I work at a school, my computer tech gave me a new superDisk drive. I use it to back up work orders. Now the Icon does not show on my desktop (I use a mac)
  • 481 Answers
By SuperDIsk you mean the removable cartridge drive, right?
The drive itself will not show up on your desktop unless there is an actual cartridge in it.
If it doesn't show up even with a cartridge in it, check Finder / Preferences / General / Show these items on the desktop, and make sure External Disks is checked.
Posted on Sep 19, 2009
My external hard disk is not working properly. i can see the icon in drivers and printers but there is no folderor icon to open
Please remove the usb cable and try to connect do you see the notification new hardware found if yes just check my computer dose the hard drive shows over there if yes and double click on it dose it open if yes and the hard drive is empty .
then go back right click on the hard drive check properties dose it show the empty and the full graphs if it shows full and dosnt show the drive letter.
then right click on the my computer icon on the desktop go to manage and diskmanage ment check the hard drive over ther dose it show its unformated or un initialized if no dose it have drive letter on it if no then right click on the drive and say change drive letter and assigned one letter like h or g and check in my computer now dose it appair.if still so try changing the usb cable may its defective.
if dosent detect at all could be your hard drive case so you can remove the hard drive from inside the case and connect it directly.in the computer if works backup your data abd return backthe hard drive in the case and if its still in gurentee return it to the service center.
Dec 14, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
The icon for my lacie exyernal hard does not show
Here's two suggestions. (If your using Mac OS X 10.x)
Make sure external hard drives are to be shown by clicking "Finder" in the menu bar then "Preferences" and under the "Sidebar" section selecting "External Disks".
Also check that the hard drive is mounting by opening "Disk Utility" by first opening the "Applications" folder then the "Utilities" folder and double clicking "Disk Utility" and in the left sidebar checking to see if your external hard drive is listed as one of the mounted drives. Hope this helps, don't forget to comment/vote if this helped. Thank you.
May 30, 2010 | Apple Computers & Internet
Lacie icon not showing up on my desktop
Try disconnecting the usb cable from the drive and take the drive to a quiet place.
Power up the drive and put your ear next to it. Listen for the internal disk to speed up and then click (which means it's ready). At this point you should have a solid blue LED on the enclosure.
If not, either the disk is bad, the enclosure's controller is bad, or the external power brick is bad (put your ear next to the power brick and if you hear a faint clicking sound, the power brick is bad and you can order a new one from LaCie for about $16.00.
You rate will be much appreciated!
May 07, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
When I click on "My Computer" there usually shows the drives I have which is the "c" drive and the "d" drive. Suddenly I the "c" drive is gone. Maybe my kids touched the computer and accidentally deleted...
Do a system restore. Go to control panel and open it. Once open, click on system maintenance(opens new window) and click on back up restore center (opens new window)and when that window opens, on the left side of the window will be an option to " Repair Windows using System Restore." Click on that. A window may open up asking to continue, click yes and do a system restore back to the date when the "C" drive was showing. Computer should do a restart afterwards.
Mar 29, 2010 | Toshiba Satellite A135-S4527 Notebook
My flash drive does not work. No flash drive icon
The most likely solution to this problem is to go to the computer manufacturers website and find the drivers for your flash drive and install them.
After this, your flash drive should work fine.
Jan 12, 2010 | eMachines T6534 PC Desktop
1 TB EXTERNAL HARD DRIVE
Go into My Computer, look for the drive.
Right click on the Drive, click on Create Shortcut you will be asked if you wish to place shortcut on the Desktop instead. click yes.
A new ICON will appear on the desktop, to access the new drive you only have to click the ICON of the drive and it will open....
Jul 01, 2009 | Western Digital Computers & Internet
Bios says no ide device found (hard frive missing?)
If the BIOS is not detecting your hard drive, then there are two possible suspects here. Could just be your hard drive or it also be your motherboard.
If you have already reseated your hard drive and memory and the symptoms are still the same, then go to the nearest local computer shop that sells HP. Have them try a known-good hard drive on your system. If it works, purchase a new hard drive. If it doesn't work, your mobo needs to be replaced.
Jan 01, 2009 | HP Compaq Presario v3000z Notebook
My white ipod nano still shows the "do not disconnect" icon when connected to the usb port
can you uninstall itunes from add or remove programs and after that, install it again. You should get a icon into your desktop, if its not there.
try to find it
my computer -> c: -> Program files -> iTunes -> right click iTunes.exe -> send to -> desktop.
You should now have a icon on your desktop.
Mar 25, 2008 | Apple iPod nano
Main advantages
* Super high capacity storage/ floppy disk compatible The Panasonic PV-SD4090 and PV-SD5000 digital cameras offer super high capacity storage on a 120MB SuperDisk™ Diskette for up to 1500 shots on the PV-SD4090 (Up to 1000 on PV-SD5000). Also, both cameras are floppy disk compatible. * USB Port/External SuperDisk™ Drive Both cameras come equipped with a USB port so you can quickly and easily transfer images from either a SuperDisk™ Diskette or floppy disk (using the included USB cable) to your computer, even if your computer does not come equipped with either a SuperDisk™ Drive or floppy disk drive. In addition, images and data can be transferred from your computer to the camera using the included USB cable*. This lets both the PV-SD4090 and the PV-SD5000 digital cameras function as an external SuperDisk™ Drive so you can easily archive your images or backup all your data (i.e. Excel, PowerPoint files). * Inexpensive media Panasonic SuperDisk™ digital cameras use SuperDisk™ Diskettes or 1.44MB floppy disks. SuperDisk™ Diskettes cost approximately $10.00 each (suggested retail price), which is far less expensive than comparable CompactFlash or SmartMedia cards. * Motion image recording with audio The PV-SD5000 can record up to 12 seconds of motion images with audio (the PV-SD4090 stores up to 10 seconds) using the popular QuickTime™** format, so you can easily send motion image files to friends and family. * TIFF recording (PV-SD5000 only) TIFF format recording allows you to take uncompressed images with greater clarity and detail. * Comes with a complete package of accessories, including: 1. 120MB Panasonic SuperDisk™ Diskette 2. Rechargeable lithium ion battery pack 3. AC adapter charger 4. DC cable 5. A/V cable 6. USB cable 7. Camera strap 8. Software CD-ROM including Adobe® PhotoDeluxe® editing software *Requires Microsoft™ Windows® 98 preinstalled PC with USB port, Windows® 2000 PC with USB port, iMac® or Power Macintosh® G3 or G4 with USB port and Mac OS version 8.1 or later. Windows® 2000 driver for the PV-SD4090 is currently available on this website. Software for the PV-SD5000 will be available in the near future. **QuickTime and the QuickTime logo are trademarks used under license. QuickTime is registered in the U.S. and other countries.
Sep 04, 2005 | Panasonic Palmcam PV-SD5000 Digital Camera
Main advantages
Sep 04, 2005 | Panasonic Palmcam PV-SD4090 Digital Camera
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
