Question about Canon PIXMA MP210 Photo All-In-One Printer
Hi, my canon mp210 will not scan error codes 1 and 6. It keeps saying that the scan has been cancelled
I installed the drivers for a canon pixma mp210 and it wont scan. it keeps saying " E 1 6"
"E 1 6" error code means Ink has run out.
Replace the ink cartridge and close the Scanning Unit (Printer Cover).
If printing is in progress and you want to continue printing, press the Stop/Reset button for at least 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.
The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing. The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
Jun 11, 2011 | Canon PIXMA MP210 InkJet Printer
PIXMA MP210 scanner wont work. when i press scan it says SELECT PRGRAM TO SCAN TO, no matter how many "softwares" ive download from the canon website and others NOTHING WORKS
Hi
follow this steps
1.unplug your printerfrom your pc
2.uninstall canon driver from your pc
3.run setup (without connecting printer to pc)
4.connect your printer only when setup ask you to
pls vote us to keep us alive
Nov 16, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Canon MP210 Third Party Ink Canon Does Not Work!
When the error message comes up, try pressing the "stop/reset" button and holding it down for at least 5 seconds. This works when I get an error message with compatible cartridges (only my error message says the ink is empty - and I know it isn't)
Jul 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Error code 6000 on canon pixma mp210 stops me from printing
Error 6000 means - The specified file could not be encrypted.
Solution: reinstall the printer driver.... it's better to install a upgraded version of driver...
Good Luck!!!
Mar 19, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
MP210: Can I use the scanner without the printer?
yeah same problem here wit a mp160.. will try it with new cartridges, if that fails, i'll never buy canon again
Jan 18, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Error code:2,114,0
HI
I have Canon PIXMA MP210 printer but problem is that whenever i given comand for print or scan than computer show "Code: 2,114,0" this message therefor printer not print or scan. so please give me solution
Thanking you,
ayyub_thakur@hotmail.com
Dec 06, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Scan does not work.
hi!!
try to re-install the driver PIXMA MP210 Photo All-In-One Printer
Nov 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon mp 210
According to Canon you should:
1. Load paper correctly then press Black or Color button (MP210) 2. Press ON/OFF switch to reset the multifunction device 3. Remove Packing Material MP210 4. Reseat ink cartridge MP210 5. The MP210 may require repair
All steps can be done individually and if the error goes away the other steps don't have to be done. Hope this helps.
Oct 06, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Brand new Canon MP210 wont print at all
Try going into Control Panel, Administrative Tools, Services and make sure that the print spooler is set to automatic.
Also make sure you have the latest drivers.
Click Here To Go To Canon Support
Sep 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
1,058 people viewed this question
old marine
old marine
