Question about Compaq (176763001) 120-Watt Power Supply
This type smps burning
i want new please, anyone can help me
    Habit-Forming:
  • 74 Answers
CAN U SEND ME THE PICTURE OF INSIDE VIEW OF SMPS
THIS IS ONLY SOLUTION
ID IS ERKAMALSINGH YAHOO.COM
I WILL HELP YOU ONLY ON THIS WEBSITE
Posted on Jan 28, 2010
Smps output voltage is gradually increasing
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Replace all the zener diode used with new ones.
Aug 06, 2014 | Sanyo Televison & Video
No power to hp envy
I suggest you step by step follow check it your Desktop issue.
A> All power plug proper connect or not, if possible change another port.
B> Have your ups get power or not, If ups on then nest step follow.
C> Check it SMPS on or off position. If your power ok and come to smps or smps not start then you SMPS damage position, you check it smps ok conduction or not..
Checking method:
SMPS more wire available you see it one more bulk wire available and black wire and green wire cross check, if not start smps then damge. But my friend if you smps ok or your are wrong wire attach then may be your smps damage. So better contact good Computer Hardware Technician.
Thanks.
Computer Support
Feb 19, 2014 | HP ENVY 23-d065 TouchSmart All-in-One...
Sanyou DP26746 LCD TV Has sound, No picture, Has backlights, LCD is active
It sounds that the main digital board to your TV has damaged. But, before make it confirm, a through check should be done. Contact any experienced service technician for help. The work is skilled one, that a user cannot do it with ease.
Jul 16, 2012 | Sanyo DP26746 26 in. LCD Television
LG LED TV SMPS & Panel cost
If you are talking about the Display Panel and a board---the cost of the panel (entire front screen unit) will easily exceed the cost of a new set. If it is being repaired and they are authorized LG they should be able to get part number for both the smps and the panel and a price.
Apr 20, 2012 | Televison & Video
I'm looking for a power supply for a sinotec 32"LCD tv. my tv was damaged by lightning
The replacement SMPS must confirm to the voltage/current sepcifications required for the TV and so it is best to get the same type from the dealer.
However if you are trying to get a universal type the output voltage and the protection should be of correct value or else it can further damage the motherboard.
finally if this was a lightnening strike please confirm if the mother board is working if not investing on a new SMPS should be reconfirmed.
Tips on SMPS repairs click ON:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Sep 20, 2011 | Element Electronics FLX-1910 19 in. LCD...
I have corei3 system. their confiuratio is intel corei3 processor 3.2 ghz/intel DH61ww motherboard,seagate 500gb sata hdd,lg 22x sata dvdrw50w smps,atx comuter case,15.6" lcd acer monitor,xerox phesar...
sounds like you need a higher wattage power supply!! meaning if you have a 500 watt power supply and it burned up then you may need a higher wattage power supply!! try a 650 or 750 watt power supply. there is only 4 screws holding the power supply in place, just un-plug all internal power cables and remove the screws and do the reverse with a new power supply. please go slow the connecting internal power cables are keyed meaning that they only fit one way!!! DO NOT FORCE THE PLUGS INTO THEIR SOCKETS OR YOU WILL BLOW UP YOUR MOTHERBOARD!!! sorry for the caps!
Aug 24, 2011 | Intel Desktop Board DH61WW Classic Series...
SMPS BURNT OUT
Does your laptop works on battery?
Do u mean to say that your adapter burn?
if so please replace the adapter.
There should not any problem related to booting of your computer as far as the Adapter concern.
Apr 12, 2009 | Lenovo 3000 N100 Notebook PC
Strange noise and burning smell form my PC tower
HI,
this seems that there is the issue with SMPS check for the following please
1.Power is comin in the machine
2.if power is there then there is short circuit
3.please get it checked with professional and if u know then once reassemble the machine and check the static mat below the m/b (if power is coming and fans are moving) other wise SMPS is bad
Feb 26, 2009 | E-Machines eMachines Desktop PC
Whare can I get the SMPS for CLP600?
Can anyone tell me where the SMPS board and fuse are. I need a diagram to check the board or fuse. Is it is the front of the machine or what?  gharris@msrce.howard.edu
May 28, 2008 | Samsung CLP-600N Laser Printer
No power
1. Please check with the power supply of pc from a/c plug. 2. if power supply is ok then ensure that the input poewer cord is at right position in behind of cpu. 3. If you are using old type power supply (which do not autumatically turned off by operating system) then there is problem with power switch or SMPS. 4. If you are using advance power management (generally used in now-a days computers which is automatically turned off by O.S., then there may be a problem with power pin that is connecting thae mother board and power button. Shut down your computer and open the cpu chasis and tighten the pin and ensure that it is properly inserted (the location of the pin is near hard disk lid pin, power lid pin). 5. If this pin is ok then check with pconnecting wire of pin and power button and also the power button. 6.Then turn the computer on. If it does not work then check the power connectors from SMPS to mother board are properly installed and inserted. 7. If power connector is ok then there is posssiblity of problem with your SMPS (power supply) of computer. 8.Generally due to heavy load of power and long usage the condensers of smps get mailfunctioned. Take the smps or computer to a local hardware expert.
Aug 25, 2007 | Compaq dc7100 Small Form Factor (PJ361UA)...
Compaq (176763001) 120-Watt Power Supply Logo
70 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
