Question about Dryers
I push the start button it starts than stops after a few seconds what do you think??
  • 986 Answers
This is probably the motor going bad. The sensors wont cause this to happen. The start switch either, replacing all the sensors in the world wont make the motor be good again. But their is something you can do to try and make the motor last a while longer,their isn't any holes to oil the dryer motor so you must make some,using a 1/8th inch drill bit make a hole in either end of the motor where the bearings are (taking care not to hit the shaft), then add some hi temp oil such as zoom-oil, (dont use WD-40) and work the motor free as you can by hand. If this frees up the motor it may go a while longer. Also oil the rollers and check the slides to make sure they are not pinching and stalling the motor. If the motor can't reach top speed it will get hot,overload and stop.
Posted on Sep 12, 2009
I have a whirlpool sixth sense tumble dryer - when I switch it on it only goes on for a few seconds and then stops again. The time remaining indicator just runs Ina little square but doesn't show a time...
does it stop right after u relase or take ur hand off the push start button? ( bad push start button) does it turn off after a while then look at ur thermostats and ur venting and duct system/. Also heating element may have short in it causing it to turn off can check that will multimeter
Dec 27, 2014 | Dryers
Intermittent Start (expanded explanation)
Lint will jam the start/run switch on the motor. Vacuum out the motor real good and check that the switch moves freely, and all the wires to it are plugged in good.
Nov 30, 2013 | Maytag Dryers
Intermittent start
Not a thermo fuse sound like motor is struggling.
May just need taken apart and cleaned
How do you open lid on Maytag Centennial top load washer after it has started
Push the little rubber button which starts the machine and stand there waiting. In a few seconds it should stop and unlatch, push it again when you are ready for it to resume. Hold the button 3-5 seconds to cancel the wash cycle completely.
Apr 15, 2013 | Washing Machines
Forgotten how to turn it on. It seems to be set on timer. Oops
push stop button for a few seconds until it beeps or the readout changes. unplug,,,,,plug back in....push "Select" or "menu" button depending on which machine you have....push again and again until the program you want is on the display or readout. Then push the "start" button ....Don't push any timer buttons or arrows!
Dec 04, 2011 | Kitchen Appliances - Others
The sweep hands don't align back to zero after replacing battery
Pull out the stem to the second position then push the chronograph start/stop button a few times to move the minute hand to the zero position. Then pull the stem out to the 3rd position and adjust the second hand again by pushing the start/stop (top) button to move it to the zero position. Once you get them both to top zero push the stem back all the way and screw it in tight. Tim
Jun 21, 2010 | Watches
I just moved into a flat with the WMA641 w Beko Washing Machine. I loaded it and turned it on : settings : Delicates 30 degrees. Pushed the on button and nothing happens. after few seconds the on light...
turn the machine off at the wall , leave off for 30 secs , switch back on
and push the start button
give the door an extra shove as this may not be fully closed
the on/off button will be a push in type , the start button is usually much smaller
Oct 23, 2009 | Washing Machines
Knemore 80 series dryer won't start every time
Go to www.repairclinic.com and enter your model number and it will show you all your parts, but I suggest you change your thermostats and basically have the dryer cleaned out of possible lint build up on the interior
Mar 20, 2009 | Kenmore Dryers
Kenmore dryer start button not working
when I push the start button on my kenmore dryer it will not start and the drum will not turn.
Nov 09, 2008 | Dryers
Dryers Logo
42 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
