Question about Samsung Washing Machines
Samsung washing machine WA13U7 .After repair now tangles clothes .It didnt before repair .The repair was to replace clutch mechanism which stops the drum turning during wash cycle
    President:
  • 1,653 Answers
Call back the repair man to fix it!
Posted on Sep 11, 2009
Hi my washing machine is tangling up all the washing around the agitator then going out of balance, stops spinning, lights start flashing and beeping? Please help me...
Make sure the agitator is down as far as it can go on the shaft. If it has worked itself partially off the shaft it can cause a gap that will cause your clothes to tangle around the agitator.
Dec 09, 2014 | Washing Machines
I have a samsung washing machine code No.DC68_023404 the problem i'm having is when it is spinning while the water is throwing up it making a clicking sound..."click" click" while...
The servo is not engaging the bowl so only the agitator is spinning witch is tangling the clothes. Servo will need replaced it is found underneath, it looks like a small motor with a wire coming out
Jun 07, 2011 | Samsung Washing Machines
Fills with water then does not rotate, also does not spin
Check for large items of clothes being tangled if the Bosch washing machine doesn't spin. The weight could not be evenly distributed in the drum and the spin cycle will have been disabled to prevent damage to the clothes..
Load the drum with large and small clothes together and run the entire washing cycle and spin cycle again.
Add more powder and run the entire washing and spin cycle again if you haven't found tangled large items, but the spin cycle still failed. This indicates the amount of cloths was too small.
Add 1 tablespoon of fabric softener to 1 pint of water and pour it into the main detergent dispenser if there's no tangling and the load was a normal size. The cause would have been excessive suds because of too much, or the wrong kind, of detergent. Use HE (High Efficiency) detergent in Bosch washing machines.
Nov 01, 2010 | Bosch Washing Machines
Hoover 500M0AUS stops very frequently due to off-balance
Hi there.I'm guessing you changed the (Spin Brake Solenoid) underneath,it attaches to the brake arm,the solenoid retracts with a normal loud clunk & pulls the brake arm away..I think what is happening is the clutch spring inside that white plastic cog is not binding like it's supposed to & it's not taking the drum with it.so the agitator is spinning independantly without the drum.the clutch spring tightens in one direction for spin & loosens in the other direction for wash.either way i think your problem is in that plastic cog & clutch spring,the spring is inside that cog & hard to see.it can be repaired if your up to pulling the entire gearbox out to get to it.I hope this was helpful,it's kind of hard to explain by this method.cheers Chris
May 29, 2010 | Washing Machines
Simpson eziset 800 clothes tangle when washing
If you can use a lollipop stick to operate the lid switch while you leave the lid open, you will be able to observe if the agitator is going smoothly back and forth EVENLY or not. If it is tending to turn just one way....this will tangle the clothing like mad!
If this is the problem it could be the switching module or capacitor that needs replacing.
Oct 25, 2009 | Washing Machines
My washing machine turns on but wont rinse my clothes
If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jun 09, 2009 | Avanti 10 lb. Portable Top Load Clothes...
Tangled, "knotted" cloths
hi, these are early signs of drive failure. the drive is made up of a clutch assembly and a transmission(gearbox). it also has a brake that is integrated into the drive as well. these components work together and if one or more start to malfunction, it will cause squeaking noises and slow reacting braking of the drum as well.
You will have to replace the drive and transmission soon.
May 15, 2009 | Maytag Legacy Series Top Load Washer
Lg washing machine wf-t902. clothes tangling up
the machine has a broken wire to motor possibly
check that first
if not
does machine spin
otherwise at the bottom of gearbox under drive pulley there is a pring on main shaft and tah locks gearbox up
if this starts slipping on shaft it will only wash one way
remove and rough up shast refit and grease
Mar 16, 2008 | Washing Machines
Washing Machines Logo
275 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
