Question about Akai CFTD2011 20 in. EDTV-Ready LCD Television
The Akai 20" LCD Power Supply card is burnt
Burned at 2-3 points under the transformer.... some very small IC's on the track side at these points look to be charred
    President:
  • Akai Master
  • 1,779 Answers
Replace the Power Supply! Try ShopJimmy.com
Posted on Sep 11, 2009
There is no sound from my speakers
Dose the green LED light up at the front ? . If it does not its a power supply issue. You must have burnt the transformer in the power supply unit. If the light lights up ans there is no sound it could be the Amplifier Chip (IC ) problem. This will involve soldering and desoldering work not to mention procuring the IC.Cos wise the IC just cost about 3$ ans the transformer about 7$.
Aug 27, 2011 | Creative Labs SBS 20 Computer Speakers
The problem started from a power surge.
You may be on the wrong track here.......fly backs are a common failure,but not because of power surge. Most commonly the problem would be on the primary side of the power supply ,such as the rectifiers and sw mode regulator. If you want to prove it,just un solder the horiz out transistor(q401) and the pin of the flybackit connects to...... and if it still blows fuse ,you need to work on the power supply.......not the horiz/hv area
Jun 04, 2010 | RCA F36665 36" TV
Acer X223W power supply
the voltage inverters are the small transformers attached to a small pcb, that is connected to the backlight inverter (cold cathode).
Just in case replacing the capacitors did not work, the second thing to do is to check the backlight inverter. If there is busted light, replace this one too..the last thing to check is the high voltage ballast transformer... if one of these is burnt, it is enough to affect the stability of your supply current. It can also result to a dark portion on your screen or worst , could result to a total black screen..
If you can replace this transformer with the same value, please do so.
If this is a help to you.. please rate this solution...thanks.
May 28, 2010 | Acer 22" X223w LCD Monitor
Turn it on screen with blue AKAI comes on breifly then cuts right back off smelled like a transformer or something burned out
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Akai+LCT3285TA+
Please post back what you find.
Dec 17, 2009 | Akai LCT3285TA 32 in. LCD Television
AKAI 50'' Plasma PDP5006H Main Power Supply Board p/n LJ4400057A
I looked around for a power supply for you and turn up nothing. I see your problem. Nobody is selling. Best just to fix the board itself.
What I would do is get a Service Manual over the internet. Nodevice.com is selling the Service Manual. Usually cost under $20. It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part number lists. And most cases the new part cost less than $15 by searching on the internet with the part number.
It's possible that it's just a bad capacitor or transformer on the power supply board. Cheaper than replacing the board.
I hope I solve the problem for you.
Jul 20, 2009 | Televison & Video
I just replace convergence board on my akai tv and
There is a burnt capacitor somewhere in the unit. Look for any burnt or swelled up capacitors. You can also usually locate a bad cap if there is burn marks on the system board. Also test power supply with voltmmeter to make sure it is a constant volt reading.
Jul 11, 2009 | Akai PDP-42TD1 42 in. EDTV-Ready Plasma...
Akai LCT2721AD won't turn on. it started months ago. First you would need to keep pushing the power button and after anywhere from 2 to 10 mins it would turn on but after awhile it wouldn't turn on at all....
Most likely the TV has a power supply related problem. Most causes are burned out capacitors or transformers.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
Jul 07, 2009 | Akai LCT2701TD Television
Tv keep going on standby when you turn it on
tv goes into standby all the time if a power supply is not fine, what happens is that a power supply produces two voltages, one small one powers a standby components and bigger voltage powers a line transformer which later produces more small voltages,
then later cancels the first small voltage.
chec your power supply semi conductors like, transistors, diodes and small value resistors, on your power supply. some power supply uses a IC to oscillate a ht. so check a supply at a w/shop.
Feb 07, 2009 | Goodmans 257NS 20" TV
POWER FAILURE
you must look around for the reson of this burning look for burnt resisttor--explosive capacitor-----short circuit capacitors----short of winding in pulse transformer-----circuit diagram will be helpful.
Aug 09, 2008 | Sony DAV-SC5 System
Akai CFTD2011 20 in. EDTV-Ready LCD Television Logo
936 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
