Question about Brother MFC-5840CN All-In-One InkJet Printer
MFC5840cn does not read the media cards. Shows only that it will prit, however it used to be able to import it to my HP Touchsmart computer. What is wrong or what do I need to reset?
How do I get the small panel off the back
Very carefully. Try and see if there is a YouTube video for it. What you have to be careful of is the ribbon cables
Nov 16, 2015 | HP TouchSmart 520-1020 Desktop Computer -...
Tip
How do I use my iPod With an HP TouchSmart
<p>The HP TouchSmart PC is a common computer, except it has a touchscreen. This allows you to tap the various icons on the screen for games, applications, and download files, and open your iTunes. Using an iPod with your HP TouchSmart PC is like using your iPod to another computer or MacBook. However, instead of using a mouse to navigate through your iTunes library, you need to tap your finger, or "click" on the items you want to open and upload to your iPod. <br /> <p><br /> <p>1. Turn on the computer end of the USB cable into USB port of your TouchSmart. The end of the computer's USB cable is the smaller of the two sides. <br /> <p><br /> <p>2. Connect the other end of USB cable to the bottom of your iPod. Normally, when you connect your iPod to the TouchSmart PC, iTunes opens automatically. If it does not open, tap the iTunes icon on the screen of your desktop to open the application. <br /> <p><br /> <p>3. Tap "File" at the top toolbar of iTunes. Select "Sync iPod" to upload music, photos and even files from your iTunes library to your iPod. <br /> <p><br /> <p>4. Select the "Eject iPod" icon in "Device: iPod" on the left side of the screen. This will allow you to safely remove the USB cable from your iPod and TouchSmart. <br />
on Aug 09, 2011 | Apple iPod touch
Change the Video Card
No, the graphic card is build in on the mainboard and can not be upgraded.
Dec 13, 2012 | HP TouchSmart Elite 7320 21.5" FAll-in-One...
What to do when you turn on computer and see multi vertical colored lines?
This is a known problem with the touchsmart desktops. The cooling on the motherboard and graphics card has a dreadful design and the graphics processors overheat.
The graphics card needs to be replaced, and the HP part number is 5188-7147
Aug 08, 2010 | HP TouchSmart IQ770 PC Desktop
The graphics card on my hp Touchsmart IQ770 computer is u/s and I need to replace it but I am not able to get one from anywhere.the graphics card is a geforce go 7600do you know if an alternative card can...
Not to my knowledge, The original they used to build this is mounted flat to the motherboard due to space requirements. No other I know of will work without a custom made adapter.
Jun 22, 2010 | HP TouchSmart IQ770 PC Desktop
Touchsmart i846 disc burner
Have you selected a slow disc burning speed in Roxio? If so increase it to 8x or 16x or whatever speed your media is certified for.
If you are using slow media then it does not matter what speed you set as you will inevitably encounter burn problems.
Also go to HP support at
http://h10061.www1.hp.com/ccsearch/search?pname=touchsmart+iq770&opname=HP+Deskjet+3650+Color+Inkjet+Printer&qry=disc+burn&method=prodFinder&enc=UTF-8&ctry=uk&lang=en&dlc=en&sni=304535&search=0&submit.x=0&submit.y=0
Sep 10, 2009 | HP TouchSmart IQ770 PC Desktop
When computer opens, incomplete Touchsmart windows appear
it mean your windows is corrupt just format & reinstall fresh copy of windows.
Jan 07, 2009 | HP Hewlett Packard ALL-IN-ONE-TouchSmart...
I have an HP Touchsmart computer. When I put a data or audio CD in my DVD/CD drive, it sounds like it is going to start up, the light comes on like it is going to run, but nothing happens. Sometimes, it...
CDs means totally nothing. sorry....
what CD? , a CD-R? CD-RW, or a store bought CDDA disk
all 3 are different. (or DVD? of vast types too...)
my guess you meant CD-R. (CD record-able)
TouchSmart IQ770 PC Desktop? 2007 carbon date?
what OS, XP, VISTA or W7?
My guess its bad media or bad CD drive.
only way to prove that is use new CD-R burned on good system slow.
say using the great free utility called, imgburn.
first try a real disk, from a store, from the Music section
called CD-DA disk, play it , if it plays the CD drive might be ok.
then try what I call rubber disks, recordable. CD-R
using pro grade disk burned correctly.
buying the cheapest media can be a nightmare. here.
tell HP your OS
the as an example (i guessed OS, means operating system)
install this up date, called HP HP Personal and Pocket Media Drive Driver Update
here.
https://support.hp.com/us-en/drivers/selfservice/hp-touchsmart-iq700-desktop-pc-series/3351217/model/3351218
Apr 11, 2017 | HP TouchSmart IQ770 PC Desktop
Memory stick / card slot not reading
Right click on my computer,click on properties,Click on Hardware Tab,Click on Device Manager tab.Here u can find ur multimedia reader.If it is disabled it shows red cross on it.Or if it is not installed it shows yellow exclamatory sign on it.
Regards
Sandeep
Oct 25, 2007 | HP Pavilion dv4000 Notebook
Brother MFC-5840CN All-In-One InkJet Printer Logo
26 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
