My OS drive is always running short of space. i've dedicated a 12 gb partition for my os drive. this problem prevents me from using my com properly.i cannot download an install even small programmes, not even updates for my antivirus. how can i possibly solve this problem? can this be due to some virus infestation?
  • 55 Answers
This is nota virus infection, you merely don't have spce to download or install programs or updates. This solution would be to install on a larger partition. If you want to keep your files and settings, get a USB flash drive and use Documents and Settings transfer to save your files and settings. If you want to keep all your programs too, do a full windows backup onto an external hard drive or the sort. Thenafter reinstalling your os on a larger partition, restore your compter from the backup or the fDocument and Setting tranfer. Hope this helps. Good luck!
Posted on Sep 12, 2009
  • 66 Answers
Assuming you're running Windows, a 12G partition is not really large enough as you already found out. It may be large enough for the operating system itself but not much else. Most likely, your temporary internet files, recycle bin and other "stuff" are also on that drive. One thing you can try is the Disk Cleanup tool. On XP go to Start / All Programs / Accessories / System Tools / Disk Cleanup. The default options are usually good but check them carefully. Also, don't compress old files. That can make your system run slower. You should be able to free up enough space to download your antivirus updates. Consider this a first step - you should investigate a larger partition for your OS. Make sure temorary files, program installs, etc. are going to a different drive and you should be cleaning up OS updates and removing programs that you are not using.
Posted on Sep 11, 2009
Connot select, create, or delete partitions through diskpart.
If you want to create a new partition, there must be enough free space to put it. If the whole of the flash drive has been formatted, you cannot add a partition to no free space. Most flash drives will not accept more than one partition.
Mar 07, 2014 | Fujifilm 32 GB USB 2.0 Flash Drive
Tip
How to Install 2 or more Operating Systems on your Computer
You will need to make sure your hard drive is large enough to accommodate the space requirements of both operating systems, plus enough room to install software and store files for each perating system. Personally, I do not recommend attempting this on drives of less than 50GB with Windows operating systems XP and later. You will first need to optimize the existing installation to reduce and condense your total disk space. To do this you can run the following utilities on your existing installation: create a restore point then, run a registry cleaner (Ccleaner is reliable and free), registry defrag, system cleaner (Trial versions of Yacimsoft Optimizers or Glary Utilities are fully functional free downloads which will give you all the tools needed to achieve these functions), uninstall any program files you do not use . . . then perform a complete disk defrag once all junk files, temp files, old document files etc have been deleted and removed from the recycle bin . . . then reboot the computer.
To perform the disk partition inside Windows XP and later, make sure you are logged on to a user account with full administrator privileges., then click on start and RIGHT click on My Computer (WinXP) or Computer (Vista and 7) on the start menu and select “Manage” this will invoke the “Computer Management Console. In the far left column find and select “Disk Management” This will open the Windows utility to create disk partitions.Your primary Hard Drive will be labeled “Disc 0” and display information about the size of your drive. Newer laptops and desktops may already show multiple partitions setup by the manufacturer which are used to restore your original factory settings – DO NOT DELETE OR TAMPER WITH THESE OR YOU WILL LOSE YOUR ABILITY TO RECOVER YOUR ORIGINAL OPERATING SYSTEM IN THE EVENT YOUR OPERATING SYSTEM BECOMES UNUSABLE.
Find the rectangular section of the Hard Drive Graphic which bears the word BOOT Right click, Select “SHRINK VOLUME”. A new window will appear with minimum number of megabytes the drive can be. You will NOT want to use the minimum number. If you do, you will be creating a partition only big enough to accommodate your current data. There will be little or no room to add additional programs or save files. What you will instead need to do is look at the total capacity, then calculate how much additional space you want to allocate to your original Windows installation with enough remaining space to install the secondary operating system.
Lets pretend the original OS is any flavor of VISTA and you are planning to install Windows XP SP3 on your new partition . Your HDD is 60 GB (this will be shown in MB units which will be a 5 digit number for drives less than 100 GB and a 6 digit number for drives over 100 GB total capacity).
Note: HDD capacity calculations are not exact. Do not be surprised if your 60GB drive actually only shows a “Total Size Before Shrink” of 58777 megabytes or some other number less than 60000 as you might expect. This is an industry norm. The true capacity is rounded up to the nearest GB even though the actual capacity may be slightly less.
In this scenario the Disk Management utility informs you the minimum size you can shrink your Vista volume to is 22497 megabytes. You want more room for downloads and stuff you add later. The total capacity you need for your XP installation and other files you decide will be 20 GB. This leaves approximately 20GB of space you can apply to the Vista partition. Therefore you will enter a number something like 44000 in the Shrink window field labeled: Enter the amount of space to shrink in MB. Now click the “Shrink” button. The operation will take several minutes to complete. Once the Shrink has completed successfully, reboot the system to make sure your original OS is operational and the computer boots without any issue. Then return toDisk Management You shoulod now see your Vista volume and a second area of Unallocated Space.
