Question about Remington Electric Pole Saw
Putting chain back on remmington chain saw . Can not dowload manual
    Sergeant:
  • 384 Answers
Lay chain over sprockets and adjust arm to tighten chain.
Posted on Sep 11, 2009
14SB REMMINGTON HOW TO REPLACE THE CHAIN
Remove the cover, loosen the bolts to allow the bar to slide toward the sprocket. Lift chain off the sprocket and pull out from the notch in the bar. Be sure to turn the chain the same direction, otherwise you will be cutting with the back side of the blades. Slide the new chain blade onto the sprocket then fit into the bar. Once that is accomplished pull the bar firmly outward watching to see that the blade stays inside the slot of the bar. While keeping pressure on the chain and bar, tighten the retaining bolts and replace cover
Sep 28, 2014 | Remington Electric Chain Saw
Chain fell off and I can't get it back on.
Turn the saw off. Look for several nuts on the right side of the saw that hold the cover on and the blade to the saw. Loosen these nuts, and before taking the cover off, loosen the chain adjuster by turning it (usually a screw head on the same side, or on the front of the saw as you look down the blade towards the saw.) Loosening the chain adjuster moves a pin that goes into the bar (the part the chain rides around when operating) to push it away from the saw to tighten the chain when you are tightening it. Take the cover off, and put the chain around the sprocket at the back like a bicycle chain, and then while holding the bar (sometimes a partner helps) parallel to the saw and outward away from the front of the saw, align the bottom parts of the chain inside the bar guide slot all around the bar, holding just enough tension that it doesn't fall off the sprocket or get misaligned in the bar guide. Try moving the chain a little bit to make sure it is not binding on anything. If it doesn't move at all, make sure the chain brake is not on. Once it is moving smoothly, put the cover back on, and begin to hand tighten the nuts. Just before they begin to get tight, eyeball where the chain tensioner pin is in relation to the hole it is supposed to go in. Adjust the chain tensioner screw to move the pin towards the hole. When it pops in the hole, continue tightening the nuts by hand until tight. Now you and your partner can let go of the bar. Adjust the chain tensioner for the proper tension in the chain, not too loose, not to tight, refere to your manual. Finish tightening the cover nuts using the universal wrench to the specifications given in the owners manual.
Sep 06, 2011 | Poulan 14" Electric Chainsaw
Where can I find parts for my remmington chain saw?
Take saw to good farm supply store they will order for you.
Aug 24, 2011 | Remington Electric Chain Saw
I have a remmington limb chain saw and need a part. Where can I find one
Hi "grouch",
Here are a couple of websites to try:
http://www.masterparts.net/remingtonelectricchainsaw.html
http://wssemw.arinet.com/scripts/EmpartISAPI.dll?MF
You can also check out ereplacement parts, but you have to know your model # to find it. Yours is an MTD product:http://www.ereplacementparts.com/
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 06, 2011 | Desa International Remington 14" Electric...
What type of oil should I use for my remmington electric pole saw
You should use a non fling chain oil, available from any chainsaw shop, if you cannot get this, then a gear oil will sufice
Mar 19, 2011 | Garden
I was using the saw as a chain saw last weekend to cut up an old tree stump when the chain came off. I don't know how to access it to put it back on and don't have a user manual. The saw belonged to my...
You will have to remove the cover on the side the chain bar goes into. There should be one or two nuts holding the cover on the side. The is also a chain tension adjuster you may have to loosen to put it back on. Make note of the direction of the teeth on the chain. It is an directional chain. The tension adjuster is usually a flat head screw on the front side right beside the chain bar.
Unless it is a really old saw, manuals are available from most manufacturers for free download. See if you can locate a brand name and model number.
Jun 16, 2010 | Remington Electric Pole Saw
Looking for the age of a Remmington model 121
These rifles were made between 1936 and 1954. There is more detailed information about them on the Remington website.
Oct 17, 2009 | Remington Electric Chain Saw
Lost oil cap and bulb
Remmington's parts department.
Sep 14, 2009 | Remington Electric Pole Saw
Remington 16 in. electric chain saw
Go to www.masterparts.net Remington chain saws are listed by bar length and model number. There is a parts list with each saw.
Oct 27, 2008 | Remington Electric Chain Saw
Remington Electric Pole Saw Logo
160 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
