Question about Samsung CLP-600N Laser Printer
Samsung CLP-600N power up issue
We have a Samsung CLP-600N and have had many different issues with it. Today it will not power up. We've checked that plug to machine and outlet are secure and power switch is on. Any thoughts as to what else it could be?
My samsung clp-600n laser printer is missing the network menu, how do i find it when the menu goes from setup to information and not network!
Go to Samsung Download page and read the manual. See also the Software tab on the same page and install the appropriate SyncThru soft for your operating system. Dan
Sep 20, 2011 | Samsung CLP-600N Laser Printer
Samsung CLP-600N displays message - engine fuser low heat error. Machine is out of warranty.
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Aug 10, 2010 | Samsung CLP-600N Laser Printer
When I turn on my Samsung CLP-600N laser printer, I just get a clicking noise. When I turn it off, it continues to click for a minute or two and then stops. The lights do not go on.
it sounds like a faulty power supply, when you apply power it charges the capacitors in the psu but as it is faulty is unstable hence the clicking, it continues as the capacitor discharge until all power drains
Apr 20, 2010 | Samsung CLP-600N Laser Printer
Printer will not power up.
If the Printer does not power up, and you tried another outlet and power cord, the problem lies with the power supply in the printer. Unit will need to be taken in for repair.
thanks adi
Dec 12, 2009 | Samsung CLP-600N Laser Printer
Engine Fuser Low Heat Error on Samsung CLP-600N? What can I do?
i have samsung laserprinter 1610 problom low heat error ple telme anw
ser
Oct 05, 2009 | Samsung CLP-600N Laser Printer
Invalid transfer belt error on Samaung CLP 600N
This error can arise when the door on the right-hand side of the printer, the part you open in order to replace the toner cartridges, is not correctly closed. Close the top right-hand section first and then close the door on the right-hand side firmly (slamming it if necessary) and then check that all edges look correctly aligned. That should solve the problem. Incorrect shutting of these parts has always been the cause of this error on our Samsung CLP-600N laser printers and we have several of them.
Mar 23, 2009 | Samsung CLP-600N Laser Printer
Samsung CLP-600N
The SMPS Fan Error is caused by slow or no rotation of the SMPS Fan. The firmware solution from Samsung disables monitoring so if the fan stops the printer will keep working. Thankfully, it's not physically hard to fix this issue though and can be done by removing 9 screws and using a little oil.
I've actually posted a step by step guide to fix this here.
Jul 26, 2008 | Samsung CLP-600N Laser Printer
Samsung clp-600N
remove power for 5 min and plug back in
Dec 03, 2007 | Samsung CLP-600N Laser Printer
Samsung CLP-600N Laser Printer Logo
205 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
