Question about Refrigerators
Top mont refige; ice maker works but allows water
Top mont refige; ice maker works but allows water to drip into formed cubes creating a bed rosebeneof sheet ice
  • 4,070 Answers
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it can freeze and block the tube or keep dripping into the ice mold. . You can take the water line off the valve and watch to see if it drips.
Posted on Sep 11, 2009
What causes my ice maker to drip water?
HI,
This could be either the ice maker is old and the finish inside has depleted, the water valve is going bad or you had a jammed ice cube and now it overfilled. Many different reason this could happen. Does the ice cubes stick together with a bridge? Is the drip coming from the ice maker head unit? How is the ice in the pan its stored in, stuck together? In the pan, has the ice glaciered together? Need more information please. Thanks
Aug 09, 2014 | Kenmore Top Freezer Refrigerator
Intermittant ice making
When you see this happen can you feel the bottom of the ice maker to see if hot? What is the correct model number? I am trying to understand if it is the ice maker heating element is stuck on while heating the ice maker to release the cubes or if the water control valve is allowing the water to come in through the fill tube like a leaking faucet. Thanks, John Tripp Appliance 911
6aa070b8-d84c-4116-a3d3-21bc4d340b93.jpg PSS26MSRSS)?
Jan 27, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag icemaker drips dirty water onto existing ice ini tray.
please check or install screen filter in the water valve at the back beside compressor
Jan 15, 2014 | Maytag AFD2535
The Ice maker does not make cubes.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Feb 06, 2010 | Refrigerators
Ice maker dripping water fusing ice cubes
The dual water valve (solenoid) that open and let the water from the line when the ice maker calls for it, is leaking and needs to be replaced.
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water in icemaker overflows into ice cube storage box AND CAUSES ICE CUBES TO FREESE TOGETHER AND FORM BIG ICE CHUNKS. ALSO THE FULL SHUT OFF PADEL HAS ICE FORM ON TOP OF IT
Check the ice maker after it dropped the ice cubes and when it calls for water it should be pouring it for no much more than 7 seconds ,if more it overflows, in this case the module board inside the ice maker has to be replaced(or for almost the same price with parts and labor you can replaced it for a new ice maker) But if water is sitting in the ice maker all the time , the dual valve which supplies water to the ice maker is leaking and needs to be changed (it's located at the back of the fridge in the bottom behind the cover where the water line is hooked up).
Aug 05, 2009 | Refrigerators
Water leaks into storage bin
open the machine control panel side and cube adjustable thermostat available in side,adjusted in the thermostat screw
Jun 22, 2008 | U-Line Icemaker
Ice Maker Freezing Up and Ice not dispensing
Check your ice cube tray to see if it is warped. Mine was. I took the tray off and dipped it into boiling water and remoulded it to the original shape and re-installed it. So far no problems. The tray gets warped because of the ice cube release mechanism. The tray is rotated around until it meets a block on one corner which creates the twisting motion we used to do on manual trays. Over time it tends to warp the tray. Good luck
Nov 26, 2007 | LG LRSC26925 Side by Side Refrigerator
Refrigerators Logo
101 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
