Question about HP w2207 Monitor
HP W22 lcd monitor turns on and off
This monitor turns on and off. I tried CRT monitor on same computer and CRT monitor works just fine. I tried the HP monitor on another computer and it turns on and off. So I am sure it is the monitor.
1) any ideas as to what may be the problem? (overheating)
2) which internal components may need replacement?
3) How do I take the back cover off without breaking the plastic tabs...Do you have any illustration as to where the plastic snaps/tabs are so I can push on the proper areas without breaking anything.
4) is this a common problem...I talked to HP and they have no record of this type of problem....my hunch is that it is a common problem.
Thanks
    Problem Solver:
  • 13 Answers
This is a fairly common problem with lcd monitors but it can be caused by many different components.
To remove the back cover you need to insert a thin plastic strip to prise it apart. Don't use anything metal as this will damage the plastic casing. If you slide the plastic strip along the join you should be able to feel where the clips are. Once you have got 1 clip released it should be fairly easy to release the others. The clips rarely break so don't worry about them breaking. Once inside take a look at the electrolytic capacitors. These look like miniature tin cans and are normally slightly concave at the top. If any are bulging or have a brown liquid oozing from them they will need replacing. Also check all the solder joints are OK especially on the transformers. If your screen has a pinkish hue then 1 or more of the backlights is failing. The inverter detects the power difference in the backlights and shuts down as a safety precaution.
Posted on Sep 12, 2009
My HP w22 Monitor started to make a crackling sound and than all the sudden turned off, or something. It wont come back on. The computer works just not the monitor. Any ideas on how to fix the problem?
Try checking your Cable connections to the Monitor to the Computer and from the Monitor to the wall outlet.The crackling sound maybe normal.Most Monitors make that sound.
Jul 31, 2010 | HP W22 LCD Monitor
My Neovo E-W22 monitor quit working. I have had it just under 2 years. It is as if it is getting no power. Any ideas?
Make sure the power connector is secure with your monitor and the adapter power light is on as green. If not working at all then just contact with AG Neovo as service.us@agneovo.com for 3 yrs warranty repair. But you probably have to cover the one way shipping only.
Mar 17, 2010 | Neovo AG H-W22 TFT - H-W22 22 inch LCD...
Monitor shows on no picture
its because display ic of your motherboard might be damaged.try fixing it by visiting service centre.
Mar 16, 2010 | HP W22 LCD Monitor
HP w22 Monitor display disappears after about 2
bill, if monitor not covered by warranty, the check out YOUTUBE for long 8-12 minute video clips of LCD monitor disassembly or LCD monitor repair to find out what the major cause of your monitors SYMPTOM that you described above. Here is a small hint for you. If you didn't see the displayed data on the BLACK lcd panel with the flashlight "trick" then you would know that the entire "switch-mode-power-supply" was in complete SHUTDOWN mode or even blown the "line-in fuse" for the monitor. Also try a visit to www. ccl-la.com/badcaps.htm and view some of their vids on repair of lcd SMPS/INVERTER supplys and cold-cathode-fluorescent-lamp replacement. They also do the repairs and return shipping. Please rate this on fixya if this response was helpful. Bye for now. 12fixlouie
Oct 25, 2009 | HP W22 LCD Monitor
Screen image appears fuzzy, jumpy and broken up into lines.
gardenman13, I would certainly complain to HP about their w22 monitor!! Find out if the units warranty is still valid and can be swapped-out for a REFURBISHED unit. Your w22 shouldn't be hazy, distorted, or flicker for any reason. My best guess is that it (w22) has problems inside with it's "cold-cathode-fluorescent-lamps" and electronic ballast circuit called an INVERTER circuit, which could also cause the main "switch-mode-power-supply" to go a little NUTS upon STARTUP!! FYI you are dealing with a technology similar to the curlie-Q CFL screw-in light bulbs. Their ballast's are called CONVERTERs (ac to ac) and are cheaper. Your lanps are thinner and straight, hung on rear of your LCD panel. I hope this was informative. Please rate this on fixya. 12fixlouie
Dec 11, 2008 | HP W22 LCD Monitor
Monitor reads - "no vga signal". Thus, I have no picture. It just stopped working
hi there, check the system if it is ok, if so, check your video cable, you have a video problem. try to see if there is a cold solder on video section, do some test. ty
Dec 25, 2007 | HP W22 LCD Monitor
HP w2207 Monitor Logo
916 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
