Question about Car Audio & Video
Getting error #9 on clarion cdc 1205 . will not turn on.
  • 497 Answers
Check the antenna cable or antenna is connected properly to the back of the unit, and check the cable all the way along to the antenna - these are prone to internal corrosion when they get a bit old. Easiest way to check is to get a new antenna and cable (they are cheap) and plug it in directly to the back of the unit.
Check the ground connection of the unit is good - any terminals might need a clean up - disconnect the battery first.
These guys have a service manual for sale;
http://www.manualscenter.com/allprod-42-217.html
here's the LINK for a free download of the owner's manual (it says is for the 635, but is also for the 634);
Good Luck!!!!!!!!!!!!!!
Posted on Sep 11, 2009
Clarion PK9090V Radio Owners User Instructions Operating Guide CDC-2497
I bought a kawa with a clarion-radio PK-9090V, but I have problemswith the kabels. I want to know if they are set-up right? Where can I find a picture to control that it's done right? Or a manuel?
Thx
May 18, 2012 | kawasaki VN 1700 Voyager Custom...
Rd634 clarion changer error code 9
two reasons one if you are recording a disk the error is because the disk may be scratched so you must cycle off the power and try a new disk if your not trying to record a disk error code 9 also means and this is taken directly from the manual..
There is a problem with the FM Modulator circuit.
Contact your authorized Clarion dealer for repair.
i hope this helps
Mar 14, 2011 | Clarion Car Audio & Video
Clarion 12 Disc CD Changer Model # CDC 1255z What
out of focus.
if all of your discs have the same error code 6, it is optical lens problem. have it checked to the nearest service center.
Jun 12, 2010 | Clarion CDC1255z 12-Disc CD Changer
I had a Clarion 6 Disc CAA-355 in my car which got wet and is no longer working. Can I buy the same model again. If so where from and for how much or is there another model that will be compatible with my...
Great Clarion Disk Changer, 6 CDs CDC-655Z:
CDC655z Multi-Disc Changer - 6 -disc direct load mechanism. - 1-Bit D/A converter. - 10 sec. read ahead memory to prevent interruptions caused by shock and vibrations. - Non-stop play. - Optical Digital Output. - 0º to +90º mounting angle.
Great Multi-disk player. Works only with Clarion audio source units.
Selling b/c my deck player broke- I can give you the deck- maybe you can fix it. The model is DXZ-535, comes with owner's manual and remote.
Feb 25, 2010 | Clarion Car Audio & Video
When i install cd it says error 6 on my clarion dxz465mp
Clarion Audio error codes:
Error Codes:
Error 1 Battery inside CD Changer needs to be replaced.
Error 2 CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3 CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4 Connection problem. Reconnect the data cable.
Error 5 CD error message. Could not read correct data due to CD ROM.
Error 6 CD error message. Could not read data from disc because it is upside-down.
Error 8 Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9 Weak RF. Try alternate frequency
Even though it says error 6 is an upside down cd, it just means the disc cant be read. usualy means the laser is dirty, out of adjustment, or not working.
Aug 19, 2009 | Clarion DXZ465MP CD Player
Turn it on it beeps cdc
You really aren't giving much info, so here are some beep - codes, also make sure nothing came loose on the motherboard or other components ( do this ONLY if you know how ) Safety first.
BIOS Beep Sound core list
AWARD BIOS
1 short(Beep) System booting is normally.
2 short(Beep) CMOS setting error
1 long - 1 short(Beep) DRAM ERROR
1 long - 2 short(Beep) Display card or monitor connected error
1 long - 3 short(Beep) Keyboard Error
1 long - 9 short(Beep) ROM Error
Long(Beep) continuous DRAM hasn't inset correctly.
Short(Beep) continuous POWER supply has problem.
AMI BIOS
1 short(Beep) DRAM Flash Error
2 short(Beep) DRAM ECC Check Error
3 short(Beep) DRAM Detect Fail
5 short(Beep) CPU Error
6 short(Beep) Keyboard Error
8 short(Beep) Display card memory Error
1 long - 3 short(Beep) DRAM Damage
1 long - 8 short(Beep) Display card or monitor connected error
Jul 16, 2009 | E-Machines T6520 PC Desktop
CDC-3 magazine will not eject nor play, error on receiver indicates magazine error
1998 porchea boxter cdc-3 cd changer, The cd changer keeps on changing tracks as if their are no cd's in the changer. keeps going from 1 to 6 and then changes to radio.
May 19, 2009 | Becker Car Audio & Video
Clarion RDC634 Error 9
First thing to suspect would be the antenna cable or antenna. Check it is connected properly to the back of the unit, and check the cable all the way along to the antenna - these are prone to internal corrosion when they get a bit old. Easiest way to check is to get a new antenna and cable (they are cheap) and plug it in directly to the back of the unit. Check the ground connection of the unit is good - any terminals might need a clean up - disconnect the battery first. These guys have a service manual for sale; http://www.user-manuals.com/advanced_search_result.php?keywords=Clarion+RDC634+manual&forward=plist&osCsid=64c58306e0b8605abe537ef57684dcc0 so do these; http://www.manualscenter.com/allprod-42-217.html here's the link for a free download of the owner's manual (it says is for the 635, but is also for the 634); http://safemanuals.com/user_guide_instructions_owner_manual_CLARION_CDC635%20OWNER%27S%20MANUAL_E.htm Hope this helps :)
Jul 07, 2007 | Clarion DC625 6-Disc CD Changer
Car Audio & Video Logo
165 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
