Question about Garden
ModleHDS 3.5/30 P Cage - 1.575-551.0
Modle HDS 3.5/30 P Cage - 1.575-551.0
Q: I have Pressure for a short while then (nothing) I have used the Trobleshooting Chart in my Operators Manual but it has no listing for this Problem.
  • firehead May 11, 2010
    This is a heavy duty machine. I (and Karcher) feel you should really take it to a professional. Disassembling a 3000PSI pump can be dangerous, even lethal if you are not a trained technician.
    It sounds like it is leaking somewhere or a seal or valve is blown
2 Suggested Answers
  • 2841 Answers
SOURCE: I need the owners/operators manual
I found this manual but it is not free. http://www.industrialmanuals.com/karcher-series-instruction-operation-parts-manual-p-218.php
I also found this.
http://pressure-washers-uk.com/acatalog/Karcher_HDS_750_Spares.html
Posted on May 22, 2011
Karcher HDS 7/10-4M has the oil light giving 4 flashes, what does this indicate as the fault.
Ive got a brand new HDS 10/20 and its crapped out on me already, water line filters were blocked, cleaned them out and now it splutters after 2mins of pressure washing, oil light flashing x3, nothing in any of their **** manuals to assist, any ideas before i set it on fire?
Jan 19, 2013 | Karcher Garden
What kind of cleaning maintenance should I expect from a bird cage?
Cleaning a bird cage may often feel overwhelming, with both daily and weekly tasks that need to be done; however it is a crucial aspect in ensuring your bird remains healthy and has a clean and comfortable living environment. Using cage liners will help make this process much easier. Here is a short video clip explaining basic maintenance requirements to keeping a bird cage clean.
http://www.youtube.com/watch?v=Eb4onjZrVZI
Aug 30, 2012 | Absorption Corp Birds
What's a travel bird cage?
The travel bird cage is usually a smaller version of a normal bird cage. The travel bird cage does not need to be large, nor does it need to be as durable as your bird cage. Be sure that your bird can comfortably fit in this cage for a short amount of time so that it will not become stressed.
Aug 05, 2012 | Birds
Karcher professional hds 655 steam cleaner not much water pressure
If there is nothing wrong with the machine but you have lost power over the years you have been working it. It could be that the machine needs a new pump kit or/and change the pressure nozzle.
smaller issues could be that the pump isnt turned to high pressure or if you have an servo control on the gun that it is turned to low pressure instead of high pressure.
May 14, 2012 | Karcher Garden
How can I learn more about using my debth finder. Its new to me . Any video tutorials or materials I can read or watch?
look under support
http://www.lowrance.com/Products/Marine/HDS-High-Definition-System/HDS-5-FishfinderGPS-Chartplotter/
Feb 08, 2011 | Lowrance HDS 5 Fishfinder GPS Chart...
Campagnolo Record 10 sp. short cage rear drlr.+ 13-26 cassette
You don't say if this happens in the BIG ring, small ring or both. If it's just the big ring I'd suspect there isn't enough chain length.
Cross chaining is unnecessary and bad for your drivetrain. I never go more than one cog past the center of my cassette opposite the chainring I use.
http://www.parktool.com/repair/readhowto.asp?id=26
May 02, 2010 | Campagnolo Record 10 Rear Derailleur
I am looking for a workshop manual for karcher hds 555 ci hot pressure washer.or access to where i can download one. any assistance is greatly appreciated
hi could you post your email address and i can email you a full pdf file, also on the chassis of the machine there will be a silver sticker could do with all the numbers to find which modle it is regards
Jan 19, 2010 | Karcher PSI Electric Pressure Washer
I want to clean the squirl cage fan on my Carrier handler. It's 12 years old and never really been cleaned. What is the best cleaning procedure to maximize its efficiency.
The best way to really clean the squirrel cage is to remove the entire indoor blower motor housing assembly out of the furnace then remove the squirrel cage from the motor shaft and pressure wash the squirrel cage. Make sure you don't use to much water pressure as you might knock off any balancing weights that may be attached to the one or more of the vanes. Make sure the cage is completely dry before you re-install it back on the motor shaft.
Nov 16, 2009 | Kitchen Ranges
My karcher hds 745 has started blowing fuses. it switches on the power light comes on and it makes a buzzing noise for about five seconds and then blows the mains 13amp fuse. i have replaced it twice but...
you have an electrical short in the motor windings. you'll have to either replace the motor or buy another washer. also check to see if the motor isn't locked up with a piece of trash. to do that you'll have to dissassemble housing until you get to the motor. it should turn easily by hand. if so you have a short.
Apr 19, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
