Question about Samsung HL-P5063W 50" Rear Projection HDTV
LAMP LIGHTS UP, HAS SOUND BUT NO VIDEO - Samsung HL-P5063W 50" Rear Projection HDTV
  • 1 more comment
  • jeffcounihan Sep 12, 2009
    sorry for the delay, I have tried the component, HDMI and cable input still with no video but have audio, I also do not get any menu on screen. The lamp is on and the color wheel is spining.
  • jeffcounihan Sep 23, 2009
    The lamp does come on and the color wheel is spinning, I do not get a menu or Video using RF,component or HDMI. Audio is ok.
  • Dale Hunter May 11, 2010
    what do u have hooked up to tv for source-try a dvd
  • Samsung Master
  • 5,138 Answers
Ballast Board it is what turns Lamp on Call Encompass for part #
BP47-00021A 1-800-638-3328 or Go to E-Bay type in part# I have found good deals on Parts there.
Posted on Sep 27, 2009
Mitsubishi WD60735. Had white spots. Later lamp went. Replaced DLP Chip and lamp. Screen lights up very slightly. No sound. Green LED light is steady. Projection lamp is on. What is my problem.
Check and replace the lamp inverter too. Lamp replacement should always accompanied by the inverter too. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Feb 01, 2017 | Mitsubishi WD60735
Wd-y65 no picture. Sound for a few seconds then shuts off
Lamp is usually customer replaceable and instructions are in owner manual.
I would to begin with (set unplugged) get at the lamp to inspect it--if shattered inside look for a replacement.
Google the model number with "lamp" to see what is available.
You Tube has video instructions for replacing lamps on most brands and models as well---not have to read just look.
May 22, 2012 | Mitsubishi WD-Y65 65" HDTV
Hello.... Samsung HL-P5063W Lamp LED blinks approximately 35 times followed by 1 long standby/temp light blink After this all 3 lights remain lit and flash....lamp/standby and timer makes a loud humming...
Sound like ur tv have two problems.The "lamp"LED light flashes,mean ur tv need a new projection bulb.The loud refrigerator sound,mean the tv colors wheel is dead,it spinning off of it axes motor.Hire a tv repairman to do this the colors wheel is hard change,because require take out many machanicals parts even to get to the colors wheel to change.The bulb is easy replaced,but he there pay him to put new one in.
May 26, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Just changed the lamp in my samsung 4663w. lamp light blinks a while then all three blink. sound but no picture
hi, leaves only 3 options
1. color wheel not coming up to 6000 rpm`s
2. no ballast strike to lamp
3. lamp door safety switch in wrong position when door was re-attatched.
highly unlikely but not impossible u got a defective lamp, did your old lamp still come on? if so put it back in, if it lights up new lamp is bad, my money is on the color wheel if you installed lamp door correctly, gl, video-tek
Jun 04, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Hp pavillion dv2000 has a black screen
First thing is to check if the video card is OK.
Connect an external monitor to your laptop, if you get a clear image on this monitor then the video card in the laptop is OK.
A faulty backlight could be caused by a defective inverter that supplies high voltage to the CCFL lamp or a faulty CCFL lamp. Most likely a faulty CCFL lamp.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 09, 2009 | Dell Latitude D600 Notebook
Sharp projector(xr-10x) lamp wont come on. lamp only 600hrs old. second lamp to have stopped around this stage. could their be any other issue. when lamp did come on projector made a buzzing noise which i...
that noise could be the color wheel. it sound like a fan. but it could be a fan and if fan does not work properly , the lamp would not stay cool.
Maybe you should have a service center look at . before you get another lamp.
thanks doctor video
Jun 07, 2008 | Sharp Televison & Video
Weird Rapid Metallic Popping Sound
I think i have the same problem, but i can get audio still. did the poping plinking sound come from the inside back panel of your TV? it sounded almost like a arc wielding noise?
Sep 29, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Samsung HL-P5063W 50" Rear Projection HDTV Logo
133 people viewed this question
Henry  Thomas
Henry Thomas
