Question about Sony Network Walkman NW-A1200 MP3 Player
Wet through I dropped mine into a bucket of water. it won't turn on now. Is this the end?
  • youngercobb Dec 24, 2007
    Well I dried it out for about a week then tried turning it on. It doesn't turn on but now if i plug it into the usb the player gets warm but no turn on.
    An expert whose answer gotĀ voted for 100 times.
  • 108 Answers
It depends upon the chasis. if it is immersed for a while then the circuits present inside the player might get short circuited. then it can be never turned back on. there are many ways to save the device when it is dropped into the water, Remove the batterys as soon as possible.
Posted on Dec 20, 2007
id ck the drain hose connection for build up of fouling material , the symptom you describe usually occurs when the hose cant drain all the water the machine makes
a wet/dry vac is perfect for this (set to wet) and some even allow you to turn airflow around to blow air as well , this is perfect to clear a stopped up hose (point end into bucket)
Nov 28, 2015 | Dehumidifiers
AQXGD Hotpoint front loader. Won't unlock. Says f5 on display and that washing machine is blocked. Has now unlocked itself and I've taken washing out, but lots of water at bottom. Closed door and...
Hi I hope the picture below helps, I can help you further with this as I have found that mine was a 5p blocking my pump fan at the bottom behind the lower front cover, I can talk you through how to do that, but it does involve unplugging the washer firstly, then using a sponge & bucket to remove as much water from the drum as possible & then tipping back machine & propping it up under with a strong solid object that can hold its weight for a while, but then slide a good solid tray under to catch the excess water & an old towel or rags near by for any splashes, then by undoing the front lower flap with a butter knife there are lugs about an inch in from each end, gently pop them down carefully & remove white cover, then by twisting the grey circle cap that is at the front of the pump fan, this can be hard to turn, but follow the arrows, I have had to turn mine using pliers before, turn this slowly because water will come out & it will be fast if you turn it to quickly soaking the floor, once removed look & see what is obstructing the pump fan blades, maybe a hair clip or a coin or limescale & hair etc, give it a good sweep around & rotate the fan blades & inspect closely with a torch to see any minor scratches or damage the fan, this may indicate the item is blocking something or if it's gone the other side of the fan or not, once this has been cleared & rotates & the filter if there is one has been cleaned & replaced back then reassemble it all together & then resit the machine, please leave & allow it to settle for a few mins to be sure that there is no leaks from the area you opened (sometimes a few drops as the water tipped backed wards will rush forwards & then it will be resealed, after a 5-10 min wait plug the washer back in, set it to the pump out & spin programme & this should clear the problem, it did with mine last summer... I hope this solves the problem..
I did add a picture from their website depicting what the error code is trying to indicate to you, but you probably have already looked for this already, Hope this helps....
Feb 08, 2018 | Hotpoint Washing Machines
GE front load waher Model #: WSSH300GWW fills and agitates, but does not spin and drain.
take drain hose and lay it in a bucket to drain water or a wet vac works better. remove 2 scews from lower pannel it will drop down and come off. look for a accordian shaped black hose. disconnect it and remove junk in it. check inside the pump inlet for stuff it's the thing one end of the funny hose is hooked to. put back together and don't over tighten clamps nut driver tight is fine.
Feb 17, 2010 | GE Washing Machines
I have the same problem!!!! I just dropped mine 2 hours ago!!
Jun 04, 2009 | LG Vu CU920 Cellular Phone
APE08AK GE Portable Room Air Conditioner isn't draining
I had the same problem and unscrewed and removed the back cover (AFTER I UNPLUGED THE UNIT) and noticed there is a small black tube that the drain tube connects to. Mine was broken off track and I had to physically remove the small black tube, put it back in it's place and super glued new tabs along the side so it would tilk back and drain the water in the bucket vs. the floor via the unit.
Hope this helps.
May 25, 2008 | GE APH10AA Air Conditioner
No water in bucket
possible that the cooling fins have frosted over...this happens when a cold surface appears in a humid room that does not have enough heat to prevent the freeze-up on the fins. If you look at the fins (above the water bucket), you may see the frost. One solution is to turn up heat in room, followed by placing a fan to blow air through fins if still frosted. If you do not have a frost problem, then ensure compressor is running. If comp is running, then return dead unit.
Feb 16, 2008 | Kenmore 53301 Dehumidifier
Motorola RAZR V3m Cellular dipped in water not on
WOW.... this is a hard one. Cell phone fails in a bucket of water... the solution... buy a new cellphone... and sell your bucket of water...
P.S. everything inside the phone burnt to pieces... game over
Dec 03, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Camera dropped in a bucket of water
I very much doubt it. If you had removed the batteries straight away, stripped the complete camera and let warm air waft over it for a day and then put it all back together and tried it, you may have been lucky. But wet circuit boards and electricity is asking for major problems. Even leaving a closed camera for 2 days wouldn't have given it a good drying out.
Jun 13, 2006 | Panasonic Lumix DMC-FZ5 Digital Camera
Sony Network Walkman NW-A1200 MP3 Player Logo
137 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
