Question about Uniden Cordless Phone
How to Silence the Key Pad
I have a GE 25942C cordless phone. Is there any way to turn the sound off when using the key pad? It's annoying to listen to the beeps every time someone is dialing. I can't find anything on it in the instruction manual. Any help would be appreciated.
I called GE directly and they said there was no option to silence the key pad on this phone. (I think I'll return it).
Posted on Sep 12, 2009
Cordless phone does not ring
Posted on Jun 30, 2011
4 Suggested Answers
SOURCE: UNIDEN ELITE 9035 + 1 (WHITE) CORDLESS PHONE INSTRUCTION MANUAL DOWNLOAD
Try here:
http://www.uniden.co.nz/RESOURCES_MAIN/pdfs/ELITE_9035_OM%20Final.pdf
This is the manual from the Uniden NZ site.
Posted on Aug 29, 2008
SOURCE: How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Posted on Feb 05, 2009
  • 8 Answers
SOURCE: Static on my pair of Uniden cordless phones (Model DECT1560)
Is your base near a computer or other electronics? Also, make sure your microwave is not on. I get static if I do any of those things.
Posted on Jun 20, 2009
How do i turn off keypad volume
My service provider couldn't even help me with this! So in case no one has answered this yet ,,, to turn off the key pad tones (very annoying sound) select menu>settings>profiles, then with 'normal' selected, hit the 'options' key (upper left soft key), then 'customize'- set up your audio profile the way you want it - go down the list til you come to 'key volume' and turn that all the way down with either the side control or the navigator dial. That will turn off those annoying key tones so you will bother other less while you use your phone in public.
Hope that helps.
Jan 28, 2010 | Pantech C470 Matrix Smartphone
Remove the sound from the keypad.
hi
well it quite simple
you need to go to your phone Profile section
then under customise profie find the key pad sound option
and turn it off
that will solve your problem
you can create different profile for different situations...some of them are already made for your use by phone manufacturer
thank you
Cheers
May 25, 2009 | Samsung Cell Phones
Key pad not working
dust may be accumulated in key pad if u can try opening the panel and cleaning it or the connector of key pad would have failed try changing it
Jan 20, 2009 | Sony Ericsson W200i Cellular Phone
Touch pad
your phone manual will guide you as to how to do that.....or just go to your sound settings and deactivated the keypad sound
Nov 24, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
How do yopu turn the key pad tone down (or better - off)
This phone doesn't offer that option, Everything that can be done with this phone can be found in the user guide found HERE
Oct 15, 2008 | GE 25932 Cordless Phone
KEY PAD SOUND ON W377
Hello Velveteve,
Luckily for your housemates, there is a way for you to silence the keypad.
You'll need to go to your "Settings" Menu
Select Ring Styles, then go to ringer "detail"
If you scroll all the way down, you should be able to see "Key Volume".
Set that to "0".
Similarly, you can choose the "Silent" or "Vibrate" ringer option and that will temporarily silence your Keypad Tones.
Hope this helps,
cHiPz.
Mar 23, 2008 | Motorola Mobility W375 Cellular Phone
Turn off ringer
here's what my instructions say about turning off the ringer:
Ringer high/low/off Shortcut
Apart from the setting in the main menu, there is a shortcut to set the ringer. Make sure the phone is OFF (not in talk mode).
1. Press the #RINGER/PAUSE button to go to the RINGER VOLUME menu. RINGER 1HIGH shows in the display. 1HIGH is the default.
2. Use the cid/vol (- or +) button or the touch-tone pad on the handset to scroll to 1HIGH, 2LOW, or 3OFF.
3. Press the #RINGER/PAUSE button to save your selection. You will hear a confirmation tone.
Jan 21, 2008 | GE 25951EE2 Phone
GE28112 Dect phone
Here are the instructions and a link to the manual :
Key Tone
From the Handset Setup Menu:
1. Press the caller ID-volume ( 6 or 5) button to scroll to the KEY TONE sub-menu.
2. Press mute/program button to enter the menu. SET KEY TONE 41ON 2 OFF shows in the display. The default setting is 1ON.
3. Use the touch tone pad on the handset to select 1 or 2, or use the caller ID-volume ( 6 or 5) button to scroll to your selection.
Here is a link to the manual for you :
http://telecom.hellodirect.com/eBiz/pdf/phones/GE_28111_Manual.pdf
Jan 05, 2008 | GE 28111 Cordless Phone
Can't switch off annoying key pad music tone
use volume key on left hand side when phone is open and display will gradually reduce until an X is displayed.
Dec 29, 2007 | Samsung SGH-ZV40 Cellular Phone
Uniden Cordless Phone Logo
80 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
