Question about Master Heaters CD Master CD Duplicator (Standard) Burner
Standard SD350 duplicator error
I have a standard SD350 duplicator with a code on the display that says E-01 Call Service, can I clear this myself?
Error E 01
The complete error codes for RZ220 Duplicator can be found at.
http://mfpdoc.com/?mod=free&chap=erc&brand=Riso&model=RZ220
Jun 13, 2014 | Riso RZ220 Duplicator
Tip
Sharp Copier Call for service code # H5-01
If you experience <span style="font-weight: bold;">Call for service code # H5-01 </span>just follow the steps below.<br /><br />You might need to run a service mode to reset the machine:<br /><br /><b>P * C * 14 (start) then 1 for Yes</b> and follow on screen directions, code should clear out<br /><br />Or <br /><br /><span>Press <span style="font-weight: bold;">Program Key(P)</span>, <span style="font-weight: bold;">Asterisks</span>, <span style="font-weight: bold;">Clear Key (C)</span>, <span style="font-weight: bold;">Asterisk</span> . when the stand by for simulation code appears type <span style="font-weight: bold;">14</span> to cancel the trouble code</span><br /><br /><span style="font-weight: bold;">Thanks for using Fixya.</span><br />
on Mar 09, 2011 | Office Equipment & Supplies
The lcd display an error code ....E04-01...and i need to get into service mode to clear the message..thanks help please
Did you make a repair or replace the fuser and need to reset the code?; Because if you didn't fix the problem, you'll still get the same low fuser temperature error code.
Press <function>, <original size (ledger)>, <3>
to enter service mode, go to F9-05-04 (RAM Initialize, fuser reset, power off/on)
If the E4-01 error code returns you have a defective thermistor/thermostat.
Nov 22, 2013 | Panasonic WORKiO DP-C262 Printer
Error code e000002-0000
This is a standard Canon error code for the fixing assembly not getting hot. You will have to reset the error by clearing the error from the copier's memory. You have to press additional function key, then press 2 & 8 at the same time, then additioanl function key again. The display should change to the service mode with COPIER and other accessories being seen. Press COPIER then Function, then CLEAR, then ERR, then OK. Press reset a couple of times then power down the copier, then back on. If the error comes back then the fixing film assembly will have to be changed to make a more permanent fix. Good Luck.
Sep 18, 2012 | Canon imageRUNNER 2200
We are getting a code H5-01 what does this
H5-01 means there were five consecutive jams at the fuser section. Open the left jam door and look up in the fuser (heat) section and at the top of it You should find sheets crunched into an accordian After clearing all the paper from this area close up the copier Turn it on and press the copy mode key Then the following keys in order one after the other Program..*..C..* The display will change to service mode input 14 then the copy start key enter 1 for yes then the copy start key if the copier does not restart itself then hit the CA key the copier sholr reset and start with out the code
Feb 17, 2010 | Sharp AR-M355U Copier
Our Standard SD650 Duplicator has error code SC07-30. The paper tray is jammed in the down position. Need the reset code to clear the error
Through my own efforts & online research. Your service team never responded. I paid for live chat assistance which was not provided, and was then directed to email assistance which has been a complete joke. Please fully refund all fees charged to my credit card. I will look for other solutions to tech problems in the future.
Dec 11, 2009 | Standard Registar SD650 Color Copier
I want a solution for a Sharp AR - 287 Digital Image problem
H-4 is an error code for the fixing assemblyand needs to be reset thru a simulation code, sometimes a power flucuation can cause this error and therefore may not need parts.
press #
press *
press clear
press *
when it is done properly the display will go blank
then enter 14
then press the start key, turn the machie off and then back on.
If the code comes back you'll need something for the fixing assembly
Good luck
Bob
Apr 27, 2009 | Sharp Office Equipment & Supplies
T20-414
Check the paper ejection unit that is a T20 code T02 code would be a standard tray lift issue.414 is not listed in the book for eather code
Apr 13, 2009 | Riso RZ310 Duplicator
Master Heaters CD Master CD Duplicator (Standard) Burner Logo
160 people viewed this question
Top Master Heaters Computers & Internet Experts
David Payne
David Payne
Are you a Master Heaters Computer and Internet Expert? Answer questions, earn points and help others
