I need to set up the option to boot from two different hard drives. Both of the hard drives have Windows XP Home SP3. I would prefer thatr someone logs in on that computer and does it for me
  • 298 Answers
No ones will be able to login and set that up for you on here, you can google "dual booting" and their is many guides out on the web for this. I still refrer to them myself sometimes and I've done it probably 2 dozen times.
The easiest way is to just install each OS to it's own drive, the second install on the second drive will reconfigure the bootloader itself.
after it finishes the instalation it will give you an option dialog box for 30 seconds before windows to select which OS you want to boot up.
Also if your bios has a boot option menu you can manually select each drive by entering that menu each time you boot up. That will allow you to have both installations as C: rather than 1 being C: and the seconds as D:
just plug in only the drive you want windows on during that install and then unplug it and plug in the 2nd drive and install to that one. Make sure the PC is powered off during the drive switches though.
After this is finished connect both drives back up and power on, enter the boot menu and choose which drive to boot from. Simple. but your bios has to support this.
Posted on Sep 11, 2009
Windows xp cd with sp3 installation
In BIOS change the boot order such that CD/DVD comes first. You will also need to make sure your hard drive runs in IDE mode since Windows XP doesn't support sata drives by default. FYI XP is going end of life early 2014.
May 20, 2013 | Microsoft Windows XP Home Edition
Windows XP sp3 not booting Error system halted
Is your First Boot Device in BIOS is Set to Hard Drive? IF not then Just Change it Hard Drive.
Aug 11, 2012 | Intel Computers & Internet
Windows xp home edition boot process will not recognise a dvd player but the dvd is readily useful after bootup this also applies to usb dvd players the PC is a Dell that has just been updated with SP2...
If you are using IDE drives (ribbon cable), then the most likely culprit is that the hard drive is set to something other than master and the DVDROM is set to something other than slave. Based on what you have described, I am pretty confident that it is a jumper setting issue on your hard drive/DVDROM.
Apr 24, 2011 | Microsoft Windows XP Home Edition
How to reformat the computer?
To reformat the windows vista.There are two options to approach the reformat:
  • Option #1: Boot from the Windows Vista DVD. This is more complicated to do, but it destroys all data and partitions.
  • Option #2: Re-install Vista without leaving the desktop. This preserves the previous installation in a folder called Windows.old. Not all info is wiped, however, and you can't destroy your partitions.
First, restart your system. When the computer starts to boot, look for an option before you get to the Windows screen that reads: “Setup” “CMOS,” or “Bios”. This varies between manufacturers. For example, on the boot screen, it says:
“F2 =Setup”.
The option will flash by quickly so be ready for it and react quickly. You may need to reboot a few times to catch it.
Once in the BIOS, look for a setting that says "Boot" or "Boot Sequence". You might have to dig through the menus with your keyboard’s arrow keys to locate the setting. In the listed as Boot Sequence. And to navigate to Startup, then Boot, and then Boot Priority Setting.
When you find the setting, change your DVD drive so that it occupies the top of the list. The hard drive that contains Windows Vista should be listed as second in the boot list.
And put the Windows Vista installation disc in the designated drive. Now, select the Save Changes and Exit option in the BIOS. The computer will restart and will attempt to read the optical drive you just assigned as the first bootable drive.
The system will use the Windows Vista disc to boot and the reformat and reinstall process will start. But You will need to reinstall any programs that are not bundled with Windows Vista and reinstate your preferences and personal files after reformatting the computer and reinstalling Vista.
Windows Vista Home Premium Edition upgrade Click here.This downloadable version of Windows Vista is an upgrade only. Users can upgrade to Windows Vista Home Premium from Windows XP Home or Windows Media Center edition.
All the Best!
Sep 05, 2010 | Microsoft Windows Vista Home Premium...
How to set up dual boot for two hard drives?
My freind, you can boot from two hdd inside the same computer. You can only boot from the primary HDD. What you need to do is install both Windows 7 and XP on the primary hdd in different partitions. Then when you boot the system it will give you the option for booting to both XP and 7. You dont even need the secondary hdd unless you are looking to have more storage space.
