Question about Maytag Neptune MAH5500B Front Load Washer
My Neptune does not fil with cold water during the
My Neptune does not fill with cold water during the rinse cycle. It fills with only hot water & the clothes are steaming hot when removed. I was told by my repairman it is normal for hot water to be in the cold cycles to get it to 70 degree temp.
    President:
  • 1,776 Answers
Check for a cold water supply problem, since cold water is what is used in the rinse. Check the water inlet valve. Remove the water supply hoses and check the small metal screens inside the openings on the valve. Make sure they are clear of rust or debris (especially the cold water side) and check the solenoids. They can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid. I will attach a photo for reference. Hope this helped and best wishes.
Posted on Sep 11, 2009
WDSR2120J washer will not fill in rinse cycle
possible 3 solutions for this problem 1 could be the cold fill solenoid 2 could be brushes in motor 3 could be main pcb
Feb 20, 2013 | Washing Machines
Not getting enough water during rinse cycle
In the rinse cycle it will use cold only to rinse with.
You need to see how fast the water is going into the machine on rinse
Things that can effect slow fill, low water pressure, Faulty cold valve
water hose & valve filters clogged, Kinked hose
Feb 21, 2012 | Fisher and Paykel IWL12 Top Load Washer
There is a hot water valve & a cold water valve on the Dexter T300 machines but it is a 2 coil valve. does the hot water valve supply only hot water or does one side provide water to perhaps the...
supplies hot water when needed, cold water when needed. and then warm water when needed. so the second coil is for warm water. it basically mixes the hot and cold water.
Mar 17, 2011 | Washing Machines
My Maytag Neptune will not go into the spin cycle, instead the letters "nf " come on the display. What can I do to prevent this and to have the cycle completed?
Bonnie,
NF = No Fill the control board receives signaling for the washer during the water fill cycle. With most cycles the depth of water is around 3.5 inches in the wash basket. I know a Bulky Wash cycle selection will fill the wash tub to a high fill which is about 7.5 inches of water in the wash basket.
Is the washer filling the machine with any water? Do you hear water entering the machine? If you are doing a cold water fill and there is no or very little water in the wash basket with the NF error code. Try a Warm or Hot fill and see if the machine will fill and start the wash cycle.
Assuming you are doing cold water wash loads. You could have a water line block at the inlet screen or a failed cold water inlet valve which will not open. Try the above and let me know the results..........Rich
Sep 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Water pressure for Washer (rinse only)
you nead to turn off both cold and hot water.next you nead to remove cold water hose from washer.remove screen and clean it and replace it.hookup cold water hose to washer and turn water back on.you should have better pressure.your rince cycle is cold water.
Nov 18, 2009 | Kitchen Ranges
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag Neptune stops during rinse cycles
from what you say it doesnt sound like a water valve. does it fill to correct level the first time round?
Mar 27, 2007 | Maytag Neptune MAH7500WH Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
198 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
