Question about Microsoft Windows XP Home Edition
I need to setup a dual boot computer. I have 2 hard drives each has an os I need the option to select at startup
    Scholar:
  • 49 Answers
Do you have both operating systems installed seperatly ? In case of installing another operating system while one is present, the computer would've known to select the one of it by itself or through some menus while startup. If you have installed both operating system seperately than you may need to find out first that both operating system are able to boot with some menu choice from the startup. To dual boot computer one system has to set as primary while other as extended partition using some Harddisk utility like FDISK. If you need to reset the partitions make sure that both systems works together as dual boot. Win XP, Win98 works as dual boot, WINXP , LINUX works together , but WIX 95 and WIN 98 may not work for dual boot systems.
Posted on Sep 17, 2009
  • 62 Answers
Try Install KDE on your desktop, I think its much better than gnome for booting setup. There's another way which one you'd like to booth by striking the F8 key repeatedly on the restart or starting your PC and select the drive which drive you like to boot.Or you can configure it on your bios setup by hitting the del key and configure your boot priority.
Posted on Sep 12, 2009
Siig sc-sat212-s4, stops boot when connected
While most computers are capable of starting up properly with external drives connected, from time to time the external drive can cause confusion during the startup process. The computer may attempt to boot from the external hard drive rather than the primary internal drive. This causes the computer to fail during startup because the external hard drive does not have the operating system installed on it.
Disconnect the external hard drive from the computer. In order to minimize the risk of damage to or loss of files on the external drive, shut down the computer if possible, or hold down the power button on the computer until the computer turns off and then disconnect the external hard drive. Restart the computer with the drive disconnected. If the computer still does not start up, it is possible that the computer is attempting to boot from the external drive. Reconnect the external drive and restart the computer. Watch the screen as the computer boots up. A prompt will appear indicating which key to press to enter "Setup" or the "BIOS." Press this key when the prompt appears. On many computers the key is either Delete ,F2 or F10. Use the keyboard of the computer to navigate the "Setup menu" that appears. (Advanced Bios Features.) The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ? or using the arrow keys you can load failsafe or optimized defaults this will set the boot order. Highlight the option for "Boot Disk" or "Startup disk" and select the "C:/" or the primary internal hard drive. Press the associated key, labeled so on the bottom of the screen, to save the changes and restart the computer. This will allow the computer to boot from the appropriate drive. Hope it helps.
b>
Jan 23, 2013 | SIIG Scsat212s4 Pci Serial Ata 2 Channel...
No boot sector on internal hard drive. No bootable
A boot sector is a sector of a hard disk that contains booting programs stored in the other part of the hard disk. You boot sector might have been deleted or corrupted and you can't logon until you repair or recover the boot sector. To do this you must have your OS cd. Boot from OS cd the follow below steps...
Windows Vista
1. Insert the installation disc.
2. Restart your computer
3. If prompted, press any key to start Windows from the installation disc.
4. Choose your language settings, and then click Next.
5. Click Repair your computer.
6. Select the operating system you want to repair, and then click Next.
7.
On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem, and if necessary, it might restart your computer as it makes repairs.
Boot from you hard disk then you're done!
Regards,
Jeep Brainy
Jul 29, 2009 | Dell Inspiron 6000 Notebook
Tip
How To Repair Your Operating System
A Repair Install will replace the system files with the files on the XP CD used for the Repair Install. It will leave your applications and settings intact, but Windows updates will need to be reapplied. Here is how to run an OS Repair using the Operating System CD in XP, Vista, or 7:
Windows XP
1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will see the options below:
3. Press ENTER to start the Windows Setup.
4. Accept the License Agreement and Windows will search for existing Windows installations.
5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup.
6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
Windows Vista
If you have a Windows Vista installation disc, you need to restart (boot) your computer using the installation disc. If you do not restart your computer from the disc, the option to repair your computer will not appear.
Here is a step by step picture guide.
If you have a Windows Vista installation disc:
2. Restart your computer.
3. Click the Start button, click the arrow next to the Lock button, and then click Restart.
4. If prompted, press any key to start Windows from the installation disc.
Windows 7
1. If a startup problem is detected, Startup Repair will start automatically and try to fix the problem.
2. If the problem is severe enough that Startup Repair doesn't start on its own and you can't access the System Recovery Options menu on your computer's hard disk, you can get to the menu and start Startup Repair by using the Windows installation disc or a system repair disc that you created earlier.
on Jul 13, 2010 | Computers & Internet
Tip
How to remove Multiboot Option in Windows
If under various circumstances you had to install a second Windows OS on the same system, you should have already met the dual boot option. It will pop up before booting the system permitting the user to select which OS will boot.
Boot.ini, the house of the dual boot option Boot.ini is a system file found in the system root. Because it has a major importance for the booting process.so we have to edit this boot.ini file to remove multiboot popups.
How to edit Boot.ini
1.Go to Start Click on Run
2.Type msconfig.
Once the system configuration window pops up, you will notice that Boot.ini has its own tab. Select that tab and where you see "timeout," set it to a lower or higher value. Remove/Add Operating Systems in the dual boot menuThis is the main issue.
Step 1:Right click on My Computer icon and select Properties.
Step 2:From the properties window go to Advanced > Startup and Recovery > Settings.