May 04, 2010 | Computers & Internet
I HAVE DEMO VERSION FOR ONE MONTHSOF VISTA HOME BASIC NOW MY LAPTOP NOT STARTING IT REQUIRED PRODUCT KEY
The demo version was set to expire quite some time ago... Either format the system installing a new operating system or buy a registration key for Windows Vista. If you've got it, I would install Windows XP Professional (SP3 is preferred). If you do not currently have an operating installer disk, you can download some free ones such as these:
Linux Mint
Ubuntu
Fedora
As mentioned, they are completely free and do not require you to register them. To install them you will need to have a CD (or CD/DVD) burner. Afterward download the .iso image to the computer with the CD/DVD burner. Then use a program such as ImgBurn to burn the image to the disk. Once done, stick the disk into the CD/DVD drive of the computer with the Vista installation. Then start the computer and use the boot option to boot from the CD/DVD disk (Generally a message during startup will read similar to "Press F12 for boot options." Press the key associated with the message continually (in this case, F12) to bring up the boot selection screen). Sometimes you will be asked to press any key to continue booting from the CD. As it said, press any key and you will boot from the CD.
Hopefully you will be able to resolve your problem. Just remember, installing a new operating system will erase ALL data on the hard-drive. So if you have precious files on the hard-drive, I would not recommend installing a new operating system.
Let us know how things turn out, or if you require any further assistance.
Jan 05, 2010 | Microsoft Windows? Vista Home Basic...
Windows XP Home Not Booting
For that you need to recover error on hard drive then you can see repair option.
For that insert windows disk or recovery disk in cd/dvd rom.
Then boot your computer with it set first boot device as cd/dvd rom in bios.
Then follow the procedure select "R" for recovery console.
Then type in prompt "chkdsk /r" then press "y"
then it fix error on hard drive.
Then restart computer then it search the previous windows then you can see "r" for repair previous windows.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 07, 2009 | Microsoft Windows XP Home Edition
My computer only boots successfully after a forced shutdown.
Is it possible that you have installed winxp twice? You say that you installed XP Pro sp3 was that an upgrade from xp home? if so then you will need to uninstall one or both versions of XP then install only one.. Make sure you backup any important files first though
May 22, 2009 | Microsoft Windows XP Professional SP3 Full...
Hard drive crash, not usable at all; downloaded xp drivers and computer drivers but cannot get them installed. Hard drive not recognized.
When you install a new harddrive, it has no Operating System on it.
Windows XP and Windows Vista, are examples of an Operating System.
Each laptop manufacturer, has their own system of changing a laptop harddrive. Some allow you to press a key or two, to put the laptop in a state where it will save the basic Operating System files, and when you install the new harddrive, it will transfer them over to it.
Some laptop manufacturers do have this option.
You either have to take the harddrive out, install it into an external enclosure for a harddrive, (Uses a USB cable) Then attach the external enclosure via the USB cable, to another computer, and use a 'mirror' imaging program to save the Operating System to that computer.
Then the new harddrive is installed in that external enclosure, and the Operating System is 'mirrored' over to it.
Just information for you, as you cannot do this now with a crashed harddrive.
Your option now, is to buy a genuine copy of the Operating System you had on the laptop, and install it.
Not what you wanted to hear, huh?
You need to buy whatever version of Windows XP it had, (WinXP Home or WinXP Pro), or Windows Vista.
If it was Windows Vista, I suggest getting at least the Windows Vista Home Premium version.
I personally prefer Xp over Vista.
Tigerdirect.com, and Newegg.com, have these.
Look for Software>Operating Systems.
OR, you can simply put Ubuntu Linux on it for free.
Apr 16, 2009 | Toshiba Satellite P25-S5263 Notebook
Dell xps 600 windows booting problem
You would probably do right to reinstall Windows. The bios handed off to Windows long before the splash screen comes up. It is probably a faulty driver or corrupt registry entry. If it was me I would reload Windows
Dec 01, 2008 | Dell XPS™ 600 PC Desktop
k24674
jasbo
jasbo
