Question about GE JVM1650 1000 Watts Microwave Oven
Ge microwave jvm1650sh keeps shuting off and
Ge microwave jvm1650sh keeps shuting off and allways have to input time in order to start sometimes stays good for a few days and other times every few minutes
  • GE Master
  • 9,047 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Let us know what you find out.
Otherwise, this is almost always due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
Details covering some previous models are in their bulletin here. Even if your model is not on the list, the same problem can occur.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
See
this FxYa solution.
http://www.fixya.com/support/t2330691-ge_spacesaver_jvm1650sh01_shuts_off )
NOISY MAGNETRON TEST (c) 2009 William E. Miller prototech@usa.net
(PLEASE do not be fooled into thinking that the procedure outlined at this link is a "fix". It should only be regarded as another test method to prove that you have a noisy magnetron which must be replaced.)
One way to test it is to do the following:
1. Unplug the microwave or turn off its breaker.
2. Open the door, then detach the control panel as shown in the video at http://www.microwavedisplay.com and swing it down, but without disconnecting the wires. If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
3. Plug the microwave back in.
4. Make sure neither you nor anyone else reaches in behind the control panel. There will exposed high-voltage connections.
5. Put a few cups worth of water in a microwave-safe container and place it inside the microwave.
6. Shut the door.
7. Run the microwave for about 1 minute or so on full power. (Time Cook > 1 > 0 > 0 > Start, e.g.)
8. If it does not fail, try it several more times.
9. When the water boils, change the water and try again.
NOTE:
If your model does not have a door handle, you will need to unplug the oven and reattach the control panel to be able to open the door.
If it still does not fail, I would recommend that you put it all back together and keep using it until it fails more consistently, then repeat this test.
If it keeps failing while the board is in the down position, you either have a very leaky magnetron or possibly another problem.
So you can then get a Ziploc bag and insert a flat piece of aluminum foil into the Ziploc and close it.
Then (with the power off) tape it over the circuit board as best you can, covering it as much as you can, making sure it does not get snagged or punctured.
Then try the oven again. Do not leave this test shield in place as a "fix". It is not safe.
While a microwave should never be left running unattended under any circumstances (as your owner's manual will tell you) it's even more important when one is exhibiting a failure or any odd behavior. So play it safe and stay with it while it's running!
If you or someone you know want to replace the magnetron yourself, you will need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
G.E. will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
If it is not within the magnetron warranty, you can find helpful exploded view diagrams and order parts by entering your full model number here.
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly.
William E. Miller
prototech@usa.net
Posted on Sep 11, 2009
Why is my microwave shutting off after 2 seconds?
Problem with inverter or Magnatron etc, unless you know what you are doing have a shop look at it.
Oct 14, 2012 | GE JVM1650SH Microwave Oven
Ge Microwave model JVM1650SH05 Error code F3. Microwave turns on by itself and keeps beeping
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
The easiest and quickest way to repair this yourself (it's easy) is to order a new control panel frame, which comes with a new keypad.
It's part # WB07X10959 and you can get it for $92.50 plus shipping here.
You can also find helpful exploded view diagrams at that link.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
Mar 14, 2010 | GE JVM1650SH Microwave Oven
Not heating anything up
if the light comes on and you here it buzzing but its still not heating up its likley to be the megertron burned out,, (thats the aerial for the microwave's to transmit off) its very expenive to replace,,,
bont try replacing it yourself, inside the microwave is very high voltage even if its been turned off for a long time,, 1000's of volts and they kill,,
have you ever seen a stun gun working??? this microwave has the stun guns very big brother inside it?? it dont stun,, it kills! play it safe drop it into a repair man to fix or better still buy a new one,,there so cheep now its realy not worth spending good money on an old microwave,, go out and treet yourself and play it safe!
Oct 25, 2009 | GE JVM1650SH Microwave Oven
GE PROFILE MICROWAVE LIGHT CONSTANT ON NOW
JVM1650SH - May 27, 2017
(I'm also sending this to your listed e-mail address, but with full details.)
I see (and repair) this problem a lot. The problem is on the controller assembly. Details here.
At my Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line.
Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 22, 2017 | GE JVM1650SH Microwave Oven
Beeping at night
if it beeps you might as well just unplug it
Dec 08, 2008 | Panasonic NN-C994S Convection/Microwave...
GE spacemaker microwave model #JVM1650SH
Allways unplug when your working inside a microwave, you will most likely have to replace the bulb again and also the fan, or anything else that is damaged, you will need to inspect the microwave for broken parts.
Il get you a few links to repair parts.
Sep 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
No Heat on JVM1650SH
Right on!. yup, you should be able to figure out how to swap the magnatron. Take the old one apart - they have 2 great magnets inside.
Dec 27, 2007 | GE JVM1650SH Microwave Oven
Won't stay running!
This is a due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If yours was recently replaced, it may have loose mounting nuts or bolts or the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
GE had a campaign (but not a recall, mind you!) covering several models.
Details are in their bulletin at http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf
The parts kit (that GE used to pay for) is part # WB27X10489 and is shown in the photo below.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on
Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 15, 2007 | GE JVM1650SH Microwave Oven
GE Microwave Model JVM1650
the diode is open when the voltage arive at the anode junction it locks off due to the diode is not passing the voltage,change the diode and the microwave will resume operation.good luck.
Aug 04, 2007 | GE JVM1650SH Microwave Oven
GE JVM1650SH Stainless Steel 1000 Watts Microwave Oven?
It sounds like you may have had an issue with a high voltage part such as the magnetron, diode, or transformer. It's also possible that you had an arcing stirrer. I would also check to see if your model is covered by / affected by this bulletin: http://microwavedisplay.com/ge_mw_mag_kit_bulletin.pdf If you or a friend decide to work on it, we have *critical* safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Apr 28, 2007 | GE JVM1650SH Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
253 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