Here, you can both edit the timeout value and modify the Boot.ini file by clicking Edit. If you remove the second operating system from Boot.ini, the dual boot option won't appear before booting.
For more details information visit How to Remove Multiboot Option in Windows XP
on Jan 08, 2010 | Computers & Internet
WHAT KEY IS REQUIRED FOR RECOVERY OF MEDION MT 7 PC
From the Setup CD-ROM
1.
Insert the Setup compact disc (CD) and restart the computer. If prompted, select any options required to boot from the CD.
2.
When the text-based part of Setup begins, follow the prompts; choose the repair or recover option by pressing R.
3.
If you have a dual-boot or multiple-boot system, choose the installation that you need to access from the Recovery Console.
4.
When prompted, type the Administrator password.
5.
At the system prompt, type Recovery Console commands; type help for a list of commands, or help commandname for help on a specific command.
6.
To exit the Recovery Console and restart the computer, type exit.
If you have already installed the Recovery Console
1.
During Startup, select Recovery Console from the startup options menu.
2.
3.
4.
5.
Aug 15, 2012 | Medion MD-1704 PC Desktop
Dual Boot
You may have overwritten your boot.ini file.
  • Click Start, click Control Panel, and then double-click System.
  • On the Advanced tab, under Startup and Recovery, click Settings.
  • Under System startup, in the Default operating system list, click the operating system that you want to start when you turn on or restart your computer.
  • Select the Display list of operating systems for check box, and then type the number of seconds for which you want the list displayed before the default operating system starts automatically.
    To manually edit the boot options file, click Edit. Microsoft strongly recommends that you do not modify the boot options file (Boot.ini), because doing so may render your computer unusable.
If both OS's are the same, you should be able to copy and paste the line for XP and simply change the drive letter to the location of the second OS.
Jul 10, 2012 | Computers & Internet
Windows 7 laptop won't boot to OS , only has a black screen with a blinking cursor
Insert your system recovery disc to repair your startup.
1. Change your Bios to boot from disc:
When your computer powers on, hit F2 (on some computers, F8 on others). Use your arrow keys and move to the right to your BOOT option. Hit the down arrow until you select your CD/DVD drive. Look at the bottom of your screen, and it should say to change the option hit F7 or F8. Use the specified keys, and move your CD/DVD drive above your hard-drive. Save your settings.
2. Boot from your disc. Insert your system recovery disc and restart your computer. Let the recovery disc load. If the option comes up to hit any button to boot from CD/DVD, then hit any button. Once it loads, it should come to a spot where it wants your language. Select your language, then select the option "Startup Repair". Click on it, and let it repair the startup. If it automatically starts correcting your startup then great! If not, then select your operating system from the list and click the Repair Startup option. Restart your computer, and hopefully it will boot from your hard-drive correctly.
Hope this works.
P.S. If it continues to boot from your recovery disc, then using the same method in step 1, go to your bios, and move your CD/DVD drive below your hard-drive.
Mar 01, 2011 | Computers & Internet
How to put a os on my aspire computer
1. Press f12 as soon as the laptop starts up. This should give you a menu which allows you to select a temporary boot device, you'll need to select your cd/dvd drive.
2. Make sure the os disc is in there, and when it says 'press any key to boot from disc', press a key.
3. Follow on screen instructions.
If F12 doesn't bring up a boot menu, then you'll need to go into the bios. You do this by pressing F1, F2 or del usually, it varies between computers. For instance I have an iBM laptop and I have to press the thinkvantage button to interupt normal startup and then select either F1 for the bios or f12 for the boot menu. But whatever you have to press, it should tell you.
Once you're in the bios then you should be able to find an option to enable a boot menu, enable it, and once you've saved and exited the bios proceed from step 1.
If you can't find a boot menu option, then you will be able to find an option to change the boot order, you'll need to change it so that your cd/dvd drive is at the top. Once that's done save and exit, then proceed from step 2. In this case, once the os has finished installing, you may want to go back into the bios and put your hard drive back to the top of the boot order, this isn't necessary but if you don't then the laptop will give you the option of booting from cd/dvd every time, thus slowing the overall startup time.
Jan 18, 2011 | Acer Computers & Internet
When i turn my computer on, it ask me to pick xp home edition or it will pick the first one on the list. I wan to know why it is doing this
This will occurs when the Computer did not shut down properly or restart automatically or a dual Operating System installed in the Computer.
To resolve this:
1. Click on Start -> Control Panel -> System.
Or, Click on Start, right click on the My Computer option and select the option Properties.
2. In the System Properties option click on Advance tab.
3. In the Advance, click on Setting option under Startup and Recovery option.
4. Under Startup and Recovery option un-check the boxes:
a. Time to display list of Operating Systems.
b. Time to display list of Recovery options when needed.
5. Then, Click OK, then Apply and OK in the System Properties window.
6. Restart the Computer.
This should resolve the issue.
Good Luck!!!!!!!!!!!!!!!
Sep 29, 2009 | Microsoft Windows XP Home Edition
Thinkpad 390x 2626, won't boot from cd drive
Try pressing F12 at startup, you should get a boot option.
Nov 19, 2008 | Computers & Internet
Microsoft Windows XP Home Edition Logo
93 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
