine is SAE 10W-30 and the capacity is 0.61 quarts. This and more can be referenced at the website at the end of this solution. I was able to find the owners manual of your particular engine.
http://www.northerntool.com/downloads/manuals/60594.pdf?cm_re=Product%20Page-_-Manual-_-Side
May 27, 2010 | Honda Pressure Washer PSI 3000
Pump burned up?
The unit does not have auto shut off? Anyhow try to take out the oil and flush it by running good oil in and let it out again…then put oil and first see if you can turn it manually few turns and see if you hear any sound…then try to start it and see…let me know
Please do not forget to rate my service for the site to continue helping everyone and improve on it.
Sep 17, 2009 | Honda Pressure Washer PSI 3000
I'm trying to find out how much oil should be in the water pump of a honda pressure washer model xr2750-1
it's an ex-cell pressure washer with a honda motor.
engine oil capicity: 0.61 qts(.58L)
view owner manual here:
http://www.excellpressurewasher.com/documents/pdf/a12338-e.pdf
Mar 10, 2009 | Honda Garden
Karcher 2500 PSI Pressure Washer Logo
580 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
