Question about Frigidaire ATF6000ES Front Load Washer
Can't skip wash cycle to spin hand wash
Model GLTF1240AS0 Serial: XC22803435
After hand wash I want to use ONLY the spin cycle but wash cycle starts automatically.
Can I avoid this?
Marg. Smith
alan@asmith.com
tel: 905-628-0436
    Top Expert:
  • Frigidaire Master
  • 80,637 Answers
Unleess there is a setting for bypassing this rinse cycle no u can't do it, u can on the old style machines with mechancial controls, but this machine has an electronic program and it can't be altered.
Posted on Sep 11, 2009
GE front load washer model number WBVH6240HWW SERIAL NUMBER RM200099T spins freely by hand but started smoking and belt behind looks fine. What could be the problem. Before the smoke started when spin...
Hmm... Kind of difficult to say for sure. Does your inner spin basket wiggle up and down? If so, you've got a main bearing going. Also, put it in a spin cycle for a minute or so and then try smelling the windings on your main motor. If they smell burnt, you'll need to replace the main motor. Also, one last thought, check to see if your drain pump overheats. I say this because the drain pump is active during the spin cycle and a bad drain pump can sound extremely noisy and start overheating.
I hope this helps. Good luck!
Oct 19, 2014 | Washing Machines
Fills with water, skips wash and rinse cycle, starts spin cycle and sprays water out of the top
I would look at lid switch on this model and plunger to lid .Under lid is spray flume that can be damaged by large loads ,check that close. put it in wash full and drop lid hard it may come on.
Nov 19, 2013 | Maytag Dependable Care LAT9206
Washer skips spin cycle
You have an issue with the controller on your machine. Needs replacement.
Sep 17, 2017 | Maytag Legacy Series Top Load Washer
The spin cycle does not spin smooth. What can I do? I had it worked on and when it came back it bounces when it spins.
vaquero651
It is really important to know what the model number of your machine is. You are in the Neptune FAV6800AW Top Load Washer forum so I assume it is a FAV6800A or FAV9800A. With the model number I can zero in on the issue.
What is the model number?
Does the machine error out with an unbalance error code such as dC or uC in the Spin Cycle?
What was the previous work performed any parts replaced in the washer for this issue?
Some additional info if the machine is a FAV6800A or FAV9800A; Service Manual for reference. Sears Parts Direct for reference.
If your machine is a FAV6800A or FAV9800A can you provide me with the first two digits of your serial number. The Model numner and Serial number is located on the back of the console right hand side as viewed from the front. Left hand side viewed from the back see the pic below……Rich
May 20, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune topload model fav6800aww. does not spin
Thank you for posting your model number.
Are you taking error codes to the LED display such as dC or uC with fail to complete spin cycle?
Is the wash tub banging the sides of the machine at the start of Spin Cycle?
Will your FAV6800A complete a spin only cycle with no clothes in the wash basket?
If you are going to DIY the repair take a look at this step by step process Clutch Fix Post
Basic mechanical skill set and hand tools are all that is required. I can help you through the process just let me know what direction you want to go.
Links to the FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
If you can give me the first two digits of your serial number of your machine it will be 10 through 17?
Jan 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Gallery ser. front load makes loud clunking sound in all cycles
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fgsgsgf
Apr 19, 2009 | Frigidaire ATF6000ES Front Load Washer
The neptune TL model 6800AWW makes a terrible noise at what seems to be the end of the wash cycle. Is this a rebalance? Because it sounds like metal against metal. Or could this be a belt issue. The...
Hello acelmo3,
Thank you for the model number, can you give me the first two digits of your serial number. That number is located on the back right side of the console. I only need the first two digits.10, 12, 16,,,etc.
Let's try to troubleshoot the grinding noise issue, You mention the spin cycle. Have you taken any dc or UC errors in spin cycle? Can you try the following and let me know what you find?
1. Open the lid and rotate tie wash basket by hand Counter Clock Wise, CCW. The wash basket should rotate freely with no restriction. The wash basket will not rotate Clock Wise, CW by hand.
2. Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. Raise the top of the machine to observe the wash basket and tumbler action described in step 2. (See page 33 of the Service Manual for putty knife insertion point). Also see pic attached.
3. With the top raised start a Spin Only cycle with no clothes in the wash basket, observe the wash basket it will begin to rotate CCW. Watch the tumblers, they should not rotate in spin cycle (maybe ½ turn at the start of spin cycle and that’s all). If the tumblers rotate while the wash basket is rotating you have a clutch malfunction and the Spin Cycle will fail with dc/UC errors. If this is not the situation move on to step 3. This is what I refer to as a soft failure and possible clean up of the clutch roller bearings in the clutch hub may restore normal clutch operation. A hard failure would be the clutch spring has failed, the roller bearings are rusted beyond clean up. A replacement clutch is required.
Pic attached for top cover removal .
Let me know if you see the tumblers rotating in Spin Only cycle and if yo hear the grinding noise. Rich
Mar 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
After a load of laundry is washed the clothes are still soaked. What would cause this?
Hello brendalee. The unit is not performing the rinse cycle. I can suggest you VERY SLOWLY turn the control knob a click or two and see if the water for the rinse cycle starts when the unit stops after the wash cycle. Unit should fill, wash again, and spin. If the machine never spins I will need Mgfr, model, & serial # to assist you futher if you wish to use some hand tools and repair the unit. Good Luck.
Oct 08, 2008 | Washing Machines
GE washer model WHDSR209
On some models, the drive motor is universal meaning the drive turns clockwise in wash mode and turns counter clockwise in spin mode.
Possibly the motor windings is defective for the wash mode and thus the entire drive motor will require replacing.
Hope this helps..
Jul 15, 2008 | GE WDSR2080D Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
88 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