Right click in the unallocated space, select “New Simple Volume” This will begin the Simple Volume Wizard. Click Next. Use the maximum size indicated & click “Next”
In the next menu select “DO NOT ASSIGN A DRIVE LETTER OR PATH. Format the new partition to NTFS.Click “Finish”
Return to the Disk Management utility & you will see the new partition. When the format is complete, right click on the new partition and select “change drive letter” use the default drive letter suggested.
Insert your XP Installation CD into your DVD/CD and run SETUP within Vista and select the option to install a copy of XP on this machine.Select the empty new partition you created for XP and follow the installation instructions.
Vista Boot Loader will detect the XP installation and prompt at startup which OS you wish to boot. You now have 2 separate options for which operating you want to run on your computer.
DO NOT ATTEMPT TO RUN PROGRAMS INSTALLED ON ONE OS IN THE 2ND OS. YOU WILL NEED TO INSTALL ANY PROGRAMS YOU HAD INSTALLED ON YOUR ORIGINAL OPERATING SYSTEM SEPARATE INSTALLATION IN THE NEW OS. ALWAYS SAVE PROPRIETARY FILES AND BACKUPS TO THE CORRECT PARTITION CONTAINING THE OPERATING SYSTEM WHERE CREATED.
EXCEPTIONS ARE: MOST STANDARD MEDIA AND DOCUMENT FILE FORMATS – mp3, .doc, .pdf, .jpeg etc. These files are universal and can be accessed from either OS by pointing their opening application to their location on any logical drive.
My Next How-To will be PART 2, Installing multiple Operating Systems on a Clean Unformatted Drive.
Please send any feedback or questions to GeekMaker@hotmail.com
Colt Baldwin – FixYa.com Computer Technology Support Expert.
on Apr 10, 2010 | Computers & Internet
I have had an Evesham PC desktop computer since 2002. I use Windows XP. Is there any possibility of downloading Windows 8? Annie
You might need to upgrade a few hardware items first also you might upgrade to vista then windows 8
Creating a new partition on your hard drive gives your future version of Windows 8 a place to live on your drive.
Knowing exactly how much space the OS requires helps you determine how large to make your partition.
Size requirements don't tell the entire story on their own, though.
Other factors like drive type and additional storage help ensure you get the best Windows 8 experience where your hard drive is concerned.
Size Requirements
Both Windows 7 and Windows 8 have the same system requirement regarding hard drive space, so if your hard drive can handle Windows 7, Windows 8 shouldn't be a problem.
For 32-bit versions of the operating system, you'll need at least 16 GB of available disk space. The 64-bit version requires 20 GB.
Your partition will have to be at least one of these sizes, depending on your OS version.
The PC Advisor website warns that these are literally the bare minimum requirements, and using these figures leaves you hardly any space to save files and install apps or programs.
Size Recommendations
You'll get more out of Windows 8 if the operating system has enough free space for you to install your favorite programs and apps.
PC World calls this extra space "breathing room," suggesting you give your Windows 8 partition at least 30 to 40 GB.
If you're dual-booting with another operating system or you're accustomed to keeping excess data on a separate partition, 30 to 40 gigabytes should be fine.
If you'd rather have all your songs, videos and PC games on the same partition as the operating system, consider giving it substantially more space.
Solid State Drive
Windows 8 works on traditional hard drives with spinning disks, but it's optimized to run on a solid state drive.
If you've got an SSD, consider putting your Windows 8 partition on that drive.
While any operating system benefits from the speed increase an SSD brings, ARS Technica specifically recommends this drive type for Windows 8, saying the operating system's "tablet-esque feel and search-heavy usage model will be much better served by solid-state storage."
Other Requirements
Hard drive space is a crucial system requirement, but others are just as important.
Ensuring your computer meets the other requirements before partitioning your drive for Windows 8 saves trouble in case your computer can't handle the OS.
You'll need at least a 1 GHz processor that support PAE, SSE2 and NX.
Your computer has to have at least 1 GB of RAM for 32-bit Windows 8, or 2 GB for 64-bit.
Your graphics card must be at least a DirectX 9-capable card with a WDDM driver. Also, while you're formatting your drive, format the Windows 8 partition in the NTFS format.
Storage Spaces
Storage Spaces is a useful Windows 8 feature when you're working with multiple drives and partitions.
The tool enables you to group drives into one larger storage space so you don't have to constantly switch partitions and explore different drives.
