Question about Compaq Evo N610C Notebook
Install extra memory and a wirelss card in a
Install extra memory and a wireless card in a compaq evo laptop
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 67 Answers
U can install extra ram by removing back cover over battery ... better to google a tutorial of how to install a memory in laptops....and for wireless card u can't install an internal card but u can try and external usb wireless card ... for ur laptops..
plz give rating.
Posted on Sep 12, 2009
  • Compaq Master
  • 13,433 Answers
The memory slot is most likely in the bottom of the laptop and its hold closed with 2 screws.
Some laptops have the other memory module under the keyboard, if the other memory module is not in the bottom of the laptop, you would have to unscrew the screws from the bottom of the laptop that are under the keyboard, those screws may be marked with K/B (meaning Keyboard screws)
Then you may have to remove the plastic cover from the top of the keyboard which is between the display and the keyboard, in most cases this is hold in place with just plastic clips, you can remove it with a small flat screwdriver starting at the display hinges and then working your way slowly to remove it completely, if it really resists alot, check for screws in the bottom and the nearby areas and unscrew them, we don't want to ruin it.
Then you should be able to unscrew the rest of the screws on the keyboard and take it up, and you should be able to get to the 2nd memory module.
About the wireless card, you can use a USB, a PC card or possibly a internal card if the laptop has room and a connector for it inside, I would recommend you go with either a USB stick or a PC CARD, take the laptop with you to a local shop to find out which one would be the best option for your laptop.
let me know if you need furhter assistance.
Posted on Sep 11, 2009
I just bought a wireless card for my evo d500. when i instaled it, it had a few teeth in the slot left over (the new card did not fill all of them) when i turn on the comp., the keyboard is locked up, no...
You dont have the correct card in your computer. You may have a PCI card and a PCI II slot or the otherway around. There should be no extra teeth nor extra holes.
Remove the card and get the proper one.
Oct 25, 2009 | Compaq Evo D500 PC Desktop
Need help with Wifi Connection with COMPAQ EVO N610C LAPTOP
First you will need a router which will enable you to create a wireless network for your internet connection. I recommend, if you're purchasing online, to use Tigerdirect. Then you would need a USB wireless adapter for your laptop which will enable it to communicate with the wireless router and establish an internet connection.
Below are some links for the most affordable and best rated products you need.
USB wireless adapter.
Wireless router
Oct 05, 2009 | Compaq Evo N610C Notebook
Compaq evo n610c
yes i solved the problem. Remove the wireless lan. Start the computer go to regedit hkey_local_machine/software/Compaq Wireless LA delete it and restart. download SP23031 search on google and run without wireless lan W200. Restart with the card installed it will configure itself.
Jun 24, 2009 | HP Compaq Evo n610c Notebook
Wireless card on the blink
hello i will try to help have you tried to reinstall the drivers remove the old ones compltey the renstall the neww ones also have recently removed any software or installed any or maybe a system restore
Mar 23, 2009 | HP Compaq Evo Notebook N600c
Compaq evo n800 laptop built-in wireless internet
right click "my computer", left click properties, select "Device Manager" Expand anything to do with "Network Adapters" and make sure there are no problems / exclamation marks / unknown devices.
If there are, look for your wireless driver on..
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=uk&cc=uk&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=compaq+evo+n800&submit=Go+%C2%BB
depending on your model. if this doesn't work go to www.hp.co.uk and download the driver then install it.
If you can't detect any wireless networks, make sure your wireless card is activated - I believe this involves holding down FN (bottom left of keyboard) while then pressing F2 key at top. after this try try to search for wirless access points points.
Good Luck,
Cheers,
Colin
Mar 18, 2009 | HP Compaq Evo n800c Notebook
WIRELESS ADAPTER
To install your wireless adapter, plug in the wireless card, and put your cd driver into the laptop. Once the adapter is plugged in, your laptop should recognize a new hardware has been installed, and will ask you for a driver (whether to automatically search for it or you can install it yourself. Pick the option of you installing yourself, and put the cd driver in. Then just go through the wizard to install your wireless card. You should be good to go from there! Any other questions, let me know!
Nov 21, 2008 | HP Compaq Evo n610c Notebook
Multiport w200 wireless goes to blue_screen with belkin G+ router
http://www.fixya.com/support/t612983-blue_screen_hp_wlan_multiport_w200 seems to have the solution.
It says:
Rollback the W200 driver to version 1.00C. Subsequent drivers are incompatible with XP SP2.
Unfortunately, WPA support came in version 1.00E, so W200 + XpSp2 = no WPA support. :(
I removed my wirelss drivers and compaq wireless client software, then installed the older driver from http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=hb-13082-1&lc=en&cc=fr&dlc=en&os=228&product=235687&lang=en which is sp23031. This seems to have worked. s.gif
Oct 07, 2008 | Compaq Evo N610C Notebook
Compaq EVO N400c without wireless capabilities will external wirelss card work?
http://www.everythingusb.com/hardware/index/Linksys_Wireless-G_USB_Network_Adapter.htm
This is just one source. I did a google search for USB wireless adapters. They are used by many users. Generally these units cost the same whether online or at the local Radio Shack, etc. because of shipping.
Oct 04, 2008 | Compaq Evo Notebook N400c
System Freeze after WLI-CB-G54s is inserted
Restart your Compaq Evo N1020v laptop without the card inserted. Go into the BIOS (by hitting F10), change the UMA Frame Buffer Size from 32MB to 64MB (located in the Advanced menu), reboot and install the card drivers and insert thecard. This should fix the problem.
Nov 02, 2007 | Buffalo Technology AirStation WLI-CB-G54S...
Compaq Evo N610C Notebook Logo
131 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
