Question about HP OfficeJet 7310 All-In-One InkJet Printer
The feeder no longer works, it was iffy for awhile and now it just won't take the paper
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 156 Answers
Change the paperfeed in windows ...
Posted on Mar 04, 2015
My Lexmark printer 2600 series won't print. It pulls the paper towards the right but won't feed it. How can I fix this?
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 03, 2011 | Lexmark X2600 InkJet Printer
Lexmark 5495. No paper jam. Gears just spin. Won't grab paper. Paper properly in loading position.
Here are some tips on how to use the feeder: - Use paper that is in good condition. - Fan the paper before loading into the feeder to avoid sticking together. - Make sure the paper don't buckle when loading into the feeder. - Avoid overloading.
Aug 11, 2011 | Lexmark X5495 Printer
Lexmark X85 won't feed paper. When trying to
There could be something in the paper feeder that's blocking the paper path. Please follow steps below to identify and fix the problem:
2. Grab a flashlight and look inside for any debris.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
ns Serif"'>6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 11, 2011 | Lexmark X85 All-In-One InkJet Printer
When trying to print the paper won't feed through. It will on the left side (looking at the front of the printer) but won't on the right preventing it to print. I just bought and replaced both...
There could be something blocking the paper path. Remove the sheets of paper from the feeder. Grab a flashlight and look into the feeder. Make sure there are foreign objects or debris that could cause this problem.
May 13, 2011 | Lexmark X4650 InkJet Printer
Feeder is no longer feeding. What should be
Well I don't think you are going to be able to find replacement parts for it. But what you can do is try the following. Turn off the printer, unplug the power cord, remove any paper that you may have in the feeder now pick up the printer and flip it upside down. Be careful with the scanner lid but sometimes what happens is that things will get inside the printer blocking the paper path. That will cause the printer not to pick up the paper most of the time.
Jan 09, 2010 | Lexmark X5470 All-In-One InkJet Printer
IBM 1422 not feeding 8 1/2 x 11 paper through multipurpose feeder
Go into the paper menu and set the multipurpose feeder paper size to letter. It will work if the paper size is set correctly for the MPF.
Apr 30, 2009 | IBM Infoprint 1422 Laser Printer
SHREDDER STOPS (RED LIGHT) VERY FREQUENTLY
there are what is called strippers that ride in between the teeth to keep paper from building up. they are plastic and can break after awhile. sounds like you have some of the stripper combs broken.
razors
Feb 25, 2009 | Fellowes DM8C Cross-Cut Shredder
Lexmark x1180
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Nov 13, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Paper feed
check to make sure there isnt a foreign object in the paper feeder. Had the same issue awhile ago and found that the kids put a toy in it.
Nov 11, 2007 | Lexmark X1150 All-In-One InkJet Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
154 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
