Question about Sony Televison & Video
Mum has a dvd recorder, 2/3 years old, not digital. When I get the timer screen to set for recording it is zoomes, so i can't see it all.
  • Sony Master
  • 13,433 Answers
First lets try getting the dvd recorder back to its factory default settings, see if you can find a reset or factory defaults option from the menu's.
If you don't find any, check the back of the dvd player for a reset button or a hole.
If you don't have a reset button either, try unplugging both your tv and your dvd player for the night, hopefully this will reset both to default settings.
if the problem remains check the dvd player for zoom options and try to zoom out, do the same on the tv, also look for aspect ratio settings and try different settings on it untill you see everything on the screen.
You can also look for a reset and factory defaults option on the television if it has a menu.
Posted on Sep 11, 2009
Record tv to dvd on Funai recorder
The Funai ZV427FX4 doesn't have a tuner. You'll need a set-top box (either a digital tuner or a cable box) that has a composite A/V out. Make sure to use a compatible DVD-R or DVD-RW disc (see page 27 of the manual given below). For basic recording, insert a DVD and press DVD to make sure that the recorder is ready to record to disc instead of video tape. (You may need to format the disc for DVD-RW.) Press Rec Mode until the correct mode is chosen. Then press Input to select composite input 1 or 2 (L1/L2). Set this source to the desired channel. Then press Rec. (For scheduled recording, make sure that the unit is set to DVD. Then press Timer. Follow the on-screen cues to set the time to start and end the recording. Otherwise the steps are the same. Then press Timer Set.) See the manual for screen-shots of the procedure.
The manual for this model is available on the product page: http://www.funaiamerica.com/product/product.php?id=877 . Click on the Downloads tab. The direct link is currently http://www.funaiport.com/download/download.php?id=3361&brand=FUNAI . For older Funai units with an NTSC tuner, you will probably still need the set-top box. However, you can either connect the box to the composite video or RF input. (If you want to record a program from a low-power analog station, you would skip the set-top box.)
I hope this helps.
Aug 28, 2016 | Funai ZV427FX4 DVD Recorder/VCR Combo
Can I watch tv with the timer on the dvd recorder turned on?
Hook up the cable wire that comes directly from the wall to the dvd recorder's in connection, then get a 3 ft cable cord and connect from the out of the dvd recorder to the in on the tv. You should be able to set the dvd recorder channel and timer and leave it off. you then should be able to have your tv on and watch any station but to watch the tv with dvd recorder on, your tv should be set to either channel 3 or 4 depending on the switch on back of dvd recorder. I hope this solves your problem. Foxpaw13
Jun 15, 2009 | Panasonic DMR-EZ37VS
How to program vcr to record digital channels?
Any VCR select to input source from where recording.
So select appropiate Euroscart or other AV connection.
Digital channel will be your digital cable set top box or sat receiver, DVD player, whatever. Very unlikely you use a digital capable set topbox to output to your VCR or TV with old fashioned RF coax cable where you have to tun in to cerain RF frequency under Channel 0 or so. So when in timer menu select that input source connection. Direct recording without timer select the source with remote. This solution applies to all brands
May 02, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
Timer record on vcr/dvd attached to digital convtr box
You have to set the vcr to channel 3 or 4 (whatever the converter box is set to broadcast on). The signal to record has to come through the converter box. Since the VCR only has a analog tuner, it cannot pick up any digital channels on it's own.
Mar 29, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
Toshiba DVD recorder timer recording does not start
Does the unit not require to be in "Standby" for recording to commence.
Nov 30, 2008 | Toshiba DRW2 DVD Recorder
I have 10 year old tv Phillips model ts3258c101.Yesterday I purchased a digital video disk player & video cassette recorder. It will play a dvd. I now have found that I cannot record a video cassette...
Check if your disc player is a twin tuner model which will allow you to do what you want. It might just need configuring properly. Otherwise there are devices on sale that will allow you to achieve your goal. Good luck.
Sep 26, 2008 | Philips Televison & Video
Erase old timer entries
when you want to get rid of an old timer setting, highlight the setting you want to erase, press the left arrow once and press enter.
Poof! your old setting is gone!
Apr 06, 2008 | Dual Presidian DVD Recorder
DVD recorder
Sounds like a hardware issue. Given that the device is 2 years old, I would suggest buying a new one. Dvd recorders are not too expensive these days and you might save yourself a lot of headache by doing that. You might also try TIVO or some other form of dvr service, or set your computer up as a dvr if you know how.
Aug 13, 2007 | JVC (VDR14EU5) Mini DVD-R Storage Media (5...
DVD Timer not working
It usually means that if it doesn't record you don't have a blank DVD in the slot. Hope this helps =)
Nov 06, 2006 | Panasonic DMR-E95HS DVD Recorder
Televison & Video Logo
18 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