For example, if you create a storage space between two 32 GB flash drives, you'd be able to access it as if it were one larger 64 GB drive.
http://windows.microsoft.com/en-us/windows-8/system-requirements
Microsoft windows 8 system requirements
http://www.pcadvisor.co.uk/features/windows/3358892/windows-8-system-requirements/
PC World windows 8 system requirements
http://www.pcworld.com/article/2012847/how-to-master-storage-spaces-in-windows-8.html
PC World how to master storage space windows 8
http://windows.microsoft.com/en-US/windows/download-shop
Sep 11, 2013 | Evesham Computers & Internet
How do i use my second partition of my hard drive? my laptop is a dell vostro 1088. It seems that my OS (C:) is full but i see that i have a new volume(F:) so how do i use that? Originally, my laptop...
http://www.filehoo.com/download/Partition-Magic-8,0.aspx when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition Partition Magic 8.0 description
Partitioning your hard drive plays an essential role in maintaining your computer-preventing conflicts, protecting data, improving efficiency, and increasing performance.
PartitionMagic allows you to create, resize, merge and convert partitions without destroying data. Award-winning PartitionMagic Pro from Symantec is a leader in hard-drive partitioning software. PartitionMagic Pro allows you to create, resize, move, and convert partitions without destroying your data. You can quickly and easily create partitions, which can act as file drawers on your hard disks for storing valuable information such as data files, applications, and operating systems. Storing information in separate partitions helps you organize and protect your data, safely run multiple operating systems, and reclaim wasted disk space.
hope this helps
Apr 23, 2011 | SIB 320GB 5400RPM 8MB Cache SATA Hard Disk...
Hi, I am owning a dell inspiron 1525 for the last 3 years now. Few days ago when i was formatting my laptop to install a new OS, i accidentally deleted a partition and it became unallocated. My hard disk...
Startup from the windows 7 disk as if you were going to reinstall. Choose 'advanced' in the section where you sort out the disk to install to, and partition the unallocated space. Then exit out, do not continue to the format and install stage.
Once you have restarted into your original windows, you can format the new partition as normal.
Having said that, 10gb is pretty small for an OS partition, 15 0r 20gigs would be better and you can swap some space from your new partition to the OS partition. There are plenty of tools you can use to do this with at www.download.com.
Aug 29, 2010 | Dell Inspiron 1525 Notebook
I cloned a hard drive which was 30gb onto my orignal hard drive which 160 gb now my original hard drive thinks its only 30gb. But the bios system says 160gb how do I repair that?
Hi. What OS are you using? The un-recognize space can be recovered by adding partition to the harddisk. If you are using Windows, you can see the empty space in disk management.
Let me know if you need help with disk partitioning and what OS you are using so I can write specific solution. Thanks.
Jul 15, 2010 | Computers & Internet
How to make partition in a new seagate freeagent Go 320 GB
Here is a link to Microsoft on how to get to and use disk management. I do not know what operating system you are using but disk management has not changed a lot. The link below references XP and if you follow this step by step it will work great.
http://support.microsoft.com/kb/309000
Mar 10, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Recoverying the Vista
Well, I had the same exact stupid mistake, also on a Lenovo laptop, but a different model. Anyhow, Windows does not allow partitioning the drive which the OS is located on. It spoils the whole installation and damages the OS usually beyond repair.
I would advise you to do what I did- I tried to gracefully surpass the problem by restoring the windows but nothing happened. So, what I simply did was to format the whole computer and then divided the drive into C and D and installed Linux on one partition (all you need is about 10GB, and that's also a lot) and on the second partition I've installed the Windows OS. Good luck with that...
Nov 01, 2009 | Computers & Internet
My sp0411n my hard disk of capacity 40gb it is showing 5gb space my know reason why it is showing 5 gb space
hi first off what OS (operating system) is installed. Did you install that OS?
If the answer is yes ,did you format and partition your hdd or did you format and create separate partitions and left atleast 30 gb unpartition
Feb 27, 2009 | Samsung (SP0411N) 40 GB Hard Drive
"-36" error message using Acomdata External Hard Drive
Have you tried taking the files off of the drive and repartitioning and reformatting the drive?
How is the drive formatted? Fat? Fat32 or HPFS? What version of Mac OS are you running? It is possible, depending on the version of the OS and the driver for the OS that it can have problems with drives that have partitions larger than 128 GB. It is also a bios limitation with older systems.
Look to see if there is an updated driver for the OS X version you are running.
Also check in the Disk Utility to see how the drive is partitioned and formatted. If it is going to be a Mac only drive, partition and format it as HPFS. If it is a drive that you will use in Windows as well, use Fat 32 and limit the partitions to 128 GB or less.
You could also try a newer version of OS X like Tiger or Leopard. They are both more stable than older versions and have better support for devices.
Cheers and good luck.
Best
Dec 27, 2008 | Computers & Internet
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
